Vanos Solenoid Valve - Fault Code P0011 - BMW M5 Forum and M6 Forums
post #1 of 9 Old 17th September 2011, 07:43 PM Thread Starter
douglas_ngo
douglas_ngo's Avatar
I got a fault code of P0011 again yesterday (second time). According to my OBII scanner, it is the cam position actuator. In talking to my BMW parts guy, he is telling me that it is the vanos solenoid valve and more than likely I need to replace both solenoid valves on the exhaust side. Does anyone on here know where I can find a DIY? I did some searching yesterday and only manage to find info on the E39 model. TIA
douglas_ngo is offline
post #2 of 9 Old 18th September 2011, 07:03 PM
gasterus
gasterus's Avatar
Try searching at RealOEM.com Online BMW Parts Catalog
07 M6 blk/blk
RDsport RS58 stroker with custom ECU tune
Decated stock headers, supersprint x-pipe, E-Race mufflers
Evosport Pulleys, BMC air filters, RPI air scoops & oilcooler
H&R springs, Dinan FRC & rear sway bar
20" Ac Schnitzer V with Yokos advans sport
Brembos 6-pot 405mm front+4-pot 380mm rear
08 E92 M3 S.Graphite/Red
gasterus is offline
post #3 of 9 Old 18th September 2011, 07:04 PM
gasterus
gasterus's Avatar
the soleniod valves aren't very expensive, its the high-pressure vanos pump that you need to be cautious
07 M6 blk/blk
gasterus is offline
post #4 of 9 Old 19th September 2011, 01:43 AM Thread Starter
douglas_ngo
Thanks I am hoping to find a DIY. I guess I will have to rely on realoem.
Originally Posted by gasterus View Post
They are like ~$125 each. Have you replace your yet?
post #5 of 9 Old 19th September 2011, 02:00 AM
gasterus
gasterus's Avatar
I had my solenoids replace but found out it is not the cause of my problem. Ending up replacing the vanos gears.
07 M6 blk/blk
gasterus is offline
post #6 of 9 Old 19th September 2011, 03:37 AM Thread Starter
douglas_ngo
Did you get the same fault code P0011? Did you replace the solenoid valves yourself? If not how much did the dealer charge you? I can work on the M52/M54 engine all day long but the S85 is another animal. There is not space in this engine.
post #7 of 9 Old 24th September 2011, 06:11 PM Thread Starter
douglas_ngo
I am in the middle of changing out the solenoid valves but got stuck on what to do next. Each solenoid valve is held on by two small screws. My problem is I can not get to the screws. It is such a tight space there. Does anyone know if I need to remove the valve cover and then the vanos unit itself in order to replace the solenoid valves? Please let me know if you know the answer. TIA
post #8 of 9 Old 25th September 2011, 09:15 PM Thread Starter
douglas_ngo
Anyone? Someone on here got to have some info or first hand knowledge in changing these out. I manage to changed one of the valves out yesterday but can't seem get to the other valve. I was able to remove one of the screws but the other screw is in super tight spot (lower passenger side). I either don't have the right tool or it require a special tool. It is a fillister head screw using t20 to remove them.
post #9 of 9 Old 5th September 2015, 08:39 PM
youngz22
youngz22's Avatar
Hey Can u please tell if u ever got the problem resolve because I got the same scanner and got the same code please help me I'm losing my mind .
youngz22 is offline
DIY instructions for VANOS Solenoid Valve? czarj66 E39 M5 and E52 Z8 Discussion 66 19th August 2014 06:16 PM
Vanos solenoid seals Dr. Vanos vs OEM replacement? blackwagon E39 M5 and E52 Z8 Discussion 18 24th January 2011 08:31 PM
throwing vanos solenoid codes on new solenoid pack Msentinel E39 M5 and E52 Z8 Discussion 0 16th June 2010 05:14 AM
Gurus: Fault Code Confirmation - VANOS exhaust position vencap E39 M5 and E52 Z8 Discussion 8 9th December 2008 02:19 PM
Vanos Solenoid vs Complete Vanos Replacement SoCaLE39 E39 M5 and E52 Z8 Discussion 5 4th June 2008 10:42 PM
