Looking for FUEL TANK BREATHER VALVE DIY - BMW M5 Forum and M6 Forums
Old 17th May 2012, 03:05   #1
smidley
Garage: 2006 E60 M5, Silverstone II
Well, I got my car back from the dealership after they determined that I have a leak in my fuel tank breather valve. I've seen DIY threads for older M5's replacing this, and was hoping to find one for an E60 so I can attempt this myself. Has anyone ever attempted this before? Anyone know of a DIY thread for it? My searching was unsuccessful.
smidley is offline   Reply With Quote
Old 24th June 2012, 07:21   #2
mtradwan
mtradwan's Avatar
Garage: E60 M5 2006
whats the symptoms of a bad valve? bad idle? car stalls?
e60 2006 m5
e39 1999 540
sl60 AMG 1992 v12
1992 BMW 850i
mtradwan is offline   Reply With Quote
Old 24th June 2012, 14:01   #3
mdyaman
mdyaman's Avatar
Garage: Drives a ///M
I never heard of a breathe valve - where is that part located? Can you provide a realoem.com link?
Retired: 2006 e46 ///M3 Silver-Gray SMG (sold)
Current: 2008 e60 DINAN
///M5 Interlagos Blue SMG
DINAN 3.91 Differential, Stage 2 Suspension, Free-flow exhaust, Stage III Software, Front strut braces,
High Flow Air mass meters and intakes, 13% Underdrive pulley, RPI Scoops.
mdyaman is offline   Reply With Quote
Old 24th June 2012, 14:37   #4
Javacore99
Javacore99's Avatar
Garage: Space Grey E60M5 Sold.. E39M5 Silver Sold..
Fuel tank breather valve most likely close to throttle body since excess fumes from fuel tank go to throttle body to be burned off. I think that is function of valve and members with more knowledge can chime in.
PIA to remove on E39 and i would think you would get CEL for sure with leaky unit allowing air into tank.
RealOEM.com * BMW E60 M5 FUEL TANK BREATHER VALVE
No 1 on the diagram. BMW TIS should have more details on removal. At the minimum, the plenum has to come out.
snmpwalk –c public crumpy vtpVlanEditTable.. yadayada..
Javacore99 is offline   Reply With Quote
Old 24th June 2012, 21:31   #5
smidley
This is correct. It looks like the plenum has to come off and then you can access the breather valves. The symptoms aren't noticeable, but I'm guessing the fuel is running a little lean because of this. They determined that the leak was there by using smoke to detect it. It looks like there are two breather valves, and I'm not sure which one of mine actually has the leak.
I found a picture of the engine with the plenum removed, and I circled in red what I believe to be the breather valves. Is this right?
Old 25th June 2012, 00:48   #6
Javacore99
Javacore99's Avatar
^^^ that looks very similar to the part (left and right) but i would still get BMW TIS for confirmation. BMW TIS is under $30 or so for 24hrs or so and worth the money to get it done right. I guess i was surprised since the part in E39 was closer to the firewall and not as easy to get out and looks like this is more accessible once the plenum is out in E60. We are assuming of course that is the right part but you will know right away once the plenum is out and you have the part on hand.
Good luck and post pics and feedback if you do get it done as DIY.
Help! Stuck Replacing Fuel Tank Breather Valve ArgM8y E39 M5 and E52 Z8 Discussion 6 27th October 2012 20:59
Fuel tank breather valve rog2961 E39 M5 and E52 Z8 Discussion 25 15th June 2012 02:21
Fuel Tank Breather Valve additional parts? Georgia M5 E39 M5 and E52 Z8 Discussion 10 9th March 2012 01:37
Replacing Fuel Tank Breather Valve DIY (Peake code E8) J Irwan E39 M5 and E52 Z8 Discussion 43 18th November 2011 01:56
Replaced my fuel tank breather valve today Mike S. E39 M5 and E52 Z8 Discussion 11 9th March 2010 01:01
