Steering angle sensor DIY fix - it worked - Page 6 - BMW M5 Forum and M6 Forums
 37Likes
post #51 of 139 Old 10th October 2013, 05:38 AM
PurevilM5
PurevilM5's Avatar
Glad to hear it! mine has been malfunction free since I did it back on May 4th of this year.
Sent from AutoGuide.com Free App
Happily Burning The Unused Gas By Prius's and Smart Cars Worldwide
2006 BMW M5 20" Miro M6 Replicas, CROSS Coilovers, Meisterschaft GT Exhaust, PPO Block Off Plates, StealthShield Clear Bra
2006 Cadillac STS-V - Stock
2004 Chevrolet 3500 Duramax Dually - 22.5 Alcoa Big Rig Kit, Suncoast Stage 3 Transmission, Moonshine Ecu
2004 Nissan Sentra SE-R Spec V -
SOLD
2004 GMC Sierra - 20 & 22" Bonspeed Wheels, 4 Link Rear Suspension, Full Air Ride Technologies Suspension.
1993 Mazda FD RX-7 R1
PurevilM5 is offline
post #52 of 139 Old 4th November 2013, 03:37 AM
PilotAce
Almost succeeded - can't remove SZL
Hey guys,
I love the posts and the photos for your M5 SZL module/sensor repairs. Had this been available when I had my catastrophic electronics failure, it would've saved me $1200 about 3 years ago. I've started having Active Steering problems, and DSC warning lights come on peridically, and more frequently now, about every other day. REcently had an indy mech changed a battery due to other reasons, SMG pump replacement and brake vacuum pump replacement.
Found this and thought I'd give it a try, even though I have a 2005 545i. I got as far as taking all the screws out of the SMZ module, but couldn't lift the darn thing out of the column!! It looks slightly different from all the pics (of course), so I tried just about everything to wiggle that thing out, so I could open up the interior piece to see the goop to clean off...
Since it wouldn't lift out after all the screws came out (wondered if they glued the da*n thing in), I tried to open it up along the circular plastic piece, with all of its plastic tabs. I managed to break one (there's about 6 of them all the way around in the worst locations), and had to stop and put the whole thing back together again, as it's my DD and it was getting late.
What I noticed - it is very WET/oily inside the SMZ module. I HAVE to get inside to clean it, but I cannot figure out how to get the module lifted out!!
Anyone have more clues? I'll try again next weekend to see what I may have missed today - will certainly start earlier on a Saturday morning instead of a Sunday afternoon!
thanks in advance!
PilotAce is offline
post #53 of 139 Old 4th November 2013, 02:41 PM Thread Starter
g_force_alt
g_force_alt's Avatar
You must not have got all the clips or screws. Mine came apart quite easily. I'd be surprised if yours was glued.
BTW, a year and a half later, I'm still SZL error free. The cleaning was a fix for me.
g_force_alt is offline
post #54 of 139 Old 4th November 2013, 02:57 PM
PilotAce
Thanks - I'll keep looking. I even took out extra screws that weren't mentioned earlier. Now that I can get that airbag and steering wheel off, it should take much less time up front, so I can take photos along the way of where I'm running into problems.
When I try to get the top of the circular module to open up, there's this liquid stuff coming out of it like a yellowish oil... just gotta get the thing out to clean it...
I can hardly wait til Saturday morning, but hoping I don't royally screw it up!
This one isn't mind, but it looks exactly like this one I found on Ebay - seems like the seller had rotated the spring catch to the left side, as mine is horizontal across the top instead...
http://i.ebayimg.com/t/GENUINE-BMW-E...sJQ~~60_12.JPG
there's hope, because someone got this thing out!
PilotAce is offline
post #55 of 139 Old 16th December 2013, 04:51 PM
Delarado
I think I may be suffering with this fault too, but im not 100% sure.
My car will randomly and periodically just not accelerate at all, and the DSC light flashes at me while the car falls flat on its face. It's normally after ive been to fill up the car with fuel and pulled out of the station, but sometimes it does seem to occur just whenever; But I do seem to notice it more after I drive the car, shut it off for a while, and then pull out of wherever ive shut it off and try to get up to speed again.
One other thing its doing is not holding speed on the cruise control. This seems directly related to how fast im going / how much engine power is required.
For E.g I set cruise at 50mph and its fine forever.
I set cruise control to 75mph and its fine until i hit an uphill, then it shuts off
I set cruise control to 95mph (for testing) and it shuts off straight away.
not lights, no errors here, the cruise control just cancels itself completely. It seems that when the car needs to give strong throttle to maintain speed, the cruise cancels.
Any thoughts guys?
Delarado is offline
post #56 of 139 Old 19th April 2014, 09:40 PM
phizzak
Argh, I just put everything back together after cleaning... though my disc had no residue or gunk and looked new. Connected the battery, started the car up, the Engine and Brake lights were still on, turned left and right..... and the lights remained on. I decided to turn the engine off and let it sit for a minute before trying it again, but the lights remained on after the second attempt. I'll try it again in a little while longer, but it's not looking promising. Do you guys think that I will need to replace the module?
phizzak is offline
post #57 of 139 Old 10th June 2014, 01:24 AM
E39 GaGaN
E39 GaGaN's Avatar
just did this today and took me about 2 hours or so ..... since its freaking hot in Bay Area today ......
Used Nail Polish Remover with Q-tips ....... hopefully they light stays away for some time
GaGaN
07 MV Agusta F4 1000R
07 Interlagos Blue M5
E39 GaGaN is offline
post #58 of 139 Old 18th June 2014, 04:39 AM
absolutegtr
absolutegtr's Avatar
Hey guys. Just read through all 6 pages. Car in question is my 2008 550i m-sport. I have what seems to be a steering angle sensor problem
1) DSC light on
2) BRAKE light on
3) TPMS light on (this could be a serperate issue though)
4) start off assistance inactive
5) cruise control not working
BUT
All of the turn signals and high beam and adaptive lightning options still work just fine. So would this still be a steering sensor problem. I noticed that on a cold start there are no lights on the car. And i could throw it in drive or reverse and move forward and the lights stay off. BUT AS SOON as I turn the steering wheel...boom, all lights are on.
Does this sound like the steering angle sesor problem?
absolutegtr is offline
post #59 of 139 Old 18th June 2014, 10:09 AM
E39 GaGaN
E39 GaGaN's Avatar
Yes ... same issues were with my car ... except no tpms error ... just follow step by step directions nd ur error messages will clear ... good luck
GaGaN
post #60 of 139 Old 19th June 2014, 04:04 AM
phizzak
I cleaned everything and it kept coming back. It turned out to be the bank2 throttle actuator... i think it's about 2k+ to RR.
phizzak is offline
Currently Active Users Viewing This Thread: 8 (0 members and 8 guests)
2006 M5 Steering Angle Sensor Fix and...... KCB4 E60 M5 and E61 M5 Touring Discussion 12 12th September 2014 06:35 PM
Is this Steering Angle Sensor? Barry E60 M5 and E61 M5 Touring Discussion 23 13th October 2010 12:17 PM
DIY Steering angle sensor Viper966 E60 M5 and E61 M5 Touring Discussion 3 25th August 2010 05:07 PM
Steering Angle Sensor Fix for 2007? andrewsherman E60 M5 and E61 M5 Touring Discussion 4 29th August 2006 04:20 AM
No more LC after Steering Angle sensor fix...? Zapper E60 M5 and E61 M5 Touring Discussion 5 16th August 2006 04:51 AM
