Vanos pump repair - Page 5 - BMW M5 Forum and M6 Forums
 4Likes
post #41 of 53 Old 18th April 2013, 08:29 PM
jcolley
m5board.com Site Sponsors
jcolley's Avatar
There is a code stored if VANOS pressure drops below the setpoint (not sure what that is), but if the car doesn't have that stored, you are probably ok.
The actual test procedure IAW with ISTA or DIS connects an external pressure gage to the VANOS system at the silver "T" banjo fitting just below the forward end of the intake plenums, aft of the fan cowl, where it branches off to either operating unit. The engine is run and the pressure is monitored using this external gage. I believe BMW currently uses a pressure transducer connected to an IMIB (Integrated Measurement Interface Box) attached to the ICOM diagnostic connector. But, this doesn't do anything special, I don't think, so you get the same value using a manual pressure gage with a range of 150bar. The whole point is just to be able to read the actual pressure instead of using the built in pressure sensor the car uses.
If this pressure is low, you have a few possible causes, but the actual fixes are limited to just two: the VANOS high pressure line (the one which had a recall for early vehicles) or the VANOS high pressure pump. It's hard to say what causes the pumps to fail for sure (no one has donated one for autopsy yet and I'm not keen on dissecting mine for the hell of it), but with all of the speculation of "swarf" contributing to VANOS solenoid failure, I'm sure running metal pieces through the equivalent of a five cylinder radial engine isn't good for it. It stands to reason these could be rebuilt somehow though.
However, if your only symptom is noise, I would recommend performing the VANOS system test in DIS or ISTA and then the ventilation (bleeding) procedure a couple of times and then reperform the VANOS performance test. The ventilation procedure takes about 18 minutes and makes some funky sounds as it goes through its paces, but some people see improvement after. The repair procedures in ISTA reference noise on startup after component replacement being normal until the system is fully bled.
Given that the system uses engine oil, it stands to reason that oil quality (i.e. age) may have an effect on system performance as well and that is mentioned in the VANOS solenoid test procedure discussion in ISTA. It implies that oil which is in poor condition can skew the performance test.
So, if you bleed the system and the solenoids current and stroke times come out in spec, I wouldn't worry too much about it.
The car is usually pretty good about recording what goes wrong, just not great about telling you it recorded anything.
jcolley is online now
post #42 of 53 Old 18th April 2013, 09:12 PM
MIGHTY5
MIGHTY5's Avatar
thanks for info jcolley. funny thing ive noticed the 06 sound rougher than later models even with less miles on the 06.
MIGHTY5 is offline
post #43 of 53 Old 18th April 2013, 09:25 PM
tbrown1985
tbrown1985 is offline
post #44 of 53 Old 18th April 2013, 09:27 PM
tbrown1985
this was the code present when my line ruptured and was replaced under the recall early on
post #45 of 53 Old 18th April 2013, 10:40 PM
MIGHTY5
MIGHTY5's Avatar
good info thanks.
MIGHTY5 is offline
post #46 of 53 Old 20th March 2015, 08:53 PM
purplecty
Is there a DIY for this? My buddy has an 07 M5 that needs this repair but he is trying to see where he can get the special tools needed for the repair. Any input would be greatly appreciated...
purplecty is offline
post #47 of 53 Old 30th March 2015, 05:09 AM
MNickle Biest
+1
MNickle Biest is offline
post #48 of 53 Old 30th March 2015, 02:34 PM
mattcon
This is the DIY for the rod bearings and replacement and tear down of the VANOS pump is covered, though I don't think the internal line is covered.
BMW E60 M5 Rod Bearings DIY
It could probably be added to the master DIY list as VANOS pump replacement.
mattcon is online now
The Following User Says Thank You to mattcon For This Useful Post:
MNickle Biest (31st March 2015)
post #49 of 53 Old 30th March 2015, 02:51 PM
anzafin
anzafin's Avatar
A different vanos oil pump question;
I have stored my original pump, which has 100.000km in it. It was removed and replaced along the rod bearing job, as a precaution (I have an early model car). The old pump was fully working. Should I try to sell it? You guys think I could get any bucks out of it?
- Antti -
Project Blog: BMW M5 - Flat Eric Edition
anzafin is offline
post #50 of 53 Old 30th March 2015, 03:25 PM
jcolley
jcolley's Avatar
Antti, I have two for sale right now for several months. Seems there is some fear in purchasing a new one.
There's a misconception that they just grenade with no warning and i really believe that's false.
You can replace the drive gear on it and then it's identical to the new style pump. As long as the inner race is free of scoring, and the pistons move freely, the pump is fine.
DIY: Vanos Solenoid Repair gzig5 E39 M5 and E52 Z8 Discussion 154 1st March 2016 10:10 PM
VANOS Repair in Germany Ady J_M5 E39 M5 and E52 Z8 Discussion 4 2nd April 2011 07:16 AM
Vanos Solenoid - anyone use Dr. Vanos to repair? reds2 E39 M5 and E52 Z8 Discussion 3 2nd March 2010 04:01 AM
break in after VANOS repair? Vossen10 E39 M5 and E52 Z8 Discussion 1 14th September 2006 09:26 AM
report on vanos repair Jessem E39 M5 and E52 Z8 Discussion 1 7th July 2003 02:09 PM
