FYI: E60 M5 S85 Valeo Voltage Regulator for Alternator - Page 4 - BMW M5 Forum and M6 Forums
Like Tree6Likes
Old 26th March 2012, 13:21   #31
messex
messex's Avatar
Garage: 2007 M5 - Black, 2006 X5 - Silver, 2003 Porsche Boxster S - Black
Dave T, did the error ever go away? I'm getting ready to try this DIY, once the part gets here, so just wondering if the error went away or what it was.
Thanks!
Performance Mods
Eurocharged ECU Tune, Charcoal Filter Delete, RPI Ram Air Kit/Block Off Plates, RPI Oil Cooler, M Sprint Booster V2
Cosmetic Mods
H&R Lowering Springs, 20" ConceptOne Wheels, Blacked out Kidneys/Side Vents, 6W Angel Eyes
messex is online now   Reply With Quote
Old 7th May 2012, 12:21   #32
messex
messex's Avatar
Well, I guess I need to get a set of Mechanics gloves, as I, like others, tried for a while to get the clip off, and didn't have success. Can't get my finger squeezed in there, so maybe the gloves will help give more pressure. I'll try that next, but any other tips on getting that off. I've been out of town for so long, and my beast has been sitting for so long, I've missed driving it and need to get this done!
Old 7th May 2012, 14:51   #33
ehaze
Garage: e60 M5 darkness
messex, i had the same issue.
see my comments in this post:
ehaze is offline   Reply With Quote
Old 7th May 2012, 15:41   #34
messex
messex's Avatar
Yeah, I read this, and tried to reach over where I thought you were showing, but couldn't seem to get 2 fingers around the Clip. Did you use 2 hands (one over the alternator, and one to 'pull' on the plug? I may have to go back to this route, and see if that is any better.
Thanks,
Mark
Old 8th May 2012, 13:04   #35
ehaze
Mark, I honestly don't recall if I used two hands or one.
I do recall giving it a forceful-tug!
Old 8th May 2012, 15:35   #36
latinskllz
latinskllz's Avatar
Garage: Interlagos Blue M5
i just used one hand, as you push the clip release tabs, push slightly in and then try to slide the connector out while continuing to press.
latinskllz is offline   Reply With Quote
The Following User Says Thank You to latinskllz For This Useful Post:
messex (8th May 2012)
Old 6th July 2012, 04:57   #37
screech
Garage: 2006 black M6
Flashing dash
Hey guys.
My beast has 57k and just started having these symptoms. Caught me totally by surprise with the loss of function on the road, scary moment yet remained in control. Idled fine but would act up when hot and high revs. After three hundred bucks for diagnosis, the dealer recommended a new aternator for 1600 and further diagnosis with no guarantee of solving the problem.
Big thanks to all for posting this thread. I'm going to attempt the voltage regulator exchange so now im trying to find a source for the part.
Any suggestions would be great. The dealer wants 270 bucks.
screech is offline   Reply With Quote
The Following User Says Thank You to screech For This Useful Post:
latinskllz (6th July 2012)
Old 6th July 2012, 06:01   #38
latinskllz
latinskllz's Avatar
Look at the first post in this thread. There's a link.
Old 17th July 2012, 04:06   #39
flaury23
Garage: 2006 S.B. M5
What if you are having under voltage and battery is new?
flaury23 is online now   Reply With Quote
Old 17th July 2012, 04:17   #40
latinskllz
latinskllz's Avatar
Was it registered correctly? Under or over Voltage can be a bad regulator. I'd first check to see the battery was registered properly as there's an intelligent battery aensor
Normal operating voltage? Bad alternator? HarvesterOfBeer E39 M5 and E52 Z8 Discussion 6 29th July 2011 12:30
Ovalised slip ring on the Alternator, plus alternator rebuidl services, UK? IvanDias E34 M5 Discussion 1 26th February 2010 17:57
ABS/Battery light pause since regulator blew on 140A replacement for 110A Alternator! IvanDias E34 M5 Discussion 2 10th June 2006 12:58
Alternator Regulator Replacement Technique Query! IvanDias E34 M5 Discussion 0 31st March 2006 14:55
