HELP!!!DSC malfunction increased emissions error - BMW M5 Forum and M6 Forums
Like Tree1Likes
Old 31st July 2012, 01:44   #1
BADBOY'S M5
BADBOY'S M5's Avatar
Garage: E60 ///M5 Silverstone II
Ok, sorry if this has been talked about before.
Car has been great so far but, yesturday went to my sisters house, parked the car, locked it, 20 minutes later, alarm goes crazy, ran outsite, unlocked the car, locked it. everything ok. 20 min later, same thing happens, ran outside again, unlocked it and decided to start it. DAMN!!!
DSC malfunction;reduced vehicle stability under acceleration bla bla bla. checked what I could, shut it off, went back inside for an hour, when I left to go home, no msg and no errors. I'm thinking ok, weird, drove home, no issues.
Went to work today, no issues, went to go get the wife. Then #$ck, new msg, Increased emissions!
check the battery, volt meter is reading 13.67 with car running.
any suggestions? car is an 06 m5 with 98000k. I have 3rd party Ensureall warranty Plus.
Thanks Bobby.
E60 BMW ///M5 |Silverstone II on Black Full Leather-Suede Anthracite Alcantara roofliner
|Matt Black Grills|Blk-Carbon Fiber Badges|RPI Ram Air Scoops|Block off Plates|High Performance BMC Filters|Charcoal Filters Removed|RPi ST Pulley Kit |LED plate lights|Interior LED conversion|CODED|Tints 35%|Smoked tail lights|12mm H&R Spacers|H&R lowering Springs|Eurocharged|Sprint-Booster V2|BLK Side Skirt Diffuser's| Gloss Blk Roof wrap|
___________________________
2006 E60 BMW ///M5 Current
2001 E46 BMW 330ci /Mpkg-current daily/winter car
2000 BMW E39 540i Modded-retired
2008 Nissan Pathfinder LE-retired
2005 Jeep Grand Cherokee LTD HEMI-retired
1998 Infiniti QX4
1997 Jeep Grand Cherokee LTD
1990 BMW E34 535i Racing Dynamics Modded-retired
1987 Cutlass 442-retired
BADBOY'S M5 is offline   Reply With Quote
Old 31st July 2012, 01:49   #2
EuroCarFan
Garage: 2006 RPI Stage 2 M5 Sapphire Black
Sales Feedback: (5)
There have been several threads where members received the same error messages, including myself. Looks like the common problem was the idle actuator in bank 1 or bank 2. The dealer's process would be to look at your battery first, then try to update your software then next step.
2006 M5 Blk/Blk/Alum Fully Loaded
Engine: ESS/RPI Stage 2 Tune | RPI Ceramic Coated Headers + GTS Exhaust w/Gloss Black Tips and Red RPI Logo + Ram Air Scoops + BMC Filters + Block-Off Plates + Pulley + Oil Cooler | Sprint Booster V2 | Euro SMG LC Tune
Wheels, Susp & Brakes: Neez QD7s Hyper Black 20x9-10 | PS2s | KW V3s | Dinan FRC + Rear Sway Bar + Front & Rear CF Strut Braces | Brembo 380mm BBKs
Exterior: Revozport CF Splitter | Hamann Replica CF Roof Spoiler | Vorsteiner CF Trunk Spoiler | Hartge Diffuser | CF Lower Mirror Covers | CF Side Gills | 3M Clear Bra
Interior: RDSport Alum Pedals | Hardwired V1 | iPod Integration Kit | BSW Stage 1 Speakers | Flat Bottom Steering Wheel w/CF Trim | AS Designs Red Tachometer
Lighting: Eurospec Headlights w/Clear Corners | LCI LED Taillights | Trinity Autosport 5W AEs | Trinity Autosport Interior LEDs
Coded Options: Folding Side Mirrors, Windows and Moonroof w/Remote | Deleted "Accept" Screen | Turn Signals in HUD | Real Speed in OBC Screen | Automatic Heated Seats Controls in iDrive
EuroCarFan is online now   Reply With Quote
Old 31st July 2012, 01:50   #3
EuroCarFan
Sales Feedback: (5)
Here's the thread that I found which helped me provide the info to my dealer: Reduced Power + DSC + DBC + Start assistant FAILURE !
Old 31st July 2012, 01:58   #4
BADBOY'S M5
Thanks, have read all the msgs, but my DSC msg went away and now just say's increased emmisions, from what I read, (i'm probably wrong) but I didnt see this msg come on on anyones malfunction.
will call SA tomorrow and book it in.
Thanks for your response,
Old 31st July 2012, 02:02   #5
EuroCarFan
Sales Feedback: (5)
Good luck. Hope it's something as simple as the battery.
Old 31st July 2012, 02:49   #6
BB8888
BB8888's Avatar
Garage: 2006 ///M5 Silverstone
i had same issue only with increased emission my fuel went low and because of that appeared message i rechecked it other day i let my fuel to go low and same thing happened
2006 M5 E60
2006 CLS 500
2003 S600 Bi Turbo(sold)
BB8888 is online now   Reply With Quote
Old 31st July 2012, 02:51   #7
BADBOY'S M5
thanks, fuel is above half, i wish it was that...
Old 31st July 2012, 05:37   #8
jborowicz
jborowicz's Avatar
Garage: 2008 M5 Indianapolis Red/Portland Brown;2007 X5 4.8i
Possible fix?
Bobby,
I have an '08 and had the same errors about a month ago. I'm still under CPO warranty and they found that one of the Throttle valve actuator motors for bank 1 failed and replaced it. The part # is 13627834494 : Actuator
The Server Advisor said that the repair would have been $1100 if not under warranty.
One other thing, I use Torque and it read a P1628 - Powertrain code.
Hope this helps,
Jim
jborowicz is offline   Reply With Quote
Old 31st July 2012, 06:34   #9
ACG
ACG's Avatar
Garage: 2004 Infiniti G35 Twin Turbo, 2006 RPI/ESS VT2-650 M5
Sales Feedback: (10)
Even if the message disappears I promise you it does return and then it gets worse. Mine and fixed under warranty but I have heard others stating their warranty would not cover it
2006 Supercharged VT2+ BMW M5
Performance:SC VT2-650 / Alpha N Tune / Sprint Booster V2 / RPI GTS Exhaust / RPI SV1 Oil Cooler / RPI Jet Hot Coated Headers
Handling: KW V3 Coilovers / Dinan Rear Sway Bar / Dinan Front Roll Control / Tires F 255/35/19 R 285/30/19 / 12mm Rogue Engineering Spacers / 19x9/19x10.5, 3 Pc Rennen R8 Concave Wheels (Matte black face with chromed lip)
Exterior:Vorsteiner Rep Hood / Gloss Black Roof Wrap / Matte Azure Blue Metallic Car Wrap / Smoked LED Side Markers, Limo Tint / Custom headlights with Orion V2 rings / Custom Blacked Out LCI Tail lights and Miranda Bruce V 6 Cables / Hartge Rep Urethane Front Lip / AC Schnitzer Roof Spoiler / Matte Black Kidneys Grills / Gloss Black Side Gills / Gloss Black Rear M5 Emblem / Black/White CF Hood &Trunk Roundel / Rear Bumper Mesh
Interior:White LED Interior Lighting / Black/White CF Steering Wheel Roundel / Aluminium Steering Wheel Trim / Handbrake Handle/Pedals /Hardwired Valentine 1
Programming: Mirror Fold-up / Window Roll-up / Sunroof Closure / Auto S5 at Start up / Euro Launch Control / iDrive Acceptance Delete
Braking: RDSports 6 Piston F 380/35mm and 4 Piston R 380/32mm Big Brake Kit
In Process:
Low Compression Engine Builld:
Mahle Custom Pistons
Carrillo Rods
Custom Fuel System
Custom Alpha N Tune
Custom SC Kit Color Scheme
Wants:JME Rear Diffuser
MAHA Dyno 570rwhp 400trq 60-130mph 8.29secs
RIDES:
2004 Infiniti G35 APS TT with built motor and fully built transmission. 520rwhp and 550ft trq.
2006 BMW M5 VT2-650 SC 570rwhp and 400trq.
2008 GMC Yukon Denali
ACG is offline   Reply With Quote
Old 31st July 2012, 20:23   #10
Stormster
Garage: M5
Had it three times, it was actuators each time even though twice the stealers were convinced it wasn;t until I made them replace them!
Stormster is offline   Reply With Quote
Increased Emissions, DSC Malfunction, Check Engine smidley E60 M5 and E61 M5 Touring Discussion 31 16th October 2012 23:05
DSC Malfunction & Increased Emissions ktlocklear E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 2 9th May 2012 03:45
Increased Emissions Error: What's it mean?! pnguyen E60 M5 and E61 M5 Touring Discussion 14 7th March 2012 19:45
Increased Emissions error and DSC Malfunction.... NateO E60 M5 and E61 M5 Touring Discussion 1 1st July 2011 00:37
Increased Emissions Error TampaLBOs E60 M5 and E61 M5 Touring Discussion 24 29th December 2008 14:05
