Which is better? Lower or bigger wheels - BMW M5 Forum and M6 Forums
Like Tree4Likes
Old 30th June 2012, 20:50   #1
winnm5
Garage: 2006 M5 Black
Just got an '06 M5.
If I can do one thing... Which has a better look and ride: Lower with new springs or get 20 inch wheels?
winnm5 is offline   Reply With Quote
Old 30th June 2012, 21:00   #2
FORMnFUNCTION
FORMnFUNCTION's Avatar
Garage: 06 E60 M5 *Sterling Silver Metallic*
I would def. go with a smaller wheel then 20s, 19s are perfect, and lower it slightly..
You get more performance from a lighter wheel in general, and it would ride better as well.
Cheaper price for tires, more selections of tire.
List goes on and on.
FORMnFUNCTION is offline   Reply With Quote
Old 30th June 2012, 21:07   #3
LeeDan00
LeeDan00's Avatar
Garage: 2007 E60 ///M5 6 Speed
it really depends on what you're trying to achieve. 20's are definitely more popular for aesthetics, but if you're tracking your car then 19's probably for a lighter wheel. i have 20's on my car and wouldn't go with anything bigger or smaller; it fits our cars very well. or you can get 20's and lower it like many others.
LeeDan00 is offline   Reply With Quote
Old 30th June 2012, 21:27   #4
winnm5
Should I worry about tires rubbing if I go with 20" wheels and lower at the same time?
Old 30th June 2012, 21:43   #5
FORMnFUNCTION
You need to get proper offset, tire size, wheels width.
There are many things to consider when you talk about fitment.
Old 7th July 2012, 03:04   #6
sidemarker
Garage: 2008 BMW M5 Alpine White
dropping the car will always make it look better. even if you go with bigger wheels you have to drop otherwise you will look like a 4x4
sidemarker is offline   Reply With Quote
Old 7th July 2012, 03:05   #7
sidemarker
dropping the car will also add performance in handling.
Old 7th July 2012, 07:58   #8
ACG
ACG's Avatar
Garage: 2004 Infiniti G35 Twin Turbo, 2006 RPI/ESS VT2-650 M5
Sales Feedback: (10)
Depends on what you are trying to achieve. I stuck with 19" myself and dropped the car on coilovers. The only reason I kept to the stock wheel size is because the smaller diameter tires can increase acceleration by reducing the drivetrain's effective gear ratio, which allows your engine to exert more torque per revolution, yeah I am all about speed
If it looks you want then go with the larger size wheel.
2006 Supercharged VT2+ BMW M5
Performance:SC VT2-650 / Alpha N Tune / Sprint Booster V2 / RPI GTS Exhaust / RPI SV1 Oil Cooler / RPI Jet Hot Coated Headers
Handling: KW V3 Coilovers / Dinan Rear Sway Bar / Dinan Front Roll Control / Tires F 255/35/19 R 285/30/19 / 12mm Rogue Engineering Spacers / 19x9/19x10.5, 3 Pc Rennen R8 Concave Wheels (Matte black face with chromed lip)
Exterior:Vorsteiner Rep Hood / Gloss Black Roof Wrap / Matte Azure Blue Metallic Car Wrap / Smoked LED Side Markers, Limo Tint / Custom headlights with Orion V2 rings / Custom Blacked Out LCI Tail lights and Miranda Bruce V 6 Cables / Hartge Rep Urethane Front Lip / AC Schnitzer Roof Spoiler / Matte Black Kidneys Grills / Gloss Black Side Gills / Gloss Black Rear M5 Emblem / Black/White CF Hood &Trunk Roundel / Rear Bumper Mesh
Interior:White LED Interior Lighting / Black/White CF Steering Wheel Roundel / Aluminium Steering Wheel Trim / Handbrake Handle/Pedals /Hardwired Valentine 1
Programming: Mirror Fold-up / Window Roll-up / Sunroof Closure / Auto S5 at Start up / Euro Launch Control / iDrive Acceptance Delete
Braking: RDSports 6 Piston F 380/35mm and 4 Piston R 380/32mm Big Brake Kit
In Process:
Low Compression Engine Builld:
Mahle Custom Pistons
Carrillo Rods
Custom Fuel System
Custom Alpha N Tune
Custom SC Kit Color Scheme
Wants:JME Rear Diffuser
MAHA Dyno 570rwhp 400trq 60-130mph 8.29secs
RIDES:
2004 Infiniti G35 APS TT with built motor and fully built transmission. 520rwhp and 550ft trq.
2006 BMW M5 VT2-650 SC 570rwhp and 400trq.
2008 GMC Yukon Denali
ACG is offline   Reply With Quote
Old 7th July 2012, 19:43   #9
dhirm5
dhirm5's Avatar
Garage: 2009 M5 - Carbon Black
Just so it's clear - smaller wheels doesn't necessarily mean smaller overall rolling diameter. I have 295/30/20 in back, which is very close to the stock 285/35/19 in overall rolling diameter. In fact, 285/30/20 would actually have been slightly shorter overall.
For most people, remaining as close as possible to the stock rolling diameter is the way to go - maintains the speedometer's calibration, and stock driving characteristics. Going taller or shorter should only be done if you know exactly what you're doing.
RPI Scoops
RPI Block Off Plates
BMC Filters
[del]Charcoal Filter[/del]
Eurocharged Tune
Eibach Pro-kit Springs
Forgestar CF10 Textured Black - 20x11 R, 20x9 F
Michelin Pilot Super Sport, 295/30R20 R, 255/35R20 F
RPI Section 3 Exhaust
3M Black Brushed Steel interior trim wrap
35% tint sides and back
Pro Clip Console iPhone Mount
dhirm5 is offline   Reply With Quote
Old 7th July 2012, 20:41   #10
unfoundhorsepower
unfoundhorsepower's Avatar
Garage: 2006 M5-E60, Interlagos blue,all options + 2004 Z4 Red loaded,2004 M3 Luguna Seca Blue, 2009 X5 35d Saphire Black.
ride??? 19's the best way to go....I like the handling of the 19's better than the 20's. it is much easier to read the 19" sidewall than the 20" sidewall.....and better with road imperfections. Lowering is NOT just the way to derive better handling, one must "tune" the entire suspension to gain a substantial improvement in handling...Study before "Jumping in"....
See you all at the:
Mmmmm meet...in Massachusetts, It was good to see all of you !!
unfoundhorsepower is offline   Reply With Quote
E39 Want to buy: Lower front bumper mesh grill and... right hand side (USA drivers) Lower wheel well Hdhntr23 Parts / Other For Sale or Wanted 5 2nd November 2009 02:19
Need your opinion on new wheels/should I lower the car?? mpwr6 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 7 27th September 2009 00:17
Video: the bigger the speed ,the bigger the mess Gustav Off Topic Forum 4 5th May 2007 01:33
Do you want bigger wheels? Fart E39 M5 and E52 Z8 Discussion 0 19th January 2005 20:40
Anyone Lower there M5 on Stock Wheels?? Tony Mack E39 M5 and E52 Z8 Discussion 5 4th January 2003 23:03
