DIY: M5/M6/S85 Recall, Tech Service Bulletin/Service Information Bulletin/Technical Docs Thread - One Stop Shop - Page 2 - BMW M5 Forum and M6 Forums
 22Likes
post #11 of 36 Old 11th April 2013, 05:19 PM
5soko
5soko's Avatar
Great info! Was looking for the whole thing. This is def a sticky with a lot of good info about our cars.
2009 ///M5
Evolve Alpha-N Stage 2 Flash Tune | Eventuri Intake Kit | Supersprint Full F1 70MM-Xpipe-Catless
OEM Alcantara tri-stitch steering wheel|LUX H8 160 Angel eyes|Osram CBI's
IND Black Gloss Fender Vents|IND Painted Side Markers
Satin Black OEM wheels |Michelin PSS |30% Tint|LED License Plate lights
BMW Performance Grills|Full OEM BMW LED Interior + Trunk
Oem M projection Door lights|US Mill Work Tow plate|OEM M Floor Mats|Coding
5soko is offline
post #12 of 36 Old 11th April 2013, 08:50 PM
Stealth 993
Stealth 993 is offline
post #13 of 36 Old 12th April 2013, 02:29 PM
ror600
ror600's Avatar
ror600 is offline
post #14 of 36 Old 12th April 2013, 05:33 PM
Noble Rise
***ROUTINE/SCHEDULED MAINTENANCE:
Summary of Mike Miller’s Old School Maintenance Schedule (not specific to E60 M5)
(Email Mike Miller for the full writeup: techtalk [at] roundel.org):
- Brake fluid: Every 1-2 years
- Engine coolant: Every 2 years (50/50 mix of BMW anti-freeze + distilled water)
- Engine oil/filter: Every 7,500 miles (Castrol TWS Motorsport 10W-60)
- Engine air filter: Inspect every 15,000 miles, replace every 15,000-30,000
- Cabin air filter: Inspect every 15,000 miles, replace every 15,000-30,000
- Power steering fluid: every 30,000 miles (Pentosin CHF 11.S)
- Transmission oil (SMG & 6MT): every 30,000 miles (MTF-LT-2 or Red Line MTL)
- Differential oil: every 30,000 miles (Castrol SAF-XJ or Red Line 75W-140)
- Valve adjustment: every 30,000-60,000 miles
- Spark plugs: every 30,000-60,000 miles (stick with OEM but Amazon has them cheap)
- Fuel filter: every 60,000 miles
- Engine drive belts: every 60,000 miles
- O2 sensors: 150k miles (or just wait for it to trip a CEL)
- Water/fuel hoses: 150k miles
Noble Rise is offline
post #15 of 36 Old 12th April 2013, 05:45 PM
Killer-Bimmer
Killer-Bimmer's Avatar
^ Isn't all this in the DIY sticky?
Regarding the rest of the documents I Think they should just be pulled into the DIY sticky as well!
Just my $0.02....
Cheers!
Killer-Bimmer is offline
post #16 of 36 Old 12th April 2013, 06:03 PM
jcolley
m5board.com Site Sponsors
jcolley's Avatar
I'm kind of thinking that myself as well. I don't want to clutter the top half of the board with stickies. I seem to have awaken with mod powers this morning, so I'm going to poll the others and see what they think.
jcolley is offline
post #17 of 36 Old 13th April 2013, 02:15 AM
jcolley
jcolley's Avatar
Found another:
SI B 23 01 06
Manual Transmission January 2006
Technical Service
This Service Information bulletin supersedes S.I. B23 01 06 dated January 2006.
(New) designates changes to this revision
SUBJECT
SMG III: Fault Code 5101 Analyze Hydraulic Sensor
MODEL
E60 M5
SITUATION
While driving, the SMG control unit may intermittently switch to the emergency program. The SMG module has Fault Code 5101 (Hex) "Analyze hydraulic sensor" and the environmental condition: "Hydraulic pressure sensor earth cable broken stored in memory.
CAUSE
SMG III module software diagnostics is too sensitive.
PROCEDURE
Perform "Short Test" and clear faults.
Do Not Replace Any Parts!
(New) Reprogram the vehicle using Progman V 20.1, or higher to Target Data status (E060-05-12-510)
WARRANTY
For the appropriate labor operations please refer to the KSD system.
jcolley is offline
The Following User Says Thank You to jcolley For This Useful Post:
mdyaman (22nd April 2013)
post #18 of 36 Old 13th April 2013, 02:16 AM
jcolley
jcolley's Avatar
SI B 61 14 03
General Electrical Systems January 2006
Technical Service
This Service Information bulletin supersedes S.I. B61 14 03 dated December 2005.
SUBJECT
MODEL
E60, E61 (5 Series)
E63, E64 (6 Series)
SITUATION
Customer may complain of the following:
(New) The following software errors were corrected with the release of Progman 20.01.00 (Target data Status E060-05-12-510).
While driving, the SMG control module switches to emergency program. SMG Fault Code 5101 (Hex) "Analyze hydraulic sensor" is stored. (E60 M5 only) Refer to SI B23 01 06.
PROCEDURE
For all vehicles, on a customer complaint basis only, refer to the following procedure and warranty information.
Update the complete vehicle per SI B09 05 01 (Coding, Individualization, Programming) Procedure B, using Progman (New) 20.01.00 (Target Data Status E060-05-12-510) or higher.
WARRANTY INFORMATION
Covered under the terms of the BMW New Vehicle Limited Warranty.
jcolley is offline
post #19 of 36 Old 13th April 2013, 10:53 PM
jcolley
jcolley's Avatar
Merged the Technical Documentation thread with this SIB/Recall thread. Fixed attachment titles & hotlinked 3 SIB posts into OP.
jcolley is offline
post #20 of 36 Old 15th April 2013, 06:48 PM
jcolley
jcolley's Avatar
Found a more recent master SIB list: SIB_List_Rev_23_Jun10[1].pdf
Shows we are still looking for a lot of SIBs:
  • SI B12 09 07 May-07 M5/M6 Service Engine Soon Light Illuminated: S85 - Various VANOS Related Faults Stored
  • SI B12 19 08 June-08 M5/M6 V10 S85 - Power Reduction with Idle Actuator Faults Stored
  • SI B12 21 08 April-09 M5/M6 S85 - DME Fault 2742/2743 for O2 Sensor
  • SI B23 01 05 November-05 E60/M5 E60 M5 - CAN Communication Fault FFFF
  • SI B23 01 07 August-07 S85 M5 Service Action: Replace SMG Hydraulic Unit Electric Motor on M5 Vehicles (rpl 7/07)
  • SI B23 08 06 January-07 All SMG Cars SMG - Service Functions Performed after Drivetrain Repairs
  • SI B23 03 08 December-08 M5/M6 M5, M6 with SMG III; FC 4F82/4F83/4F84/4F85 - Gear Blocking Faults (rpl 10/08)
  • SI B32 02 08 August-08 M5/M6 Repair Instructions for Power Steering Pump and Pressure Line
  • SI B33 01 07 October-07 E60 - M5 E60 M5 Howling Noise from Rear Axle Area
  • SI B34 07 07 November-07 M5/M6 M5, M6 - DSC Disabling Function
  • SI B51 06 07 March-07 E60 - M5 Service Action: Replace Underbody Panel
  • SI B65 24 08 December-08 M3/M5 Audio System Is Intermittently Inoperative
  • SI B11 05 07 April-07 All S85 (V10) Service Action: Replace Front Crankshaft Radial Seal
  • SI B12 18 06 November-06 Ms Voluntary Emissions Recall 06E-A04: S85 - DME Reprogramming for OBD Monitoring
  • SI B12 28 08 December-08 S65 / S85 S65 / S85 Rough Running During the Catalyst Heating Phase
  • SI B23 03 06 April-07 M Cars Getrag SMG Transmission Repair & Replacement Information (SMG II and III) (Rpl 02/06)
I will start looking for them, if anyone has access to PDFs of these, post them up and let's all get smarter!
jcolley is offline
The Following 2 Users Say Thank You to jcolley For This Useful Post:
5soko (16th April 2013), mdyaman (22nd April 2013)
Currently Active Users Viewing This Thread: 19 (0 members and 19 guests)
Progman v26 Service Information Bulletin (SIB) rslee E60 M5 and E61 M5 Touring Discussion 17 4th February 2013 10:07 AM
Vanos Service Information Bulletin 12 09 07 Digi E60 M5 and E61 M5 Touring Discussion 5 10th January 2008 04:04 PM
M5 Technical Service Bulletin List howler E39 M5 and E52 Z8 Discussion 0 16th November 2004 04:28 PM
Recall and service bulletin site Pete E39 M5 and E52 Z8 Discussion 2 12th July 2004 01:22 AM
Current Recall and Service Bulletin list for MY2000 M5 jkleb E39 M5 and E52 Z8 Discussion 2 5th September 2001 05:22 PM
