DIY: Reprogram Euro SMG software to US cars! (Faster shifts + 4k Launch Control) for free! - Page 32 - BMW M5 Forum and M6 Forums
Like Tree85Likes
Old 3rd October 2011, 20:36   #311
abomb60
Garage: E60 M5 - Interlagos Blue
Is there any way to find out what the current loaded software version is for the SMG?
EDIT: Got the update for INPA so I can run diagnostics now. I ran diags on the SMG module and it's listing software as 7842205 under identification. I don't see this listed on the first page of this post so either i'm reading this wrong or I have some odd software.
abomb60 is offline   Reply With Quote
Old 4th October 2011, 07:12   #312
cryptyk
Garage: None Yet
I believe 7842205 is the SMG hardware number. The software version currently running on that hardware is different. I don't remember where to find it, though. I think I saw it in Tools32 when doing a cpu status check maybe?
cryptyk is offline   Reply With Quote
Old 4th October 2011, 09:37   #313
avlnch
avlnch's Avatar
Garage: 2010 Individual Frozen Grey M5
Originally Posted by cryptyk View Post
Update: Speaking of noobs.
I pulled the ECU and sent it to ESS. They just emailed me back and told me that the SMG computer isn't part of the ECU. It's in a different box.
So yea - after spending $90 to ship them the WRONG freaking box, I'll be pulling the SMG computer tomorrow and shipping that, as well.
Awesome.
You pulled and shipped out the DME instead of the SMG Module?
You are not far off.. The SMG Module is in the same watertight box, right below the DME. If you look at the watertight box as split into three sections from top(1) to middle(2) to bottom(3), then put your DME bak into section 1, and pull out your SMG Module right below it, in section 2.
This is a photo of the watertight box, with the SMG Module pulled out.
Reprogram Euro SMG software to US cars! (Faster shifts + 4k Launch Control) for free!-imageuploadedbytapatalk1317713779.097154.jpg
2010 BMW ///M5 INDIVIDUAL {Frozen Grey/Platinum/Platinum Alcantara/Piano Black Trim}
~Mods: DINAN Stage II Suspension, DINAN Exhaust, DINAN X-Pipe, DINAN 13% Pulley, DINAN Air Intake, DINAN C/F Front Strut Brace, DINAN Pedals,
RPI Scoops, OEM Charcoal Delete
~Mods: HRE 20" P41 [Black&MachinedFace], Matte C/F Grills, Matte C/F Side Gills, Matte Black M5 Badge, Matte Black Exhaust, Frozen Grey Front Reflectors, Matte Clear Side Markers
Other Vehicles: '12 MERC S63 AMG [WHITE], '11 MERC S65 AMG [BLUE]
Previous Vehicles: '09 MERC S65 AMG, '08 BMW M5, '08 MERC S63 AMG, '07 BMW Alpina B7, '06 RANGEROVER S/C
avlnch is offline   Reply With Quote
Old 4th October 2011, 13:48   #314
abomb60
That makes sense. I was able to find the version number installed on the module in INPA.
Old 5th October 2011, 15:10   #315
abomb60
Updated my SMG software last night. Took about 30 seconds to complete. Car was running 7842208 and now is running 7842206. Car had a full software update by the dealer in June so I don't think they're locking anything out as others mentioned earlier. I did however use a battery charger and let it charge to 100% before starting.
Old 5th October 2011, 15:25   #316
cartek
Garage: M5 Black Saphire metallic
Ok so guys. Car still shifting a million times smoother! The launch prepares to pet me launch at 4kish. But sometimes when I let go of the shifter. The car doesnt take off. The revs climb a little higher and just waits there. Nothing I can do until I let off of the gas. And let it take back off normally. Any idea? Thanks!
cartek is offline   Reply With Quote
Old 5th October 2011, 16:08   #317
LJ Martin
LJ Martin's Avatar
Garage: 06 M5 black/black 94 740il black, 69 Corvette red, 03 G35 Black
I just sent you an E-mail. How often does it happen and do you try it again, right after the first failure to launch? Mine has done that a couple of times with the U.S. spec software. On a side note to get rid of the speed limit do have to flash the ECU or is there a simpler way. Don't want to get an after market tune just would like to get rid of the speed limiter.
LJ Martin is offline   Reply With Quote
Old 5th October 2011, 22:25   #318
avlnch
avlnch's Avatar
You could contact ESS and tell them you want the speed limiter removed. You buy the direct flash device so you don't have to ship out your DME/ECU. You don't pay the full amount because you are just getting a limiter delete. Give them a call and ask, they will help you no problem. If you want to raise your idle by 25rpm, 50rpm, 100rpm etc. that can be done also via the DF device from ESS.
The Following User Says Thank You to avlnch For This Useful Post:
LJ Martin (5th October 2011)
Old 6th October 2011, 04:38   #319
Vodyk
Vodyk's Avatar
Garage: E60 M5
what year is your car?
Vodyk is offline   Reply With Quote
Old 6th October 2011, 04:44   #320
abomb60
2007 model year. Build date is 9/06 I believe.
Euro Spec Launch Control for US Vehicles!?!?! gt40mki E60 M5 and E61 M5 Touring Discussion 11 27th September 2010 20:18
EURO Launch CONTROL FOR M6 IN US! MIAMI-M6 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 3 15th November 2009 04:15
Anybody try Euro Launch Control in the U.S. yet? 6speed E60 M5 and E61 M5 Touring Discussion 3 21st May 2008 03:23
Euro Launch Control - no limitiations on times used? Habib_2 E60 M5 and E61 M5 Touring Discussion 6 16th April 2007 16:34
Launch Control Software?? dkim996tt E60 M5 and E61 M5 Touring Discussion 8 16th May 2006 20:28
