Handling:KW V3 Coilovers / Dinan Rear Sway Bar / Dinan Front Roll Control / Tires F 255/35/19 R 285/30/19 / 12mm Rogue Engineering Spacers / 19x9/19x10.5, 3 Pc Rennen R8 Concave Wheels (Matte black face with chromed lip)
Exterior:Vorsteiner Rep Hood / Gloss Black Roof Wrap / Matte Azure Blue Metallic Car Wrap / Smoked LED Side Markers, Limo Tint / Custom headlights with Orion V2 rings / Custom Blacked Out LCI Tail lights and Miranda Bruce V 6 Cables / Hartge Rep Urethane Front Lip / AC Schnitzer Roof Spoiler / Matte Black Kidneys Grills / Gloss Black Side Gills / Gloss Black Rear M5 Emblem / Black/White CF Hood &Trunk Roundel / Rear Bumper Mesh, M5 Puddle lights, QTP 2.5 Electric Cutouts
Interior:White LED Interior Lighting / Black/White CF Steering Wheel Roundel / Aluminium Steering Wheel Trim / Handbrake Handle/Pedals /Hardwired Valentine 1, P3Cars BMW E60 Vent Integrated Digital Interface
Programming:Mirror Fold-up / Window Roll-up / Sunroof Closure / Auto S5 at Start up / Euro Launch Control / iDrive Acceptance Delete
Braking:RDSports 6 Piston F 380/35mm and 4 Piston R 380/32mm Big Brake Kit
In Process V3:
Low Compression Engine Builld:
Mahle Custom Pistons
Carrillo Rods
Howerton Engineering - Aquamist HFS-3 Injection System
Custom Fuel System
Custom Alpha N Tune
Custom SC Kit Color Scheme
Future V4 plan coming soon........
Wants:JME Rear Diffuser
MAHA Dyno 570rwhp 400trq 60-130mph 8.29secs
RIDES:
2004 Infiniti G35 APS TT with built motor and fully built transmission. 520rwhp and 550ft trq.
Dinan Everything, 13% Underdrive pulley,High Flow Middle Racing Exhaust with 4" Resonators, Free Flow Exhaust (E60) M5 full cat delete manifolds, High Flow Air Mass Meter/ Intake Assemblies, High Flow large Throttle Bodies, Stage 3 Engine Software, Replacement Filter for High Flow Air Mass Meter/Intake Assemblies, 3.91 Limited Slip Differential, Dinan Carbon Fiber Front Strut Tower Brace, Dinan Carbon Fiber Rear Shock Tower Brace, Dinan Stage 3 Suspension System (E60) M5, Dinan Lower Control Arm Monoball Racing Kit M5/M6, DinanHigh Performance 5.7 Liter V-10 Engine, Euro SMG upgrade 4k launch, LIQUI MOLY 10W-60 Motor Oil, Wix 57694 Oil filter. Special Thanks All the great forum members.
Hey Eloy, I heard your car had an oil leak before and during the event. Do you think that could have affected the performance a bit? Car looked strong in that vid though.
Im not sure if the oil leak would have effected performance. I dont think it would. THe heak soak would have though. The car needs to be moving in order for the SC's cooling system to work. While I was in line to run, I had the car running the entire time while parked (about 45minutes). I still trapped 167mph so I think I did pretty well. Sometimes, there are just cars that are faster.
You did just fine
My question is if the air temps could be kept cooler would you be able to reach higher top speed? If so let's get working on a design
The difference in the kits are about 50hp. The difference in bolt ons are about another 35-40hp
It was a great event and it was awsome seeing the RPI M5 out there running and performing very well considering the elevation we were at and the temperature. I was happy to see that the M5 pulled on me cause it gave me a good idea on how the car will run with the ESS VT-2 kit. Great run Eloy!!!!
Do you have videos of yourself running any other cars?
