24th May 2011, 19:20
#1
E60 M5 with EDC warning light
I have a iDrive message of "Dynamic Damping Control Malfuntion" and a shock absorber icon on the dash. I assume this is the EDC unit warning. The warning says to drive cautiously so I continued to drive with the light on for several weeks before I got in to the dealer. The dealer did a $80 "scope" and a $50 "engine analysis" (car has 36K miles and needed spark plugs also) and said everything was fine.
Drove off and light still on. Returned to dealer. They took car around corner and 10 minutes later said I needed a new "control module" for$825. I'm skeptical. Could it be anything else? Loose wire? Steering angle sensor? fuse?
Anything I can check on my own? I want to disconnect the battery to reset but I've read several posts warning never to disconnect battery. What would be the consequences?
Any input would be helpful
