Is it possible an engine malfunction-reduced power light - BMW M5 Forum and M6 Forums
Old 3rd August 2012, 16:42   #1
Gavin S.
Garage: 2006 M5 Interlagos Blue
is a transient thing or does it always result in catastrophic engine repair? I had one pop up yesterday on my 06. I turned off the car and restarted it and it went away. I have a call into my dealer but haven't heard back yet.
Gavin S. is offline   Reply With Quote
Old 3rd August 2012, 17:15   #2
EuroCarFan
Garage: 2006 RPI Stage 2 M5 Sapphire Black
Sales Feedback: (5)
I've had this happen to me twice. The first was after a spark plug change and one of them happened to be loose. The second was accompanied by a bunch of other faults too and the problem was an idle actuator.
2006 M5 Blk/Blk/Alum Fully Loaded
Engine: ESS/RPI Stage 2 Tune | RPI Ceramic Coated Headers + GTS Exhaust w/Gloss Black Tips and Red RPI Logo + Ram Air Scoops + BMC Filters + Block-Off Plates + Pulley + Oil Cooler | Sprint Booster V2 | Euro SMG LC Tune
Wheels, Susp & Brakes: Neez QD7s Hyper Black 20x9-10 | PS2s | KW V3s | Dinan FRC + Rear Sway Bar + Front & Rear CF Strut Braces | Brembo 380mm BBKs
Exterior: Revozport CF Splitter | Hamann Replica CF Roof Spoiler | Vorsteiner CF Trunk Spoiler | Hartge Diffuser | CF Lower Mirror Covers | CF Side Gills | 3M Clear Bra
Interior: RDSport Alum Pedals | Hardwired V1 | iPod Integration Kit | BSW Stage 1 Speakers | Flat Bottom Steering Wheel w/CF Trim | AS Designs Red Tachometer
Lighting: Eurospec Headlights w/Clear Corners | LCI LED Taillights | Trinity Autosport 5W AEs | Trinity Autosport Interior LEDs
Coded Options: Folding Side Mirrors, Windows and Moonroof w/Remote | Deleted "Accept" Screen | Turn Signals in HUD | Real Speed in OBC Screen | Automatic Heated Seats Controls in iDrive
EuroCarFan is offline   Reply With Quote
Old 3rd August 2012, 17:57   #3
bradstard
bradstard's Avatar
Garage: 2008 M5 Alpine White
I've also received this code and have not seen it since the idle actuator was replaced.
2008 M5 (daily)
2003 F250 (tow vehicle)
1998 Integra Type R (track toy)
2006 Odyssey (wife's)
bradstard is offline   Reply With Quote
Old 3rd August 2012, 18:32   #4
ACG
ACG's Avatar
Garage: 2004 Infiniti G35 Twin Turbo, 2006 RPI/ESS VT2-650 M5
Sales Feedback: (10)
Let's just say if it comes back then you def will need to get it seen to but def not a catastrophic engine repair by any means.
2006 Supercharged VT2+ BMW M5
Performance:SC VT2-650 / Alpha N Tune / Sprint Booster V2 / RPI GTS Exhaust / RPI SV1 Oil Cooler / RPI Jet Hot Coated Headers
Handling: KW V3 Coilovers / Dinan Rear Sway Bar / Dinan Front Roll Control / Tires F 255/35/19 R 285/30/19 / 12mm Rogue Engineering Spacers / 19x9/19x10.5, 3 Pc Rennen R8 Concave Wheels (Matte black face with chromed lip)
Exterior:Vorsteiner Rep Hood / Gloss Black Roof Wrap / Matte Azure Blue Metallic Car Wrap / Smoked LED Side Markers, Limo Tint / Custom headlights with Orion V2 rings / Custom Blacked Out LCI Tail lights and Miranda Bruce V 6 Cables / Hartge Rep Urethane Front Lip / AC Schnitzer Roof Spoiler / Matte Black Kidneys Grills / Gloss Black Side Gills / Gloss Black Rear M5 Emblem / Black/White CF Hood &Trunk Roundel / Rear Bumper Mesh
Interior:White LED Interior Lighting / Black/White CF Steering Wheel Roundel / Aluminium Steering Wheel Trim / Handbrake Handle/Pedals /Hardwired Valentine 1
Programming: Mirror Fold-up / Window Roll-up / Sunroof Closure / Auto S5 at Start up / Euro Launch Control / iDrive Acceptance Delete
Braking: RDSports 6 Piston F 380/35mm and 4 Piston R 380/32mm Big Brake Kit
In Process:
Low Compression Engine Builld:
Mahle Custom Pistons
Carrillo Rods
Custom Fuel System
Custom Alpha N Tune
Custom SC Kit Color Scheme
Wants:JME Rear Diffuser
MAHA Dyno 570rwhp 400trq 60-130mph 8.29secs
RIDES:
2004 Infiniti G35 APS TT with built motor and fully built transmission. 520rwhp and 550ft trq.
2006 BMW M5 VT2-650 SC 570rwhp and 400trq.
2008 GMC Yukon Denali
ACG is offline   Reply With Quote
Old 3rd August 2012, 19:29   #5
Gavin S.
Thanks guys. I guess speculating is futile.
Old 4th August 2012, 10:55   #6
Mike Benvo
Garage: BMW
It could be a number of different thigns. Usually it's a malfunctioning sensor, or misfire detected, oxygen sensor, MAF sensor problem, etc..
If the warning came up, a code is surely stored for what is likely the culprit
_________
Mike Benvo - BMW Coding / Programming Expert - E60 M5 Euro SMG Available
E60/E61 Coding List Available Here: http://www.bpmsport.com/Coding.pdf
Cars:
E90 M3 6MT - Akra Evo, Crank Pulley, Stage II BPMSport ECU Flash, BBS LM, LCI
E60 Silver Grey BMW M5 - Dinan Rear Section, Crank Pulley, Stage II Flash RIP
E60 2010 550i M-Sport Automagic - 100% bone stock other than window tint
1990 E32 735i -Low Comp M35B30 w/ GT35 Turbo, Air to Water intercooler @ 14 PSI
540HP 2003 BMW 330ci - Low comp, 15PSI ASA Supercharger, ~540WHP - RETIRED
mbenvo@gmail.com
Mike Benvo is offline   Reply With Quote
Engine Malfunction Reduced Power Mbanks2 USA South BMW M Forums 0 8th August 2010 19:34
Engine Malfunction reduced power to 3,500 AUTOG4 E60 M5 and E61 M5 Touring Discussion 12 2nd July 2010 01:58
engine malfunction, reduced power jdl92 E60 M5 and E61 M5 Touring Discussion 24 28th May 2010 00:46
DSC Malfunction, Reduced Power + Orange Brake Light.HELP IndyredNJ E60 M5 and E61 M5 Touring Discussion 3 5th April 2010 18:38
Engine Malfunction: Increased Emissions AND reduced power! V10BEAST E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 7 2nd November 2006 03:39
