16th June 2012, 13:19
#2
08 M5
These instructions should show you how to access the rear light from the trunk: DIY LCI taillight retrofit - 5 Series Forums
Once you get access, first try cleaning your bulb/socket contacts to see if it just a bad connection.
If that doesn't work, identify the part number for the bulb you need from realoem.com and buy it from getbmwparts.com (or your local dealer at likely a higher price)
The fast blink would be associated with a resistance issue, which hopefully should be solved once you change the bulb(s) that are out.
Please report back what your ultimate resolution is for the benefit of others.
thanks.
Recently sold:
2008 ///M5 | Space Gray | Black perforated leather | Aluminum | SMG
M167 wheels, Rogue Engineering exhaust (Section 3), Eibach springs, 12mm front/rear spacers, matte black grill/side gills/trunk badge, painted calipers (black) with ///M decal, body color reflector, 50% 3M tint, V1 hardwire
