LinkBack Thread Tools Search this Thread Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
Old 22nd June 2002, 11:20   #1
enots
Garage: 2004 Mazda 3
WOW!! news on the M5
hi every1....reading my Saturday paper and just found this article...yeah i know some details may have been posted b4 but when u read it ALL together it really makes your spine tingle
The Sydney Morning Herald [June 22 2002]
M5 Monster
Plainly not distracted by controversy over styling of the new 7 Series, BMW has been pushing onwards with the next-generation M5, powered by a 410kW 5.5-litre V10. To arrive in 2004, it will be gunning for Mercedes AMG and Audi RS rivals. The M5 takes some styling cues from the 7 and inherits the big sibling's love-it/hate-it iDrive system. Its seven-speed gearbox with paddle controls comes direct from the BMW-Williams Formula One team. Audi's response will be to produce an RS8, based on the next A8 and using a twin-turbo 450kW version on VW's W12.
WWWOOOOOOOWWWWWW!!! very nice indeed! and interesting how Audi wanted to take on the M5 with its new RS6, could work now with the current M5.....but the next-gen M5?? hehehe.....nope....its gonna take a new RS8 to do that.
-Greg
2004 Mazda 3
[ View Me ]
enots is offline
Old 22nd June 2002, 11:57   #2
tfung
tfung's Avatar
I dunno.. I don't see a point to have a 7 speed gearbox... unless the car has like 1000hp.... even 600hp monsters don't need 7 speed gearboxes... 6 is more than enough...
US Spec 2001 E39 M5 - LHD
AC Schnitzer
Dinan
3.45 differential
Others
Euro Spec 1999 E39 M5 - RHD
2007 Mercedes E63
2007 Corvette Z06
2008 Nissan GTR
tfung is offline
Old 22nd June 2002, 12:47   #3
ICARUS
Garage: 72 pinto brown
Maybe it is because of the SMG system? With that system shifting is so effortless it doesn't matter how many gears you have to run through.
Wouldn't it just totally smooth out your ride to high speeds and increase engine life?
ICARUS is offline
Old 22nd June 2002, 20:19   #4
farcknorf
Garage: 2000 Honda CRM 125cc. :)
Imagine yourself "cruising" at 150mph, 2000rpm in 7th !
farcknorf is offline
Old 22nd June 2002, 20:28   #5
tfung
tfung's Avatar
but still, 7 gears will be totally useless... it just means more shifting, and even with the SMG, you'll still loose a few milliseconds... a 6 speed would do just as good... as far as I remember, the only 7 speed car that was ever produced was kind of a flop.... if they want more gears, they should try the variable transmission thing that they have in the new audis, which give you infinite number of gears... :p
tfung is offline
Old 22nd June 2002, 23:35   #6
Enigma
Enigma's Avatar
Garage: E46 M3 IR/IR SMG II
"Its seven-speed gearbox with paddle controls comes direct from the BMW-Williams Formula One team."
This is the key sentence. This may indicate that the gearbox is not a traditional H patern unit but a true sequential. With the SMG interface there is nothing stopping them from doing this. A 7th gear could be usefull to keep the revs down at high speeds. I expect what you would have would be 6 performance gears + Overdrive.
Enigma is offline
Old 22nd June 2002, 23:41   #7
Enigma
Enigma's Avatar
Cough, ... Ferrari FX.
I doubt that they would put a 7spd in that car unless it had some performance advantage.
Enigma is offline
Old 23rd June 2002, 08:52   #8
ICARUS
I just wonder how reliable these SMG transmisions are and how often they go through clutches.
I would guess that you would be shifting MUCH more than you would if it was a normal manual.
The shifts are probably easier on the clutch than most humans would be though.
The increased number of shifts might prolong engine life so that could balance things out.
It's all very confusing. lol
I don't understand the people that are so against the SMG system, I find SMG very interesting and would love to try it out.
If it is good enough for F1 drivers it must have some significant advantages.
ICARUS is offline
Old 24th June 2002, 06:05   #9
MEnthusiast
MEnthusiast's Avatar
Garage: 03 M5
I was led to believe that the next M5 would also have a traditional manual available- perhaps that will be a 6 speed......... either way- the rumor mill was that BMW was going more directly to the racing technology on the E60 M5 and this is consistent with that.......
All the best,
MEnthusiast is offline
Old 24th June 2002, 18:10   #10
rsbj
Garage: BMW M5 Black
If BMW is smart, they will treat the 7th gear like a very steep overdrive, keeping rev's and noise down. I seriously doubt it will be used for acceleration, meaning the other six will not be shorter. Take the current ratios in 1 - 6 and just add a 7th. It's there for those of us who will use it, or you can ignore it like it's not even there - the only penalty would be the 2 pounds the gears weigh.
Rick
rsbj is offline
Wooo tfung gone off deep end... EBMCS03 Off Topic Forum 4496 22nd November 2009 09:15
Rumours about the E39 M5 pre 1998. Gustav F10 M5 Discussion 15 21st October 2009 01:11
German AMS magazine tests M5 suspension kits lofstrom E39 M5 and E52 Z8 Discussion 25 11th April 2008 13:24
Page generated in 0.16395 seconds with 11 queries
