DIY: Replacing throttle actuator motor with pics - Page 2 - BMW M5 Forum and M6 Forums
Like Tree4Likes
Old 1st July 2012, 20:11   #11
vantaam5
vantaam5's Avatar
Garage: 2003 M5 matte black
Originally Posted by Fuddy View Post
how do you initialize the actuator after install?
Post#1,sentence #3.
-rebuild in winter 2011/2012
"submarine edition",a bit boost and some M5 parts...
vantaam5 is offline   Reply With Quote
Old 1st July 2012, 21:08   #12
bayerischemotor
bayerischemotor's Avatar
Garage: M5 E60 Interlagos Blue
Originally Posted by Finnishfan View Post
Hmmm, that car looks strangely familiar...
Could it be yours buddy?
° Evolve Alpha N
° RPi ram air induction kit
° RPi ST pulley kit
° Supersprint exhaust and resonator
° Secondary cat delete
° (Evolve long tube headers coming!)
bayerischemotor is offline   Reply With Quote
Old 2nd July 2012, 02:15   #13
Fuddy
Fuddy's Avatar
Garage: Silverstone II M5
Originally Posted by vantaam5 View Post
Post#1,sentence #3.
mind posting the process in DIS?
Fuddy is offline   Reply With Quote
Old 19th August 2012, 20:12   #14
MPG_WhatIsThat?
MPG_WhatIsThat?'s Avatar
Garage: 2006 BMW M5 - Black Sapphire Metallic
My first post on the forum. Sorry it's long, but have a lot of detail some will find useful.
@FUDDY - It appears that you don't "have to" initialize the new part. It is more of good practice and fine tunning (anyone correct if I am wrong). I will elaborate more below.
First BMW I have owned (2006 M5 SMG). During my second week of ownership, I was out for lunch on a work day. On my way back to work I stopped to fill up (as it constantly needs to do). I started the car to leave the gas station and a whole bunch of errors appeared in the gauge cluster and in the iDrive screen (dsc malfunction, take off assistant is off, etc). The RPM was limited to 4.5 and the car accelerated extremely slow. I took it down a backroad to determine if it was capable of getting back to my work parking lot as well as tried turning it off and on again to see if the errors would clear. I ended up trying to make it back and omg is it slow. Stopped on an uphill due to traffic light. Once the light was green the Big Rig next to me took off up the hill leaving me in the dust! (It is seriously that slow, like a freight train trying to get moving). Had to pull over to let traffic get past, etc. Back at the parking lot I tried disconnecting the battery and nothing would clear the error. In short, the dealer diagnosed it as the Bank 2 Throttle Actuator has an "internal malfunction" (Note: this is USA driver side). Two more weeks go by and I finally have the car back at home and needing to replace the part (dealer quoted $2121 for parts and labor, cost was half part / half labor).
Removed Throttle actuator from the car and noticed it seemed to bind in one particular spot when rotated by hand. Took actuator apart and cleaned a clay-like material from the gears. Plucked the center gear from inside and rotated it to various positions until everything rotated smoothly. Thinking I may have solved the problem, I lightly pieced the car back together to see if the errors would clear. Bam, Errors gone! (keep reading). I then tightened everything back up and took it for a test drive. All was well. Test drove it the next day. All we well. Wife and I hopped in to go for groceries, started vehicle, and the errors were back. Problem was somehow better but now intermittent. I then ordered a new part from the dealer and ordered BMW software on eBay (DIS, TIS, SSS, etc). Part came in and to this day I am still waiting on software which is coming from out of the country.
Impatiently waiting, I decided to go ahead and install the new part to see what happens. My theory was, since it is the same part it should still run just fine without this "initializing step". I figure the "initialize" is just to fine tune, so that the computer knows the start and stop positions of the new piece. Since the new part is so similar, it should be pretty close without initializing. Put the part on and no errors after two test drives. During the test drives my tire pressure light came on. Indeed the passenger rear was 10lbs low. Added some air to the tire and it does it again. Took it to a tire shop and turns out the aluminum wheel is cracked! All the while, to and from the tire shop there weren't any errors. Car is now on jack stands while wheel is off for repair. Owned the car a whole month now, and for the majority of the time it has been out-of-service.
Note: I timed the new part install and it took about 3hrs 45min to have it all back together. (This is after having done it twice already.)
Below are some pictures of the actual part including internals and part number stickers:
MPG_WhatIsThat? is offline   Reply With Quote
The Following User Says Thank You to MPG_WhatIsThat? For This Useful Post:
Minimization (28th September 2012)
Old 19th August 2012, 21:11   #15
Fuddy
Fuddy's Avatar
I ended up finding the procedure in DIS and initilized the new part... it's been flawless since I put it in... I also found a place that supposedly fixed the messed up actuators for $80, haven't had time to send it in but it might be worth a shot to have a working spare in the garage
here's the link:
5WK49066 A2C53032056 A2C53046176 13627834494 | Autotek Electronics
The Following User Says Thank You to Fuddy For This Useful Post:
Old 19th August 2012, 21:16   #16
Fuddy
Fuddy's Avatar
oh and another to anyone out of warranty, south bay (ca) bmw has the cheapest price on the actuator @ $781.01
I got my local dealer to price match them, you can probably do the same
Throttle Actuator Tendencies? eve-slow E60 M5 and E61 M5 Touring Discussion 36 6th July 2012 00:02
fuel and throttle actuator kyu79 E60 M5 and E61 M5 Touring Discussion 3 5th March 2012 14:56
E39 Want to buy: Throttle actuator sproule905 Parts / Other For Sale or Wanted 2 18th January 2012 19:18
throttle actuator advice sdc77 E60 M5 and E61 M5 Touring Discussion 3 26th October 2011 00:43
E39 For Sale: FS: E39 M5 Throttle Actuator mmzcee Parts / Other For Sale or Wanted 1 16th May 2011 07:51
