Is reinstalling stock/OEM exhaust possible? - BMW M5 Forum and M6 Forums
Old 30th June 2012, 11:06   #1
nhs156
Garage: Black 2010 BMW M5
Odd question, I know. But I'm pretty sure that I'll want to reinstall the OEM exhaust once I sell the car (Tubi Rumore goes on next Friday - cans only). Have read that the new one need to be "cut off" which sounds worrying. So can it go back on? And when it does, I suppose it won't look "stock" under the car - as it'll presumably be clamped in place, correct?
nhs156 is offline   Reply With Quote
Old 30th June 2012, 13:24   #2
Hasan Shaikh
Hasan Shaikh's Avatar
Garage: E63 ///M6 - White
You will have to cut your OEM exhaust. The Tubi will come with clamps.
You can use the same clamps to put your OEM mufflers back.
Hasan Shaikh is offline   Reply With Quote
Old 30th June 2012, 20:14   #3
petesamprs
petesamprs's Avatar
Garage: 08 M5
Correct. OEM exhaust is cut off just before the muffler using a sawzall or preferably something more precise.
New exhaust has slightly larger diameter pipe, which fits over the remaining factory exhaust (overlaps by a few inches) and gets clamped.
If you need replace OEM exhaust, unclamp, slide off aftermarket muffler, put OEM back where it used to go and use the clamp to connect. I've heard that you should use some form of exhaust tape before clamping to ensure there are no leaks, since when you put the OEM back on there won't by any overlap.
Recently sold:
2008 ///M5 | Space Gray | Black perforated leather | Aluminum | SMG
M167 wheels, Rogue Engineering exhaust (Section 3), Eibach springs, 12mm front/rear spacers, matte black grill/side gills/trunk badge, painted calipers (black) with ///M decal, body color reflector, 50% 3M tint, V1 hardwire
petesamprs is offline   Reply With Quote
Old 1st July 2012, 08:00   #4
Hasan Shaikh
That is not the case with Tubi, I think.
At least not the one that I have. The Tubi mufflers have the same diameter as the OEM exhaust. It comes with a long clamp, almost 4 inches long to hold it together. There will be no overlap.
The Tubi X Pipe does have a wider diameter about 2 inches in length where it fits over the OEM exhaust.
Old 1st July 2012, 12:33   #5
nhs156
OK, thanks guys. Very helpful. So I can reinstall the OEM but will never look "stock" again. Got it.
Old 1st July 2012, 12:35   #6
Hasan Shaikh
The clamps will not be vsisble unless you go under the car.
E60 For Sale: 09 M5 e60 stock oem exhaust muffler New pzondas Cars For Sale or Wanted 3 2nd January 2012 18:17
E39 Want to buy: M5 OEM / stock exhaust jwingstrom Cars For Sale or Wanted 3 28th October 2011 04:25
E63 M6 For Sale: selling stock OEM m6 exhaust 2008 only has 1200 miles on it MMC Parts / Other For Sale or Wanted 0 23rd October 2009 21:55
Stock OEM exhaust tip question marksv4 E28 M5 Discussion 2 8th October 2007 02:14
any stock oem m5 v ss exhaust mod m5 vids eljockvis E39 M5 and E52 Z8 Discussion 8 27th April 2007 17:34
