Control arm bushings - Page 2 - BMW M5 Forum and M6 Forums
Like Tree4Likes
Old 27th June 2012, 02:56   #11
HansE60
HansE60's Avatar
Garage: 2006 E60 Black Sapphire
My SA tells me that Meyle makes high quality parts and he uses them on his own car. I went with them bases on his recommendation. I will let you know after installation.
HansE60 is offline   Reply With Quote
Old 3rd July 2012, 13:00   #12
nightkrawler
nightkrawler's Avatar
Garage: 03' M5
Sales Feedback: (3)
get a set of stock bushings and fill them with urethane.
nightkrawler is offline   Reply With Quote
Old 5th July 2012, 12:31   #13
georgefu
Garage: 2006 M5 black
Originally Posted by HansE60 View Post
Update:
I found out that the HD bushing that are made by Meyle are also available in a complete arm from FCP Groton. I have ordered these and I will have them installed in about a week or so. This will resolve the issue of them being inserted into the old arm with possible fit concerns.
I would love to step up to the monoball set up, but this is a cheaper option now and I am hoping it will serve its time for a bit. The monoball will have to wait until the budget is bigger. I hope to report back on the new set up once I try it out.
What is the part number?
georgefu is online now   Reply With Quote
Old 5th July 2012, 15:58   #14
jpasiczn
jpasiczn's Avatar
Garage: 2006 Alpine White M5
Could worn bushings be a cause for some slight vibration from the front end? I've had my tired balanced, rebalanced, then rebalanced again by a second shop and we still have some vibrations above 60 mph. Should these be the next thing to check out? 2006 with 44k miles
2006 Alpine White M5 (12/05 build). NAC Pinnacle platinum warranty
RPI scoops and block off plates/BMC filters/Borla exhaust/interior LED lighting
jpasiczn is offline   Reply With Quote
Old 5th July 2012, 18:06   #15
nonford
Garage: 2011 Lexus ISF
Absolutely, worn bushings would give you these fits, along with the ends of the control arms being bad. Also what may help is to road force your wheels/tires as sometimes out of round tires can make you go crazy too. I hate when the BMW's start having that dang vibration, sometimes its difficult to pinpoint and you have to take baby steps to find the cause. I have had my share of the bmw vibrations on other vehicles.
GOOD LUCK!
nonford is offline   Reply With Quote
Old 16th July 2012, 05:50   #16
Javacore99
Javacore99's Avatar
Garage: Space Grey E60M5 Sold.. E39M5 Silver Sold..
Update:
Feedback on Meyle HD bushings in new control arm?
snmpwalk –c public crumpy vtpVlanEditTable.. yadayada..
Javacore99 is offline   Reply With Quote
Old 16th July 2012, 07:25   #17
kendall993
Garage: 2006 M5 Black
Can someone please help me understand why the entire control arm must be replaced when the bushing wears out? I know they are pressed in but it seems a bit much to replace a perfectly good control arm ?
kendall993 is online now   Reply With Quote
Old 16th July 2012, 14:39   #18
B767capt
B767capt's Avatar
Garage: 2008 M5 SMG
There is a ball joint on the other end of the control arm. I have read and agree that the front bushing can be replaced the first time, but the second time around, the whole arm should be replaced as the ball joint more than likely will be bad by then. This is one reason why I think the monoballs are a bit much. It only solves half the problem. I'll be replacing the bushings myself when the time comes. Meyle sent me a free set.
B767capt is online now   Reply With Quote
Old 16th July 2012, 17:14   #19
VGM6
VGM6's Avatar
Garage: M6 Coupe Alpine White
I heard that one of the downsides to a mono ball kit is its exposure to water. They say for track use it's great but as long as you don't drive in the rain. Does anyone know if this is true. I heard two different race mechanics say this.
My Build Thread
2008 Alpine White M6-6MT
Cosmetics
Custom Painted White Side Reflectors
Custom Painted Black Grilles
Custom Painted Black Side Markers
Carbon Fiber BMW Roundels
VRS Carbon Fiber Front Lip
Weischlicht Angel Eyes V2
DCTMS Carbon Fibre Steering Wheel
Aluminum ///M Pedal Set
Performance
Akrapovic Evolution Exhaust
RDSport Pulley
ASR Intake
Dinan Throttle Bodies
UUC Short Shifter
Handling
RDSport Front + Rear Sway Bars
H&R Spacers (Front-12mm) (Rear 10mm)
H&R Springs
PSS (Front) 255/40/19 (100Y)
PSS (Rear) 295/35/19 (104Y)
In the Works
Stock Alcantara Headliner
Headers
4.1 Differential
RPI Oil Cooler
Republic Wraps Headlights (Umnitza V.4)
Republic Wraps Tail Lights
Dinan Carbon Fiber Front Strut Tower Brace
Dinan Carbon Fiber Rear Shock Tower Brace
Dinan Lower Control Arm Monoball Kit
Ground Control Camber/Castor Plates
VGM6 is offline   Reply With Quote
Old 16th July 2012, 17:37   #20
HansE60
HansE60's Avatar
My car has 90,000 kms (just over 55,000 miles) on it and I decided to replace the arms and bushings for two reasons the arm with the HD bushing in it costs $137.00 and the bushing alone is around $50.00. Add in the cost of installation and the fact that there are question marks regarding the use of the existing arms with replaced bushings, it was a no brainer.
I am waiting for my rear stoptech brakes to arrive and then take the car in to have the arms and the brakes done at one time. As soon as I do I will certainly report back on how the feel versus how they are now. I am looking forward to an increased feel and no more shaking under hard braking.
Control Arm Bushings GregT53 E34 M5 Discussion 7 30th December 2011 05:16
Anyone need control arm bushings?? russap5 E39 M5 and E52 Z8 Discussion 4 30th May 2009 00:26
For Sale Powerflex Control Arm & Thrust Arm Bushings E39 M5 Racerxjling Parts / Other For Sale or Wanted 2 20th May 2009 21:17
X5 Heavy Duty Thrust Arm/Upper Control Arm Bushings For Sale gmakishima Parts / Other For Sale or Wanted 2 24th May 2007 19:12
Control and Thrust Arm Bushings fiftyfive E39 M5 and E52 Z8 Discussion 5 28th February 2007 21:54
