Weird Sound... Metallic "Clinking" - BMW M5 Forum and M6 Forums
Old 26th June 2012, 19:54   #1
Cicada
Garage: 2002 M3, 2006 M5
So my car has been making a weird sound lately, and it's very slowly been getting a little bit louder/happening more often -- I hadn't noticed it/it wasnt doing it when I picked the car up almost a month ago. (06, 80k mi at the moment.)
Basically it makes a sort of high pitched "clinking" sound -- as best as i can describe it, kind of like tent poles or some light aluminum poles being placed/dropped on the ground -- it really only happens at very low speeds (<10mph) when either taking off or coming to a stop, at or below 10mph in 1st and sometimes second gear. sounds like it comes from somewhere underneath the car, maybe toward the middle/rear on the driver's side, because when i roll down the windows, my passengers said they couldn't hear it.
Any ideas?
I took a short video to try and capture the sound; you'll hear it at 0:04-0:08, 0:13 and 0:40.
+ YouTube Video
ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
Cicada is offline   Reply With Quote
Old 26th June 2012, 23:12   #2
joeywx
joeywx's Avatar
Garage: 2002 Titan Silver ///M5
'clink clink' sounds from a low speeds/taking off from a standstill tell me that it's your driveshaft unfortunately; could be isolated to your CV joint though. This won't affect drive-ability but if it drives you crazy whenever parking or taking off from a standstill- put aside some money for a new driveshaft (replacing with rebuilt one would be the better option than). I've had to trouble shoot this not only on my car but others as well.
If you are not convinced, have your mechanic put the car on a lift and go into 1st, reverse over and over and listen from the underneath. You will hear it from the driveshaft.
joeywx is offline   Reply With Quote
Old 26th June 2012, 23:59   #3
Fuddy
Fuddy's Avatar
Garage: Silverstone II M5
had this problem on my e39 m5
turned out to be the guibo
Fuddy is online now   Reply With Quote
Old 27th June 2012, 01:01   #4
unfoundhorsepower
unfoundhorsepower's Avatar
Garage: 2006 M5-E60, Interlagos blue,all options + 2004 Z4 Red loaded,2004 M3 Luguna Seca Blue, 2009 X5 35d Saphire Black.
Fuddy, I concure...sounds like the Guibo in EARLY stages.
See you all at the:
Mmmmm meet...in Massachusetts, It was good to see all of you !!
unfoundhorsepower is offline   Reply With Quote
Old 27th June 2012, 03:48   #5
Cicada
hope it's as small an issue as that; when the driveshaft went on my E46 M3, it was way more apparent than this (actually, the center support bearing went first, then i kept driving it like a moron, so it f'ed up the driveshaft, too -- it probably all started with the guibo, though, and all this happened around the same mileage, ~80k)
more video:
+ YouTube Video
Old 27th June 2012, 22:25   #6
Cicada
taking the mufflers to get chopped off this week, so i'll see if that's something i can check for while it's up there.
Old 1st July 2012, 08:23   #7
phengm3
Garage: 06 M5, silver
My 06 w/ 60k miles has the same issue. I never knew what it was. I just thought it was something minor. My question now is, how much will replacing it be at the dealer? Also, has anyone replaced it on their M5? Thanks in advance
phengm3 is offline   Reply With Quote
Old 1st July 2012, 11:50   #8
JonnybravoM3
JonnybravoM3's Avatar
Garage: 2008 E64 BMW M6 Cabrio
Can't hear it very well but in person does it sound something like this? Whats Happening Here - Car Making Strange Noises
Metallic clinking is, in my experience, related to vanos. Take her into the shop and let them check it. Maybe a simple bleeding of the vanos will do the job. Otherwise they may need to replace which is very expensive (can be in the region of US$3,000-4,000+ outside of warranty).
Stable:
2008 E64 BMW M6 Cabrio (Black Sapphire Metallic / Portland Brown)
- ECU / Intake/ Race Exhaust
2011 Ferrari 612 Scaglietti F1 HGTS (Grigio Silverstone / Rosso)
2012 Toyota FJ Cruiser (Military Blue / Black)
2013 Audi Q5 3.0 TFSI (Maya Brown / Cognac-Black)
JonnybravoM3 is online now   Reply With Quote
Old 2nd July 2012, 19:21   #9
Cicada
no; those definitely sound like valves. Mine is definitely coming from underneath the middle/rear of the car, and is a metallic, high pitched clinking sound like if someone dropped some metal/aluminum tent poles on the ground or something.
when i got my mufflers removed, i went to check but quickly realized I can't see anything unless the midpipes/section 3 are removed as well as the heat shielding.
I'm hoping to take it in to an indy this week or next week to see what it might be. it doesnt affect driveability or power at all, and is only audible/happens at very low (<10mph) speeds. it's progressively been happening more and getting slightly louder, so im avoiding driving the car right now as much as i can until i can take it in.
Old 2nd July 2012, 23:09   #10
Cool Cat
Garage: M5 V10
Hello Cicada,
Although maybe not exactly the same noise ( difficult to tell from the video ), when my M5 did a clicking noise that I could only hear at low speeds, it was a rivet from the clutch mechanism that had broken, and was moving around there. Have it checked, because it will slowly destroy your engine speed sensor and the flywheel...
Let us know.
Cool Cat is offline   Reply With Quote
Tags
clinking, clunking, metallic, sound, weird
Help with metallic clinking sound TimInNOVA E39 M5 and E52 Z8 Discussion 16 6th December 2011 20:48
m5 "reboots" sort of? Weird electrical issue. genna E39 M5 and E52 Z8 Discussion 12 11th February 2010 04:50
Weird "trouble" with new suspension Just Right E39 M5 and E52 Z8 Discussion 27 23rd August 2007 22:36
Rear "boom" sound when switching gears, smell, clutch VWY E39 M5 and E52 Z8 Discussion 5 3rd November 2006 22:30
Gearshift making a clinking sound/feel atomic80 E39 M5 and E52 Z8 Discussion 4 15th July 2003 10:20
