3rd July 2012, 17:14
#9
Originally Posted by filipe714
Z33x - I have an 08 (so it may be different for different model years) but there is a Y cable in your center console below the plastic compartment. This Y cable has two ends, one end attaches to your Iphone and the other end has two wires (hence the "Y" cable name), one that is a usb cable that connects to the front of the plastic compartment and another end that looks like your standard stereo input. When you connect all three, this synches your iphone with your car and you should be able to listen to music when you hit the "AUX" button. Hope that helps, if you have any more questions let me know.
Gotcha that makes sense, but when you say the front of the plastic compartment...do you mean inside of the center console? I did find a little hole there that can be closed with a little plastic sliding door...I wonder if the previous owner accidently pushed it inside of the console. May have to take it apart to check. Mind snapping a pic with your phonecam of what youre talking about? If you dont mind =). Thanks!
