DIY: E60 M5 Master DIY Thread - Page 6 - BMW M5 Forum and M6 Forums
 42Likes
LinkBack Thread Tools Rating: Thread Rating: 5 votes, 5.00 average. Display Modes
post #51 of 85 Old 24th June 2013, 07:25 PM
SpeedFreek
SpeedFreek's Avatar
Huh?
Hey PeteS...
Don't know if you know, but there is a hyperlink on your post above that links to this:
Jabsco DIY Oil Change System w/Pump & 3.5 Gallon Bucket
It was visible when I wasn't logged in, but is gone now that I am logged in. Strange.
Could it be the mods (new m5board.com owners) hyperlinking paid-for ads to posts?
New spam?
Anyway, just thought you should know...
SF
2008 M5 Sepang Bronze/Sepang Bronze Full Merino Leather w/ Executive Package, SMG •H&R Lowering Kit
•CF Roundels F&R •12mm H&R Spacers all round •DINAN Stage I ECU •Blacked out side vents •20% shadow tint
•RaceMesh SS cross-weave lower grill •Beltronic STI Radar/Laser Detector •M Alloy pedals •Painted reflectors
•3M Clearbra •Just rolled 71,ooo km
Also...
2012 E92 M3 coupe track toy - Space Grey|Silver/Black Novillo|ZCP|ZPP|M-DCT|Michelin PSS, and...
•M Perf exhaust •M Perf alcantra steering wheel •M Perf CF splitters & spoiler •Full M Perf CF interior trim •Coded!
•M Perf aluminum pedals •BMW Perf Race Seats •Painted reflectors •M Perf gloss black kidney grill •CF side vents
•Black CF roundels F & R •15mm F 12mm R MachtSchnell spacers •RaceMesh SS cross-weave intake & diffuser grills
•UUC braided steel brake lines •H&R Sport Springs •M Perf E brake •iND custom painted plenum •APEX 75mm studs
Wife's bone stock 2006 X5 4.8is Silbergrau/Cream leather...and my winter ride!
RIP: 03 330cic US-spec / 98 735iA Euro-spec / 01 X5 4.4 Premium Pkg / 97 540iA Premium Pkg / 03 530iA M-Sport & AG Exec Pkg / 01 520i UK-spec
__________________________________________________ __________________________________________________ ______________________________________________
SpeedFreek is offline
post #52 of 85 Old 24th June 2013, 08:18 PM Thread Starter
petesamprs
petesamprs's Avatar
Yes, it must be a targeted hyperlink ad....pretty common to see that on forums. I don't have any control over that. I use adblock on Chrome so i don't see those ads regardless of whether or not i am logged in.
Recently sold:
2008 ///M5 | Space Gray | Black perforated leather | Aluminum | SMG
M167 wheels, Rogue Engineering exhaust (Section 3), Eibach springs, 12mm front/rear spacers, matte black grill/side gills/trunk badge, painted calipers (black) with ///M decal, body color reflector, 50% 3M tint, V1 hardwire
petesamprs is offline
post #53 of 85 Old 17th August 2013, 07:21 PM
Inferno
Inferno's Avatar
Originally Posted by petesamprs View Post
Kees was able to help out with the update.
Cleaned up formatting and added a few more DIYs
The important holes right now are in the regular maintenance schedule.
HAVE DIY:
- Air filter: Inspect every 15,000 miles, replace every 15,000-30,000
- Cabin air filter: Inspect every 15,000 miles, replace every 15,000-30,000
- Spark plugs: every 60,000 miles (stick with OEM)
DIY UPDATE/IMPROVEMENT NEEDED:
- Engine oil/filter: Every 7,500 miles (Castrol TWS Motorsport 10W-60)
- Fuel filter: every 60,000 miles
DIY MISSING:
- Brake fluid: Every 1-2 years
- Engine coolant: Every 2 years (50/50 mix of BMW anti-freeze + distilled water)
- Power steering fluid: every 30,000 miles (Pentosin CHF 11.S)
- Gearbox oil (SMG & 6MT): every 30,000 miles (MTF-LT-2 or Red Line MTL)
- Differential oil: every 30,000 miles (Castrol SAF-XJ or Red Line 75W-140)
- Valve adjustment: every 30,000-60,000 miles
If external sites have good DIYs that would apply for E60 M5s (even if written for E60s in general or even other models), let me know.
Do we still have to worry about valve adjustments on the E60? I did a search and all I found was this thread: http://www.m5board.com/vbulletin/e60...justments.html
According to that thread it's not applicable to the our cars so maybe it should be removed from the maintenance schedule to avoid confusion unless that's wrong.
I found a power steering flush DIY here: Power Steering Flush - 5Series.net - Forums
I haven't done it myself and it's not for a M5 so I can't say if it's accurate.
Inferno is offline
post #54 of 85 Old 18th August 2013, 07:30 PM
mdyaman
mdyaman's Avatar
I have not seen anyone here do valve adjustments for the e60 M5
Retired: 2006 e46 ///M3 Silver-Gray SMG (sold)
Current: 2008 e60 DINAN
///M5 Interlagos Blue SMG
DINAN 3.91 Differential, Stage 2 Suspension, Free-flow exhaust, Stage III Software, Front strut braces,
High Flow Air mass meters and intakes, 13% Underdrive pulley, RPI Scoops. 12.5mm TMS Spacers.
mdyaman is offline
post #55 of 85 Old 23rd August 2013, 06:17 PM Thread Starter
petesamprs
petesamprs's Avatar
Re: Valve adjustments, if the consensus is we don't need it, i'm happy to remove it to avoid confusion.
Will add power steering fluid flush
Added clutch adaption DIY from Inferno's other post.
Recently sold:
post #56 of 85 Old 2nd September 2013, 04:20 PM
z4coupe
z4coupe's Avatar
Started my own thread on this but maybe someone on this thread has some insight. Ok many thanks to all that have contributed to this DIY as I enjoyed this project but still need help. The last step in this process is "Connect the battery, start the car. After the dreaded yellow AWD, break, stability control lights come up, turn the wheels all the way to the left, then all the way to the right. The messages disappear". My problem is that the error messages do not immediately show until after driving the beast for a while after reconnecting the battery and this was the case after completing this project. Car ran great for 5 miles and then the same issue came back. Any insight? Hopefully so or my Indy will be getting the car Tuesday.
Exhaust:
Section 2....Tubi-Style X-pipe
Section 3....Tubi-Style
Lighting:
LED angel eyes
LED turn signals
LED license lamps
Coding:
Euro hazards
Mirrors fold up on lock
Windows up on lock
Extended pathway lighting
Brake force display
No foot on brake start
'I accept' warning deleted
Seat belt 'bing' deleted
True speed in BC
AE & side marker bulb check delete - no more strobing
Rest is stock!
z4coupe is offline
post #57 of 85 Old 13th December 2013, 04:57 AM
warmachne
warmachne is offline
post #58 of 85 Old 15th January 2014, 10:49 PM
racee78
racee78's Avatar
Is there a DIY somewhere for the crankcase ventilator by chance or has anyone done this that can give pointers?
racee78 is offline
post #59 of 85 Old 15th January 2014, 10:59 PM
jcolley
m5board.com Site Sponsors
jcolley's Avatar
Not sure what you're asking for, what are you trying to replace?
Sent from AutoGuide.com Free App
jcolley is offline
post #60 of 85 Old 15th January 2014, 11:12 PM
racee78
racee78's Avatar
The thing that is looking a bit grimy which is locate above the spark plug on the drivers side toward the back. We found it while changing the spark plugs.
racee78 is offline
Currently Active Users Viewing This Thread: 15 (0 members and 15 guests)
e60 M5 Spark Plug & Air Filter DIY w/ Pics (Good Resource for DIY-ers) mdyaman E60 M5 and E61 M5 Touring Discussion 71 28th December 2016 05:33 PM
Tristate DIY Thread furry USA Northeast Forum 48 29th October 2011 07:40 PM
Valentine One DIY Thread - Where is it? avlnch E60 M5 and E61 M5 Touring Discussion 1 13th January 2010 05:07 AM
Lost Thread for DIY LEDs JamesB E39 M5 and E52 Z8 Discussion 3 2nd April 2006 05:49 PM
