Interior & license plate LED light install instructions and pics - BMW M5 Forum and M6 Forums
Like Tree8Likes
  • 2 Post By Wulffza
  • 2 Post By Wulffza
  • 2 Post By Wulffza
  • 2 Post By Wulffza
Old 9th July 2012, 04:04   #1
Wulffza
Wulffza's Avatar
Garage: 2011 E90 335i M-Sport 6MT AW/Saddle
Spent most of the afternoon replacing my interior bulbs with LEDs from Trinity Autosport. There is a 17PC bulb set only which covers all interior lights including glovebox and door cap puddle lamps. This one is $99. I also got the license plate bulb replacements for $25. Oh, you also have BMC air filters? Great, throw those in too.
There are other packages that include full housings which would make the install quicker, but I didn't need them to be any brighter and just wanted to rid the interior of the old yellow light that did not tie in with the instruments or headlights.
Earlier this year I replaced the corona ring bulbs with 10W LEDs from Trinity as well. I believe there is a 12W option now ->10W Angel eye update
I placed the order on Friday morning online, got a call around noon to confirm my order and shipping method and Saturday at noon they were here, cross country, nice. Great customer service from Trinity.
See before and after below. I need a better camera..pics were taken with same camera on same setting, similar light in closed garage.
I will post separately below detailed installation instructions and pictures.
Interior & license plate LED light install instructions and pics-dashboard-before.jpg
Interior & license plate LED light install instructions and pics-dashboard-after.jpg
Interior & license plate LED light install instructions and pics-driver-side-before.jpg
Interior & license plate LED light install instructions and pics-driver-side-after.jpg
Interior & license plate LED light install instructions and pics-footwell-2-before-.jpg
Interior & license plate LED light install instructions and pics-footwell-2-after-.jpg
Interior & license plate LED light install instructions and pics-backseat-before-2.jpg
Interior & license plate LED light install instructions and pics-backseat-after.jpg
Interior & license plate LED light install instructions and pics-p1090149.jpg
2011 BMW E90 335i M-Sport 6MT Alpine white - saddle brown
2005 Toyota 4Runner V6 Sport Ed 4WD Silver - charcoal
Gone but not forgotten
2008 BMW M5 6MT Space gray - black (RIP 10/2012)
2004 BMW 545i steptronic ZSP Titanium gray - gray
2003 BMW Z4 2.5i 5sp ZSP ZPP - Sterling gray - black
Wulffza is offline   Reply With Quote
The Following User Says Thank You to Wulffza For This Useful Post:
Hasan Shaikh (9th July 2012)
Old 9th July 2012, 04:11   #2
Wulffza
Wulffza's Avatar
Installation
The bulbs do not come with any instructions and while it may seem like the simplest job in the world (insert how many accountants does it take to change 17 light bulbs joke here), when you are not familiar with where all the clasps and pins lie you just don't want to take a screwdriver to your pride and joy and stuff something up. I couldn't find a comprehensive install post or video and looking up parts on realoem.com and getbmwparts.com didn't really help in figuring out how the housings were installed.
So, grab a beverage, grab the phone and grab the screwdrivers, lets do this. I am not going to say how long it took me, but with instructions and confidence it would take me less than 30mins to do it again. I only broke two plastic thingies and they can be replaced cheaply so all in all, great result and I learned some things about how the car is put together!
You'll need: Somewhere with light (with may mean sunscreen too); medium size flathead screw driver, medium size Phillips screwdriver, narrow pliers. A plastic trim toolset is a nice to have instead of screwdrivers..
Watch your fingers, those old bulbs are hot, turn them off before working on them!
In the first pic there are 15 bulbs, 2 were missing, the separate package is the license plate bulb.
Door cap puddle lamps (pic 2 and 3):
1. Insert tool on the rearward side of the lens and twist. Pull down that edge and it slides out.
2. Jiggle the bulb out
3. Replace with LED bulb. Ensure the contact points are making contact. This can be very frustrating as I will get to later, but the contact points on the replacements are not the same as the OEMs and you sometimes need to move them around until it works
4. Test operation before refitting the light.
5. Repeat other 3 doors
Visor mirror lights (pic 4 and 5)
1. Insert tool on the windshield side and twist to pop it out
2. Remove and replace bulb, ensuring that contact points have a snug fit on the new bulb. Bend as necessary
3. Refit
Footwell and glovebox (pics 6-8)
1. Insert tool in recessed grooves of lens and twist out.
2. There is a metal heat shield covering the bulbs of these. It slides out towards the wiring, not the other way..
3. Replace the bulb
4. The glovebox doesn't have any slack in the wiring so it may be easier to disconnect the housing from the harness and work with it separately. Use pliers and carefully disconnect the plug, its snug.
5. Hey look, the fuse box sits behind the panel the glovebox. And there's a nice cubby to stash some stuff there too if you don’t have a multidisc CD player, like guns?
-Continued
Old 9th July 2012, 04:14   #3
Wulffza
Wulffza's Avatar
Overhead lights (pics 9-14)
These are a beast because when you remove the bulb fittings, 3 each (center light and 2 maps) then remove the bulb from the fitting and install the new one, the new bulb will not slide back in the housing, the white ring on the bulb fitting is too thick. So:
1. Remove the light panels by insert tool and twisting on the rear edge of both
2. Disconnect the wiring from the housing as your arms will get tired working with the thing hanging out the roof
3. Remove the individual light bulbs by twisting the black caps and pulling them out the back panel of the housing, which also services as a circuit board for the bulbs.
4. Remove the clear lenses from the front of the housings, using a small narrow flathead tool. There are some groves that are self explanatory for popping off the lens.
5. Remove the old bulbs from the black caps. Keep one together as a tester for sanity.
6. Twist the 2 wire contact points lying flush with the white cap so that they stand proud and to the sides of the white cap. As a tester, don't do this and insert the bulb into the black cap. You will see that the bulb contact points do not meet the black cap contact points. This is fuster cluck of note, specifically in this housing due to the reinstall implications mentioned in the intro. So what you are trying to do is ensure that it makes contact when you re-seat it.
7. Feed the new bulb from the front of the housing in to meet the black cap at the back of the house. You won't have much leverage on the bulb as it’s a narrow fitting and you will need a good grasp of it as it takes some force to attach reseat it with the black cap. Line up the black cap with where it needs to slide into the circuit board before you mate the two as it gives you more room for re-seating them.
8. Once attached, twist the black cap into place, reconnect the wiring to the housing and test.
9. Did it work? Yes? GREAT, repeat for the other 2 bulbs and complete the other housing. No? Repeat steps 6 and 7 a gazillion times and by sheer act of the little baby Jesus the light will come on. Some may have had less trouble with this. I did only find one other post that had some pics explaining this issue for the overhead lights. If the contacts on the bulb were thinner and it slid right back into the black cap there would be no problem. The issue appears to be that the contact wires on the bulb are too thick and get pushed out the way instead of seating into the cap contact points. These bulbs are a very snug fit compared to the OEM, it may scare you that the sit flush with the map light housing in some places, but LEDs don't give off much heat.., I hope..
10. So the lights all work now, reinstall the front lens, refit the housing to the headliner
-continued
Old 9th July 2012, 04:17   #4
Wulffza
Wulffza's Avatar
License plate lights (pics 15-17)
So you're getting the jist of how these housings pop out? Not so fast, the exterior housing fit differently.
1. Remove the license plate and its backing plate. Its easier if you do this. It takes 30 seconds.
2. Insert a flathead tool into the hole in the lens cover for leverage and pull it to the right. This will create some play between fitting and the trunk lid and you should be able to pull the housing towards you starting on the left side just a little, then the right and it drops out to the right. DO NOT INSERT A TOOL BETWEEN THE LENS AND THE PAINTWORK as would seem intuitive from the last 17 bulbs..
3. Remove the and replace the bulb
4. Refit.
Bask in the fact that you did something yourself.
Old 9th July 2012, 04:55   #5
SR71
SR71's Avatar
Garage: 328i Montego Blue Metallic
Any error codes yet? They look great.
The e60 M5:
"It is an idiosyncratic, hyperactive, twitchy, pent up bull in a china shop. It takes attention to drive it, whether you are trying to drive smoothly or hard."
When the E60 came out, it blew away supercars..... When the F10 comes out, it will be middle of the pack even in a straight line.
-T Bone
SR71 is offline   Reply With Quote
The Following User Says Thank You to SR71 For This Useful Post:
Wulffza (9th July 2012)
Old 9th July 2012, 05:00   #6
Wulffza
Wulffza's Avatar
No. Don't see why there would be, unless a bulb blows, in which case I expect one.
Old 9th July 2012, 05:14   #7
Alan740
Garage: 2008 BMW M5
You can get error codes because of differences in resistance. That is how the obc determine bulb faults. If you have a resistance out of spec you get a warning. Good replacement bulbs are matched or have built in resistors etc to avoid faults. Cheap ones don't. As I understand it, Trinity's bulbs are error free.
This is such a problem on older BMWs you had to use silver based bulbs, not brass colored. They were called "euro" bulbs. Always a pain it the *** on my old 525i.
2008 BMW M5 6-speed
Silverstone II/Indianapolis Red/Aluminum
Enhanced Audio, 20-way seats with Active Backrest, iPod, Comfort Access, Shades
RPI Scoops, Plates, BMC Filters, GTS Sec. 1, 2, and 3
H&R Sport / TMS 12.5mm / Dinan Front Roll Control and Rear Sway Bar
IND Gloss Black Grills
Alan740 is offline   Reply With Quote
The Following User Says Thank You to Alan740 For This Useful Post:
Old 9th July 2012, 05:22   #8
ACG
ACG's Avatar
Garage: 2004 Infiniti G35 Twin Turbo, 2006 RPI/ESS VT2-650 M5
Sales Feedback: (10)
The pins not lining up with the connectors is a known problem, I posted a few pics on how I bent mine in an L shape to make them work last year, even sent Joe pics to show what I had to do to get them to connect.
Papa Smurf 2006 Supercharged VT2+ BMW M5
Performance:SC VT2-650 / Alpha N Tune / Sprint Booster V2 / RPI GTS Exhaust / RPI SV1 Oil Cooler / RPI Jet Hot Coated Headers
Handling: KW V3 Coilovers / Dinan Rear Sway Bar / Dinan Front Roll Control / Tires F 255/35/19 R 285/30/19 / 12mm Rogue Engineering Spacers / 19x9/19x10.5, 3 Pc Rennen R8 Concave Wheels (Matte black face with chromed lip)
Exterior:Vorsteiner Rep Hood / Gloss Black Roof Wrap / Matte Azure Blue Metallic Car Wrap / Smoked LED Side Markers, Limo Tint / Custom headlights with Orion V2 rings / Custom Blacked Out LCI Tail lights and Miranda Bruce V 6 Cables / Hartge Rep Urethane Front Lip / AC Schnitzer Roof Spoiler / Matte Black Kidneys Grills / Gloss Black Side Gills / Gloss Black Rear M5 Emblem / Black/White CF Hood &Trunk Roundel / Rear Bumper Mesh, M5 Puddle lights, QTP 2.5 Electric Cutouts
Interior:White LED Interior Lighting / Black/White CF Steering Wheel Roundel / Aluminium Steering Wheel Trim / Handbrake Handle/Pedals /Hardwired Valentine 1, P3Cars BMW E60 Vent Integrated Digital Interface
Programming: Mirror Fold-up / Window Roll-up / Sunroof Closure / Auto S5 at Start up / Euro Launch Control / iDrive Acceptance Delete
Braking: RDSports 6 Piston F 380/35mm and 4 Piston R 380/32mm Big Brake Kit
In Process V3:
Low Compression Engine Builld:
Mahle Custom Pistons
Carrillo Rods
Howerton Engineering - Aquamist HFS-3 Injection System
Custom Fuel System
Custom Alpha N Tune
Custom SC Kit Color Scheme
Future V4 plan coming soon........
Wants:JME Rear Diffuser
MAHA Dyno 570rwhp 400trq 60-130mph 8.29secs
RIDES:
2004 Infiniti G35 APS TT with built motor and fully built transmission. 520rwhp and 550ft trq.
2006 BMW M5 VT2-650 SC 570rwhp and 400trq.
2008 GMC Yukon Denali
ACG is offline   Reply With Quote
Old 9th July 2012, 07:08   #9
IndyRedBeast
IndyRedBeast's Avatar
Garage: E60 Indy Red M5 & E65 Titanium Silver 750i
LED interior for our cars is a must! looks so good at night
Performance:
Meisterscahft Section 1 Pipes
Meisterschaft Section 2 X-Pipe
Eisenmann-Race Section 3 Cans
Eurocharged ECU Tune
Evosport Power Pulley
BC-Racing Coilovers
Stoptech SS Brake Lines
Stoptech Street Brake Pads
ATE Super Blue Brake Fluid
M Sprint Booster V2
Simota CF CAI
RPi Scoops
Wheels/Tires:
20" Varrstoen ES1
Hankook V12 Evo
TMS Spacers
Rolled Fenders
Gloss Black Calipers
M Caliper Decals
Exterior:
Hamann Painted Splitter
Custom Black Extension Lip
Hartge Painted Diffuser
Custom Rear Bumper Grille
Gloss Black Sideskirt Extebsions
Gloss Black OEM Grilles
Gloss Black Vinyl Roof
Gloss Black M5 Emblem
Gloss Black/White BMW Roundels
Interior:
Alcantara E-brake/SMG Boots
Alcantara/Perforated Leather Wheel
Alcantara Steering Wheel Trim
Alcantara Full Headliner
CF 3M Di-Noc Trim Wrap
CF Steering Emblem
CF Door Pins
Lighting:
Custom Painted Headlights
Orion V2's/Euro Reflectors
OEM LCI Euro Taillights
V6.1 Bruce Cables
Full LED Interior Lights
LED Clear Side Makers
LED License Plate Lights
LED Reverse Lights
Solaris Invisi-Bulbs
6000k HID Bulbs
Currently 465whp Dynojet
_______________
Mikelll M5
IndyRedBeast is offline   Reply With Quote
Old 9th July 2012, 08:02   #10
Hasan Shaikh
Hasan Shaikh's Avatar
Garage: E63 ///M6 - White
Awesome DIY mate!
Thanks for shring.
Hasan Shaikh is offline   Reply With Quote
LED XENON License Plate Light Installation Instructions for E60 M5 V10PWR E60 M5 and E61 M5 Touring Discussion 17 24th June 2012 20:35
LED License Plate Bulbs - Before & After Pics roller1150 E39 M5 and E52 Z8 Discussion 21 13th February 2012 19:41
LED Tail light and license plate issues tyroone E39 M5 and E52 Z8 Discussion 5 11th November 2011 20:32
Umitza V4 LED Turn Signal/Side Light/License Light Install/Review xr4tic E39 M5 and E52 Z8 Discussion 22 28th September 2009 06:53
LED license plate light for 2006 M5? kyle3481 E60 M5 and E61 M5 Touring Discussion 10 4th July 2008 21:02
