Steering angle sensor DIY fix - it worked - Page 5 - BMW M5 Forum and M6 Forums
 37Likes
post #41 of 138 Old 14th June 2013, 12:48 PM
messex
messex's Avatar
Originally Posted by ShowMeM5 View Post
Best day ever! Did it again, step by step. No gunk on the disc(because I cleaned it last time), but there was a ton of gunk on the housing that connects to it. Q-tipped all of it out of there.....5 used during the process. Put everything back, connected battery, fired it up. Lights everywhere! Turned left, right.....still lit up. Turned engine off....sat for a minute ....fired it back up. Lights still on, backed out of garage turned on P500, and then off again and blammo! No more lights!!! Drove around the block(driving lamp/bulb decided to go out on me)and all is good. Rock on!
Cool! Once mine went off, it stayed off. Hope the same for you! Definitely better than taking to the dealership to replace a part that isn't broken.
Performance Mods
Eurocharged ECU Tune, Charcoal Filter Delete, RPI Ram Air Kit/Block Off Plates, RPI Oil Cooler, M Sprint Booster V2
Cosmetic Mods
H&R Lowering Springs, 20" ConceptOne Wheels, Blacked out Kidneys/Side Vents, 6W Angel Eyes
messex is offline
post #42 of 138 Old 15th June 2013, 07:49 PM
ShowMeM5
ShowMeM5 is offline
post #43 of 138 Old 17th July 2013, 04:18 PM
sirjaymill
Thank you so much
I did this DIY and wanted to say thans everyone that replied and added to this post. I saved over a $1000 with this. I'm not sure weather I should post more pictures, but took some while doing this to show the air bag release hole, was confused on it for a short bit, and others. Here is a link for the pic ( good for a little bit)
https://share.htc.com/fZnIfNoK6
"E60 kept throwing codes"
If anyone is using this thread I can post them here.
sirjaymill is offline
post #44 of 138 Old 17th July 2013, 05:17 PM
Clyde
Clyde's Avatar
A few more pictures would be helpful. Upload directly to the board, rather than hosting offsite
Clyde is online now
post #45 of 138 Old 17th July 2013, 05:53 PM
Mpowah
So I took my car in because it was showing the EDC malfunction light. Dealer ran the diagnostics and said I need to replace my Steering Angle Sensor. They wanted $1100 for parts and labor. I saw the DIY for cleaning the sensor before going with the dealer. I spent a saturday taking it apart and when i finally got to the disk and sensor they were SPOTLESS. and cleaned it up with some alcohol just to make sure. Put everything back together but I still have the EDC malfunction. Any ideas? Why would the dealer say I have a bad steering angle sensor. it looked perfectly fine.
Mpowah is offline
post #46 of 138 Old 17th July 2013, 08:20 PM
Clyde
Clyde's Avatar
Originally Posted by Mpowah View Post
...i finally got to the disk and sensor they were SPOTLESS. and cleaned it up with some alcohol just to make sure. Put everything back together but I still have the EDC malfunction. Any ideas? Why would the dealer say I have a bad steering angle sensor. it looked perfectly fine.
Cleaning the "disk" repairs one common steering angle failure, but like any electronic device there are many other ways it can fail.
Clyde is online now
post #47 of 138 Old 17th July 2013, 08:46 PM
sirjaymill
did you clean sensor and the disk? when I took my disk it looked clean till I held it at a angle. I tried dawn dish soap, but, had to use contact cleaner to get the crud off. one person said he had to do it twice. I also had dust keep trying to get into it while I was putting it together. I know it's a PITA, but, I'd try it again. Good luck,but, with the E60 it could be anything.
post #48 of 138 Old 17th July 2013, 09:06 PM
sirjaymill
What I misunderstood.
I thought that 1091 was the airbag hold, but the hole to get to the airbag spring is under the steering wheel imag1092. Also if you look at the picture of my disk, I have sparkle stuff, as well as, the crud on it, which, came off after I cleaned. And yes, I didn't take a picture of it clean because I wasn't sure it was going to work. Sorry.
post #49 of 138 Old 17th July 2013, 11:48 PM
maximus5403
For those of you that have to replace your SZL, here are the steps to code it using DIS:
Diagnosis-> 5 series -> E60/E61 -> Right Green Arrow -> Control unit Functions -> Function selection -> Service Functions -> Chassis -> Steering-angle sensor -> Adjustment, steering-angle sensor -> Test Schedule -> Right Green Arrow
You'll then be guided through the steering angle sensor calibration process via on-screen instructions.
You may also need to code using NCS Expert to get the steering adjustment to work.
maximus5403 is offline
post #50 of 138 Old 10th October 2013, 05:32 AM
m5rbk
WoooHooo, just did it tonight and so far so good. I was getting the malfunction DSC and Flat Tire Monitor and some other warning..it was happening each time I drove the car when I took the first turn..
I drove it around a bunch and cranked the wheel side to side, no warnings yet....
Thanks again to an amazing forum...
m5rbk is offline
Currently Active Users Viewing This Thread: 14 (0 members and 14 guests)
2006 M5 Steering Angle Sensor Fix and...... KCB4 E60 M5 and E61 M5 Touring Discussion 12 12th September 2014 06:35 PM
Is this Steering Angle Sensor? Barry E60 M5 and E61 M5 Touring Discussion 23 13th October 2010 12:17 PM
DIY Steering angle sensor Viper966 E60 M5 and E61 M5 Touring Discussion 3 25th August 2010 05:07 PM
Steering Angle Sensor Fix for 2007? andrewsherman E60 M5 and E61 M5 Touring Discussion 4 29th August 2006 04:20 AM
No more LC after Steering Angle sensor fix...? Zapper E60 M5 and E61 M5 Touring Discussion 5 16th August 2006 04:51 AM
