Flywheel Damage - BMW M5 Forum and M6 Forums
Old 18th May 2012, 01:20   #1
donniesd
donniesd's Avatar
Garage: 06 E60 Silverstone Silver Metallic
Flywheel Damage
After getting erros and scanning for codes. I got error
P0339: Crankshaft Position Sensor A Circuit Intermittent
Took it to the dealer and they replaced the sensor under warranty. After they took it for a test drive, got the same error and told me they needed to tear down the tranny.
As you can see from the pics. We dealer and i are at a loss for what happened. They said started and clutch is in tact and so is everything else. Just the flywheel is damaged. It is not missing any teeth. They state nothing came out when they took it apart. Car has had not work on it in the month i have owned it.
Warranty wont cover it they say it was caused by "outside influenced"
NOM NOM NOM
BMWCCA Member# 461168
donniesd is offline   Reply With Quote
Old 18th May 2012, 01:46   #2
suprolla
suprolla's Avatar
Garage: Black Sapphire/Sepang
damn, that's BS. sorry to hear that. You just got the car too. Was it certified pre-owned? because I am thinking that the previous owner may have messed with it before trading in, because no way that flywheel would cause that much mess without you knowing/hearing it.
2007 Black Sapphire, Sepang interior, all options except ventilated seats.
Dinan Exhaust, Dinan Intake, H&R springs, StopTech BBK
20" BBS CH-R, 295/30/20 PSS on rear
V1 hardwired, BMWCCA Member# 444949
http://www.fuelly.com/sig-us/68994.png
suprolla is offline   Reply With Quote
Old 18th May 2012, 03:54   #3
VOVE
Garage: 06' M5 Black/Black
That really sucks. Mine was recently replaced. There's a better quality flywheel out there other than the OEM one.
VOVE is offline   Reply With Quote
Old 19th May 2012, 22:06   #4
donniesd
donniesd's Avatar
Yes,
But they are refusing to fix it.
Old 19th May 2012, 22:20   #5
pnguyen
pnguyen's Avatar
Garage: 2006 Black Sapphire Metallic M5
Thats weird that they took apart the tranny. From what I hear from my SA when there's a transmission issue with the SMG they just replace the entire tranny instead of messing with it. It could be a dealership to dealership policy though. Good luck with solving that problem!
2006 e60 ///M5 Black Sapphire Metallic | Work VS-XX | Hamann CF Front Splitter | RD Sport Springs | Magnaflow Section III | Rogue Engineering Spacers 15mm F/12mm R | 5W Angel Eyes | Black Grills | Black Fender Grills | RPi Ram Air Scoops | RPi Block Off Plates | BMC Filter | LCI Taillights w/ Bruce Cables
pnguyen is online now   Reply With Quote
Old 19th May 2012, 22:25   #6
donniesd
donniesd's Avatar
After they replaced the sensor. It was damaged again.
Old 27th May 2012, 08:43   #7
donniesd
donniesd's Avatar
6800 bucks later. flywheel is being replaced.
Old 27th May 2012, 21:22   #8
Cool Cat
Garage: M5 V10
Hello donniesd,
That damage to the flywheel is really minor. If it's still time, tell them not to change it, it is more cosmetic than anything. Unless one of its theeth is broken or strongly bent, there will be no problem in using it. Mine has more damage than this, and I've been saying not to replace it, 25.000km since then and not a problem.
By the way, have you seen/inspected your clutch mechanism? Generally such internal damage is caused by one of the mecanism's rivets to break and mess inside between the housing, the flywheel and the sensor.
Have a check, because if it's so, your insurance should cover it all...
Cheers
Cool Cat is offline   Reply With Quote
Old 28th May 2012, 06:09   #9
ldomek1
ldomek1's Avatar
Garage: 2008 M5 Silverstone
So they tell you that they have no clue what happened but it had to be outside influence that caused the issue ... that just doesn't make sense because there should be evidence of something if they claim that its outside influence.
Sorry to hear that they made you pay for the repair.
ldomek1 is online now   Reply With Quote
Old 4th June 2012, 01:34   #10
donniesd
donniesd's Avatar
Originally Posted by Cool Cat View Post
Hello donniesd,
Cheers
It has to be changed. After 5k rpm all the lights would come on and the sensor was damaged after each drive
Dealer said there was no rivets or anything else missing from the clutch or anything else. I dident notice, but i work in IT. not cars.
It would not be so bad if i just knew why it happened. But since the dealer and extended warranty want to deny fixing it i retained an attorney.
How NOT to install a flywheel. Tim's failed clutch/flywheel/RMS install. timmay77 E39 M5 and E52 Z8 Discussion 83 12th February 2012 18:02
Replacing clutch & flywheel. Don't seem to have flywheel bolts. Help guys! ///mfizzle E39 M5 and E52 Z8 Discussion 8 22nd August 2011 17:40
Flywheel toast, clutch only has 12k miles on it, reuse clutch with new flywheel? timmay77 E39 M5 and E52 Z8 Discussion 12 17th February 2011 02:56
Will I do any damage? Stack E39 M5 and E52 Z8 Discussion 9 17th December 2007 23:15
Dual Mass Flywheel .vs. Lightweight Flywheel--What Performance Differences Do You See Anita E39 M5 and E52 Z8 Discussion 33 15th February 2005 16:06
