DIY: Euro MDM for less throttle bog / intervention! NCSExpert Required - BMW M5 Forum and M6 Forums
Like Tree4Likes
Old 28th June 2012, 09:03   #1
Vodyk
Vodyk's Avatar
Garage: E60 M5
Exclamation Euro MDM for less throttle bog / intervention! NCSExpert Required
Saw this pop up on the forums and figured I would try a euro VO into NCS and see what would happen. Here is what I got:
With NCSExpert change in DSC:
UEBERSTEUERN_MUE_0_2
wert_01 to
wert_00
UEBERSTEUERN_MUE_1_2
wert_02 to
wert_00
UNTERSTEUERSCHWELLE_2
wert_00 to
wert_01
MDYNAMIC_MODE_USA
aktiv to
nicht_aktiv
A few other options changed for me however I am pretty sure they are for non 08+ w/o TPMS. I also wonder if only "MDYNAMIC_MODE_USA" needs to be changed or if the other values are required for thresholds.
I have been driving on this and feel less bogging of the throttle. Look forward to hearing what other people think.
Keep in mind this is a E60 only change. If you want this for your M6 or M3 perhaps start with only turning off "MDYNAMIC_MODE_USA" first or find a euro VO to compare with.
Hope everyone finds this useful.
Bellow are all my trace files and NCS Dummy of DSC to try to understand that different chassis settings.
Euro
Code:
BAUART_MK60
	e60
M_GETRIEBE
	sequentiell
GEARMOMENTREGLER_MAX_HA_2
	wert_00
GEARMOMENTREGLER_MIN_HA_2
	wert_00
	wert_02
LENKWINKELKENNLINIE_2
	wert_00
DELTA_PSI_BETA_LIMITKORR2
	wert_00
MDYNAMIC_MODE_USA
	nicht_aktiv
	wert_00
	wert_00
RPA
	aktiv
AIR_SUSP
	nicht_aktiv
DDS_SW_CAN
	aktiv
PRE_MSR
	nicht_aktiv
LCL
	nicht_aktiv
DSC_OFF
	nicht_aktiv
	wert_01
US
Code:
BAUART_MK60
	e60
M_GETRIEBE
	sequentiell
	wert_00
	wert_00
	wert_02
	wert_00
	wert_01
MDYNAMIC_MODE_USA
	aktiv
	wert_01
	wert_02
RPA
	nicht_aktiv
AIR_SUSP
	nicht_aktiv
DDS_SW_CAN
	aktiv
PRE_MSR
	nicht_aktiv
LCL
	nicht_aktiv
DSC_OFF
	nicht_aktiv
	wert_00
DSC Options
Code:
Generated with NCS Dummy version 0.5.0.5 — copyright İ 2011 revtor software
Output       : Module Functions
Chassis      : E60 (E60,E61,E63,E64)
Module       : MK60_M5.C15
ID         FUNCTION KEYWORD            FUNCTION KEYWORD TRANSLATION                       OPTIONS
    ID         PARAMETER KEYWORD           PARAMETER KEYWORD TRANSLATION
ŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
0F2D       BAUART_MK60                 MODEL VARIANT MK60 ANTILOCK BRAKING SYSTEM (ABS)
    000A       e60                         e60 (5 series)                                 !DSC8_CI_19+M5,DSC8_CI_19+E60+M5
    0022       e63                         e63 (6 series coupé)                           (!DSC8_CI_19+!M5,DSC8_CI_19+E63+M6)+!COMPETITION
    0020       e61                         e61 (5 series touring)                         DSC8_CI_19+E61+M5
    0024       e64                         e64 (6 series convertible)                     DSC8_CI_19+(E64+M6,!(M5,M6))
    07B6       e63tue        E63+M6+COMPETITION
0F2E       M_GETRIEBE                  BMW M TRANSMISSION
    0164       handschaltung               manual transmission                            M_GMBH_HANDSCH
    02CC       sequentiell        !M_GMBH_HANDSCH
1789       LCL
    0008       nicht_aktiv                 not active                                     !(E61+M5)
    0007       aktiv                       active                                         E61+M5
1266       RPA                         TIRE PUNCTURE MONITORING SYSTEM
    0008       nicht_aktiv                 not active                                     DIRECT_RDC
    0007       aktiv                       active                                         !DIRECT_RDC
157C       PRE_MSR
    0007       aktiv                       active                                         E61+M5,M_GMBH_HANDSCH
    0008       nicht_aktiv                 not active                                     !(E61+M5,M_GMBH_HANDSCH)
1207       UEBERSTEUERN_MUE_0_2
    00D6       wert_00                     value 00                                       !DSC8_CI_19+!(S85B50+US),DSC8_CI_19+((E60,E63)+!(US+!COMPETITION)+S85B50,!S85B50)
    0026       wert_01                     value 01                                       !DSC8_CI_19+S85B50+US,DSC8_CI_19+(E60+M5,E63+M6)+US+!COMPETITION
    001C       wert_02                     value 02                                       DSC8_CI_19+E64+M6+!US
    001D       wert_03                     value 03                                       DSC8_CI_19+E64+M6+US
    001B       wert_04                     value 04
    0027       wert_05                     value 05                                       DSC8_CI_19+E61+M5+!US
    0028       wert_06                     value 06                                       DSC8_CI_19+E61+M5+US
1208       UEBERSTEUERN_MUE_1_2
    00D6       wert_00                     value 00                                       !DSC8_CI_19+!(M5+US)+!M6,DSC8_CI_19+((E64,E60)+!US+S85B50,!S85B50)
    0026       wert_01                     value 01                                       !DSC8_CI_19+M6+!US,DSC8_CI_19+E63+M6+!(US+!COMPETITION)
    001C       wert_02                     value 02                                       !DSC8_CI_19+M5+US,DSC8_CI_19+E60+M5+US
    001D       wert_03                     value 03                                       !DSC8_CI_19+M6+US,DSC8_CI_19+E63+M6+US+!COMPETITION
    001B       wert_04                     value 04                                       DSC8_CI_19+E64+M6+US
    00F7       wert_07                     value 07                                       DSC8_CI_19+E61+M5+!US
1C7E       UNTERSTEUERSCHWELLE_2
    00D6       wert_00                     value 00                                       !COMPETITION
    0026       wert_01                     value 01                                       COMPETITION
1112       GEARMOMENTREGLER_MIN_HA_2
    00D6       wert_00                     value 00                                       !(E61+M5)+!M6
    0026       wert_01                     value 01                                       M6+!COMPETITION
    001C       wert_02                     value 02                                       E61+M5
    001D       wert_03                     value 03                                       M6+COMPETITION
1111       GEARMOMENTREGLER_MAX_HA_2
    00D6       wert_00                     value 00                                       !DSC8_CI_19+!M6,DSC8_CI_19+E60+M5
    0026       wert_01                     value 01                                       (!DSC8_CI_19+M6,DSC8_CI_19+E63+!M5)+!COMPETITION
    001C       wert_02                     value 02                                       DSC8_CI_19+E61+M5
    001D       wert_03                     value 03                                       DSC8_CI_19+E64+!M5
    001B       wert_04                     value 04                                       E63+!M5+COMPETITION
157A       AIR_SUSP
1206       MDYNAMIC_MODE_USA
    0008       nicht_aktiv                 not active                                     !(S85B50+US+!COMPETITION)
    0007       aktiv                       active                                         S85B50+US+!COMPETITION
157B       DDS_SW_CAN
    0008       nicht_aktiv                 not active                                     !PU06
    0007       aktiv                       active                                         PU06
1205       DELTA_PSI_BETA_LIMITKORR2
    00D6       wert_00                     value 00                                       !(S85B50+US+!COMPETITION)
    0026       wert_01                     value 01                                       S85B50+US+!COMPETITION
1914       DSC_OFF
    0007       aktiv                       active                                         M_GMBH_HANDSCH+(PU07,DSC_OFF)
    0008       nicht_aktiv                 not active                                     !(M_GMBH_HANDSCH+(PU07,DSC_OFF))
1113       LENKWINKELKENNLINIE_2       STEERING ANGLE CHARACTERISTIC CURVE 2
    00D6       wert_00                     value 00                                       !M6
Credit: BMWCoding.com members figured this out with m3's
BMW Coding Forum
Vodyk is offline   Reply With Quote
The Following 2 Users Say Thank You to Vodyk For This Useful Post:
Hasan Shaikh (28th June 2012), khyber (12th July 2012)
Old 28th June 2012, 14:47   #2
dhirm5
dhirm5's Avatar
Garage: 2009 M5 - Carbon Black
Nice! How did you decide to change the UEBERSTEUERN_MUE and UNTERSTEUERSCHWELLE_2 entries?
RPI Scoops
RPI Block Off Plates
BMC Filters
[del]Charcoal Filter[/del]
Eurocharged Tune
Eibach Pro-kit Springs
Forgestar CF10 Textured Black - 20x11 R, 20x9 F
Michelin Pilot Super Sport, 295/30R20 R, 255/35R20 F
RPI Section 3 Exhaust
3M Black Brushed Steel interior trim wrap
35% tint sides and back
Pro Clip Console iPhone Mount
dhirm5 is offline   Reply With Quote
Old 28th June 2012, 17:46   #3
Vodyk
Vodyk's Avatar
Garage: E60 M5
I didn't. I used a euro m5 vehicle order to see what it would set the DSC settings to. These are the differences. Most modules have the ability to change options, for region / option changes. If you tell a module a different VO NCS will set the correct values. ECU / SMG are static tunes with no option changing at face value unless you can decode and know what to change.
This is why most retrofits need coding. If you change one module you have to tell the others what the car now has so its can change its values to work with it.
Old 28th June 2012, 17:50   #4
dhirm5
dhirm5's Avatar
Figured - just wanted to confirm that. Thanks for this - I'll mess with this over the weekend.
Old 30th June 2012, 17:48   #5
Miguex
Garage: BMW X5M
Cool, I will try this too. I thought it works for M3 e9x only.
2010 BMW X5M: Stock + Custom ECU remap by ECUPROGRAM.ca
BMW Coding? Calgary, & Edmonton & Red Deer & Lethbridge area only. For Vancouver and Regina area, on request only.
" I am more terrified of a suburban mom on her cell phone with 3 kids in the back of the SUV, than an enthusiast who had undertaken specialized training, driving their pride and joy."
Miguex is online now   Reply With Quote
Old 1st July 2012, 02:33   #6
gt3m
gt3m's Avatar
Garage: Grey E60 M5
Thank you for yet another awesome find...will try it out.
2006 BMW M5 (DD)
2003 Porsche C4S (Project Car)
2008 BMW X5 (Family Vehicle)
2012 Toyota Prius (Wife's DD, Token Hybrid)
gt3m is online now   Reply With Quote
Old 1st July 2012, 16:50   #7
335xi
Garage: 2008 Black Sapphire M5
Charles, if u can figure out how to have S6 while in mdm that would be the shite.......
335xi is offline   Reply With Quote
Old 2nd July 2012, 07:06   #8
avlnch
avlnch's Avatar
Garage: 2010 Individual Frozen Grey M5
When I was taking a few laps in the M3 GTS at BMW's test track in Miramas, France I was very impressed with the way the car handled through all the different corners. It was clear that it's MDM mode was not preventing the car from doing anything besides help keep it under control. I'm sure that not very easy for the engineers to do. The M3 GTS (for those whom don't know) has revised MDM software that is specific to that car. The competition M3's have similar software (don't know if it's the same as GTS or not).
Makes me wonder exactly how much the MDM/DSC changes in the E60 after changing a few strings/values.
2010 BMW ///M5 INDIVIDUAL {Frozen Grey/Platinum/Platinum Alcantara/Piano Black Trim}
~Mods: DINAN Stage II Suspension, DINAN Exhaust, DINAN X-Pipe, DINAN 13% Pulley, DINAN Air Intake, DINAN C/F Front Strut Brace, DINAN Pedals,
RPI Scoops, OEM Charcoal Delete
~Mods: HRE 20" P41 [Black&MachinedFace], Matte C/F Grills, Matte C/F Side Gills, Matte Black M5 Badge, Matte Black Exhaust, Frozen Grey Front Reflectors, Matte Clear Side Markers
Other Vehicles: '12 MERC S63 AMG [WHITE], '11 MERC S65 AMG [BLUE]
Previous Vehicles: '09 MERC S65 AMG, '08 BMW M5, '08 MERC S63 AMG, '07 BMW Alpina B7, '06 RANGEROVER S/C
avlnch is offline   Reply With Quote
Old 9th July 2012, 21:20   #9
Vodyk
Vodyk's Avatar
Garage: E60 M5
I am surprised more people haven't jumped on this! Definitely a nice tweak and with so many people doing basic NCS stuff should be pretty simple.....
Old 9th July 2012, 23:57   #10
Miguex
Garage: BMW X5M
I did mine coded to Euro MDM but I havent tested it out yet.
Looking for GT1/DIS, NCSexpert, or AutoLogic hpy540 USA Midwest BMW M Forum 0 23rd October 2010 16:45
Bog, die....peake #90,91...help I am stranded HPizKing E39 M5 and E52 Z8 Discussion 14 13th July 2010 00:20
Euro-spec E36 M3 S50B30 Throttle Bodies PHakes E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 2 4th December 2009 01:14
Question re high speed bog. m5luver E39 M5 and E52 Z8 Discussion 8 25th March 2007 19:32
1997 Euro M3 Evo Throttle Bodies Michaelc Parts / Other For Sale or Wanted 0 28th March 2006 14:16
