O ring seals leaking on oil cooler - BMW M5 Forum and M6 Forums
Old 1st July 2012, 17:58   #1
mikeg
mikeg's Avatar
Garage: M5 silver grey
Does anyone know the proper procedure to get to the oil cooler. I can see the seepage at the cooler but it looks like a pain to get to it.
Any advice.
MZILLA
mikeg is offline   Reply With Quote
Old 1st July 2012, 20:59   #2
Fuddy
Fuddy's Avatar
Garage: Silverstone II M5
here u go
http://fjcaba.com/images/oilcooler.pdf
Fuddy is offline   Reply With Quote
Old 2nd July 2012, 04:52   #3
Voisin
Voisin's Avatar
Garage: 2007 M6 Coupe
It is more likely to be the connection between the pipes and flange at the top of the cooler. I and many others havethe same problem, weld it up or buy the RPI SV1 cooler which corrects the design flaw.
Sent from my iPad using Tapatalk HD
Voisin is offline   Reply With Quote
Old 3rd July 2012, 10:03   #4
Hasan Shaikh
Hasan Shaikh's Avatar
Garage: E63 ///M6 - White
+ 1
If you decide to replace the oil cooler, get the RPI.
Hasan Shaikh is online now   Reply With Quote
Power steering fluid leaking on Nurburg Ring!! jamiesecker E60 M5 and E61 M5 Touring Discussion 2 21st April 2011 12:29
Diff seals done now leaking again UXB52 E39 M5 and E52 Z8 Discussion 1 15th February 2011 18:54
Feedback on leaking differential seals & rear driveshaft boot? bruceholmes E39 M5 and E52 Z8 Discussion 7 5th August 2006 17:00
Leaking differential seals anyone? c4m5 E39 M5 and E52 Z8 Discussion 0 8th August 2001 22:18
Oil leaking from blown seals after Dinan upgrade tsupler E34 M5 Discussion 7 27th September 2000 03:45
