Anyone have the part number on the smg hydraulic pump relay? - BMW M5 Forum and M6 Forums
 6Likes
post #1 of 23 Old 8th March 2012, 10:25 PM Thread Starter
deebom3
deebom3 is offline
post #2 of 23 Old 8th March 2012, 11:20 PM
B767capt
B767capt's Avatar
Yes there are 2 relays in the box you should change out. The smg hyd pump is 61366901469 and Tischers price is 10.94. Of course this one gets a lot of hard use. The other one is the smg transmission oil pump which moves transmission oil through the cooler. That one is salmon color and it's part number is 12631742690 for 6.94. Since I'm in the relay box anyway, I change both when I do spark plugs. I always buy 2 each so I have a spare in the garage. How many times have we read where someone is left walking and their car is flatbeded to the dealer just for the burned out relay. I think they should be changed often, they are cheap.
B767capt is offline
The Following 8 Users Say Thank You to B767capt For This Useful Post:
Clyde (12th March 2012), CSBM5 (26th September 2012), deebom3 (12th March 2012), gt3m (3rd April 2012), guess55 (24th April 2012), Miguex (27th April 2012), Phorte (24th July 2012), SRR (1st February 2015)
post #3 of 23 Old 9th March 2012, 03:00 AM
Infamous Q
Infamous Q's Avatar
When I get a E60 I will make sure this is the one of the first things I do!!!!
"Forgiveness is between them and God. It's my job to arrange the meeting" -John Creasy
Untouchable Q
2015 Imola Red/Black all options except Rear Entertainment and Night Vision
2008 Monaco Blue/Sepang(SOLD)
2002 Carbon Black/Black (SOLD)
Infamous Q is offline
post #4 of 23 Old 9th March 2012, 12:07 PM
B767capt
B767capt's Avatar
Agreed. One theory I read somewhere was if the relay starts to go bad, then maybe it's not supplying 100% power to the smg hyd pump and they too burn out. I don't know but for 10.00 I'm keeping it fresh.
B767capt is offline
post #5 of 23 Old 9th March 2012, 01:05 PM
Gavin S.
What all is entailed in changing these 2 parts. Is there a lot of proficiency needed, because I have very little but would love to do this.
Gavin S. is offline
post #6 of 23 Old 9th March 2012, 02:02 PM
B767capt
B767capt's Avatar
Very easy. Remove the micro filter on passenger side in the engine compartment. Now remove the bottom tray that the micro filter sat in. The L and R trays overlap in the middle and you have 1 plastic nut there to rotate 90 degrees. That one nut is under a plastic cover you must slide off. I think there are (4) 13mm plastic nut heads that rotate 90 degrees to get the tray out. Just like the one on the micro filter cover. One metal screw with a torx head in the front. Now you will see a relay box that takes a #5 allen wrench. Remove the 5 screws and near the firewall you will see a white plastic tab that you must slide to the unlocked position. Pull the cover off and you will now see the realys. The black one closest to the firewall is the smg hyd relay. There is a plastic ridge on top of the relay. Grab that with plyers and pull straight up. PAY ATTENTION to the orientation of the metal prongs on the relay when you pull it out. This way you know which way to align the new one when you push it in. You can't get down there to see it if you don't do this. Towards the fender is a salmon colored relay. That's the smg oil pump relay. That's it. Put everything back in reverse order.
B767capt is offline
The Following 3 Users Say Thank You to B767capt For This Useful Post:
deebom3 (12th March 2012), Gavin S. (9th March 2012), guess55 (24th April 2012)
post #7 of 23 Old 9th March 2012, 03:19 PM
Gavin S.
Gavin S. is offline
post #8 of 23 Old 12th March 2012, 08:30 PM Thread Starter
deebom3
deebom3 is offline
post #9 of 23 Old 3rd April 2012, 03:33 AM
PRM5
PRM5's Avatar
When I open the door the smg pump comes on goes off briefly and then comes back on (intermittently), will be changing these relays tomorrow.
PRM5 is offline
post #10 of 23 Old 3rd April 2012, 04:15 AM
gt3m
gt3m's Avatar
gt3m is online now
SMG Hydraulic Pump Failure? pacemkr E60 M5 and E61 M5 Touring Discussion 14 3rd March 2014 02:14 PM
SMG hydraulic pump and SAP sensor failures... recalls? Who_Dat E60 M5 and E61 M5 Touring Discussion 4 19th July 2013 02:28 PM
Where to buy a Hydraulic Pump for my M5? msinno E60 M5 and E61 M5 Touring Discussion 8 25th September 2010 09:17 AM
urgent help needed! fuel pump relay or pump itself?? jonnycowboy E39 M5 and E52 Z8 Discussion 14 1st October 2009 03:58 PM
Location of fuel pump relay? M5Micke E34 M5 Discussion 4 2nd October 2006 09:01 PM
