24th July 2012, 09:47
#3
Super Moderator
First post conclusion is incorrect..."racing" has nothing to do with it...
The 'nitrogen fill' you get at tire stores is NO BETTER than 94%... Unless you are using bottled, technical pure certified moisture free nitrogen, you will not see any of the MARGINAL benefits, The n2 membrane concentrator has a 94% upper limit
Biggest single issue? Moisture. Use air, with a drier on the line and you're fine. For track use, many have a n2 bottle for topping off shocks, so adding a lower press reg makes sense..
.I see green valve stems and laugh, especially on a minivan!
