complete system failure help!!! - BMW M5 Forum and M6 Forums
Old 30th July 2012, 23:33   #1
phengm3
Garage: 06 M5, silver
Exclamation complete system failure help!!!
Help and avice needed. I have an 06 w 60k miles. The car was workimg fine. I installed the factory ipod kit myself. I worked fine w idrive w/o having the dealer reflash anything. It was a simple plug and play. About a week ago, when i was driving, the dash lights and the screen flicker on and off from time to time. Then different malfunctions signs come up. (Transmission failure, abs failure, steering failure). But then they disappear and my steering wheel feels like its been locked. Has anyone experienced this and what did you do. Thanks in advance.
phengm3 is offline   Reply With Quote
Old 30th July 2012, 23:50   #2
cartek
Garage: M5 Black Saphire metallic
how long ago did you install it? if you ask me it doesnt really seem related. seems morel like a loose batter connection or bad battery/alternator?? but i could be wrong.
cartek is offline   Reply With Quote
Old 30th July 2012, 23:53   #3
t.cov
Garage: 2006 M5 SSII, black interior, aluminum trim, fully loaded
my 06 has about 57K and a similar thing happened a while ago. Things just locked for a day or so. If I recall I think it turned out to be a battery issue. Check ans see if your battery has been replaced in the past.
Mods:
-sprint booster: installed/removed/installed/removed
-RPI scoops, filters, block off plates
-Evosport pulley
-CF removed
t.cov is offline   Reply With Quote
Old 30th July 2012, 23:58   #4
phengm3
Thanks for the quick response guys but I installed the kit a month ago n since I barely drive the car. I just took it out a couple weeks ago n noticed the issue. I did get the recall notice for the battery terminal. Could that be possibly related.
Old 31st July 2012, 00:24   #5
cartek
If the cable is loose, yes it could be.
Check the battery connections if they are all solid then id look into the battery itself or the alt.
But I'd be betting on battery.
Old 31st July 2012, 01:31   #6
spyderbret
Garage: 2008 M5 Indy Red Manual
+1
spyderbret is online now   Reply With Quote
Old 31st July 2012, 04:00   #7
phengm3
So I checked out the battery. There's no production date on it. I also tested it and has 12.4 volts
Old 31st July 2012, 15:18   #8
///TheIcon
Garage: 2008 M5 White
It is probably the alternator. I hade the same issue, and that was the culprit. Luckily mine was covered under CPO.
///TheIcon is offline   Reply With Quote
Old 3rd August 2012, 23:43   #9
phengm3
Stealer said its the alternator and they want 1400 which I think is crazy because the part is only 515. I'm now looking for an INDY shop that can do the work. I just think 900 in labor is crazy.
1503 E39 M5's left in the UK! Complete breakdown of MOT Pass/failure of all M5's in the UK Zow1 E39 M5 and E52 Z8 Discussion 9 12th May 2012 13:17
Complete BRAKE failure! Jetpilot718 E39 M5 and E52 Z8 Discussion 35 13th December 2010 02:05
Complete Power Failure epm E60 M5 and E61 M5 Touring Discussion 7 20th September 2007 00:58
COMPLETE WATER PUMP FAILURE oto60 E39 M5 and E52 Z8 Discussion 7 13th October 2005 02:49
E39 M5 2001 Complete Engine Failure! benragan E39 M5 and E52 Z8 Discussion 18 12th October 2005 23:26
