HELP!!!DSC malfunction increased emissions error - Page 2 - BMW M5 Forum and M6 Forums
Like Tree1Likes
Old 31st July 2012, 20:29   #11
BADBOY'S M5
BADBOY'S M5's Avatar
Garage: E60 ///M5 Silverstone II
Thanks, going to the stealer tomorrow, will see what they say and then tell them about the actuators...
E60 BMW ///M5 |Silverstone II on Black Full Leather-Suede Anthracite Alcantara roofliner
|Matt Black Grills|Blk-Carbon Fiber Badges|RPI Ram Air Scoops|Block off Plates|High Performance BMC Filters|Charcoal Filters Removed|RPi ST Pulley Kit |LED plate lights|Interior LED conversion|CODED|Tints 35%|Smoked tail lights|12mm H&R Spacers|H&R lowering Springs|Eurocharged|Sprint-Booster V2|BLK Side Skirt Diffuser's| Gloss Blk Roof wrap|
___________________________
2006 E60 BMW ///M5 Current
2001 E46 BMW 330ci /Mpkg-current daily/winter car
2000 BMW E39 540i Modded-retired
2008 Nissan Pathfinder LE-retired
2005 Jeep Grand Cherokee LTD HEMI-retired
1998 Infiniti QX4
1997 Jeep Grand Cherokee LTD
1990 BMW E34 535i Racing Dynamics Modded-retired
1987 Cutlass 442-retired
BADBOY'S M5 is offline   Reply With Quote
Old 2nd August 2012, 00:02   #12
BADBOY'S M5
Update
Dropped the beats off at 8AM, showed the SA the snap shots of the errors codes, he went and saw the increased emmisions error himself.
Called at 1 PM, car was full of codes since purchase date so they erased all, tech went for drive, no codes came on, second call was at 5:15PM, no codes still, car will need to stay over night. I told the tech about the Throttle acuator and he said yes, they think its that but need the code to come back.
will post when they find the issue.
Old 2nd August 2012, 15:11   #13
BADBOY'S M5
update,
Dealer called, no faults came back, battery under stress, charged and updated. take the car home and monitor,
they said it was the battery that probably triggered all the codes.
going to pick it up.
Old 2nd August 2012, 16:37   #14
evilb
evilb's Avatar
Garage: 2006 M5 Silver Gray
My money is on it not being the battery. I had a similar problem and it was the throttle actuator, bank 2, just as others described. Warranty covered it, but the parts were on back order. Hopefully the stocking issues on the parts has been resolved by now.
If the problem happens again, just hook a volt meter to your battery with the car running and monitor the voltage. If it dips into the 12's or goes over 14.2ish in spikes, could be your alternator. You'll also most likely throw high voltage codes if that's the case -- and these can be seen with an AutoLogic.
Good luck.
Brad
2006 E60 BMW M5 | Silver Gray | RPI GTS Exhaust | RPI Scoops | H&R Springs | AG M310 20x8.5/20x10 - Textured Black | Macht Schnell 20MM/3MM Spacers | ACS Spoiler | Gloss Black Kidney Grilles | Gloss Black Side Gills | Gloss Black M5 Emblem | OEM LCI Taillights (Euro) | Mironics V6 Cables | Euro Overlays | WeissLicht LED Angel Eyes V2 | WeissLicht LED Sidemarkers | WeissLicht LED License Plate Housings | Black BMW Roundels | Carbon 35% Window Tint | Many, many, many coats of 1Z Polish + Glanz
evilb is offline   Reply With Quote
Old 2nd August 2012, 16:45   #15
BADBOY'S M5
agreed, everyone was right about the throttle Actuator, they even see the fault in the history of codes, BUT, after clearing the code, and trying to get it to show up again, thats where the problem is it didnt come back, they know its that and gave me my $2395.52 estimate with tax and labour and said when it comes on again, bring it back and we'll change the part.
for now they charged the battery and did my battery part recall and charged me $199.00 for there troubles..
Old 28th August 2012, 20:04   #16
BADBOY'S M5
ok, so after a month of no errors, the error finally came back (increased Emission’s),
took it to the dealer, they said it’s the same issue I came in for before and will need to replace it. They called my aftermarket warranty comp and they said, yes, customer has the Secure Guard Plus warranty but unfortunately it doesn’t cover this part. Throttle Actuator part # 13627834494, total parts and labor would be about $2486 with our lovely tax. My cousin is a salesman there so they said ok, we can do it for you for $2079.00 with the taxes, I called a few other Indy shops, they were more than that, so no brainer I just gave the go ahead to BMW, You would have hoped that paying almost $6000 for an aftermarket warranty would come in handy.
A local indy shop told me to keep the part and there is a guy who rebuilds them in the UK. is that true?
They Gave me a 2013 X3 loaner and said come back tomorrow.fficeffice" />
Old 29th August 2012, 16:39   #17
acs
Garage: BMW M5 space grey
Need some help!!!
acs is offline   Reply With Quote
Old 29th August 2012, 16:40   #18
acs
above is a link to the problem i had
Old 29th August 2012, 22:30   #19
dlopez
Garage: BMW M5 E60 Black
Check the capacity of your fuel tank, under 15 litres, hard accelaration over 7000rpm triggers the same error - take my word for it. Fuel shifts to the back wall of your tank and for instant no fuel, only air and bang, everything lights up. This is the first posting I need to share. Test this before thinking this DTC and all the other errors have anything to do with either the idle control devices or throttle bodies.
dlopez is offline   Reply With Quote
Old 29th August 2012, 22:35   #20
Fuddy
Fuddy's Avatar
Garage: Silverstone II M5
If you were a bit handy with tools, it's not a hard job to swap out an actuator could've saved yourself tons of money
you can also get the actuator for $780 us
Fuddy is online now   Reply With Quote
The Following User Says Thank You to Fuddy For This Useful Post:
f1lmmaker (4th December 2012)
Increased Emissions, DSC Malfunction, Check Engine smidley E60 M5 and E61 M5 Touring Discussion 31 16th October 2012 23:05
DSC Malfunction & Increased Emissions ktlocklear E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 2 9th May 2012 03:45
Increased Emissions Error: What's it mean?! pnguyen E60 M5 and E61 M5 Touring Discussion 14 7th March 2012 19:45
Increased Emissions error and DSC Malfunction.... NateO E60 M5 and E61 M5 Touring Discussion 1 1st July 2011 00:37
Increased Emissions Error TampaLBOs E60 M5 and E61 M5 Touring Discussion 24 29th December 2008 14:05
