M5 e60 Vanos Solenoid valve changing HELP PLS - BMW M5 Forum and M6 Forums
post #1 of 7 Old 21st March 2012, 05:48 PM Thread Starter
Duschanio
hello,
I´m from Germany near Munich, my english is not so good i hope you can understand my english
I must change the Solenoid valve from my vanos ..
The first question i have is how can i cange this , i must demontage the Fan shroud .
After that in BMW TIS is written that i must demontage the Coolant hose radiator input ... but when i remove it , must be discharged cooling water???
How can i change the valves from obove or must i go under the car.
When some got pictures it was very helpfully
Duschanio is offline
post #2 of 7 Old 21st March 2012, 06:59 PM
douglas_ngo
douglas_ngo's Avatar
Which solenoid valves do you need to changes out (driver side or passenger side). You will need to disconnect the radiator hoses and fan shroud. You can replace the solenoid valves without having to remove the vanos unit itself but it is a much easier job if you do. If you leave the vanos unit in place, it can a pain to get to the two bolts that held the solenoid in place. The solenoid valves can be snug tight and will take a little force to pull them out.
douglas_ngo is online now
post #3 of 7 Old 21st March 2012, 09:01 PM Thread Starter
Duschanio
Hey i want to changr Both Sides
Remove the complete vanos ???? In BMW tis is weiteren only that i Must demontage the Fan and After that the hose Not more :/
post #4 of 7 Old 21st March 2012, 09:14 PM Thread Starter
Duschanio
post #5 of 7 Old 21st March 2012, 10:08 PM
B767capt
B767capt's Avatar
I would put a clean pail under the radiator drain and drain all that comes out. The level will then be low enough for you to remove the hoses on top without it all spilling. Every other oil change I just drain what come out of the radiator anyway and restore with new. The BMW coolant is cheap and it gets cycled that way.
B767capt is offline
post #6 of 7 Old 21st March 2012, 10:23 PM
douglas_ngo
Yes coolant will come out so you will need to get some coolant prior to doing this job. Depend on the hoses condition, now is the time to replace them if need be. I replaced all 4 hoses as a preventive maintenance. If you decided to replace the solenoids in place, you will need a flex extension. Also, don't forget to label the connecting plugs as you don't want to miss match them. One for the inlet and one for the outlet.
post #7 of 7 Old 23rd March 2012, 09:07 PM Thread Starter
Duschanio
hey
ok i changed both valves from the bank 2 (right side) .
i look to bank 1 (left side) and its more difficult there .. becouse i dont see the other 2 screws.
my questen is how i can come to the screws ... must i demontage Ribbed v-belt and the Adjusting pulley with lever to see more ??
pls help me ...
Vanos Solenoid Valve - Fault Code P0011 douglas_ngo E60 M5 and E61 M5 Touring Discussion 8 5th September 2015 07:39 PM
DIY instructions for VANOS Solenoid Valve? czarj66 E39 M5 and E52 Z8 Discussion 66 19th August 2014 05:16 PM
Vanos solenoid seals Dr. Vanos vs OEM replacement? blackwagon E39 M5 and E52 Z8 Discussion 18 24th January 2011 07:31 PM
throwing vanos solenoid codes on new solenoid pack Msentinel E39 M5 and E52 Z8 Discussion 0 16th June 2010 04:14 AM
Vanos Solenoid vs Complete Vanos Replacement SoCaLE39 E39 M5 and E52 Z8 Discussion 5 4th June 2008 09:42 PM
