Oil change drain plug - BMW M5 Forum and M6 Forums
 1Likes
post #1 of 13 Old 10th March 2011, 12:28 AM Thread Starter
LeeDan00
LeeDan00's Avatar
Went to my mechanic today for an oil change and was a little confused.
How many drain plugs are our cars supposed to have? I've heard some have 2 plugs depending on the year and model? I just didn't want to miss one plug...
Can anyone confirm?
LeeDan00 is offline
post #2 of 13 Old 10th March 2011, 12:53 AM
Clyde
Clyde's Avatar
I have only found 1 oil drain plug on my MY2007 M6.
Both plastic shields were removed during my last service, and I could not locate a second plug.
There have been posts that a second drain exists (and 2 washers are included with the oil filter), but there have not been any pictures posted.
Clyde is offline
post #3 of 13 Old 10th March 2011, 04:54 PM
ssigarto
ssigarto's Avatar
ssigarto is offline
post #4 of 13 Old 10th March 2011, 06:01 PM
DaveCM5
My 2008 appears to have two. I used them when I changed the oil and it went wthout incident.
One oil drain plug is on the pan, which is accessible through a hole in the plastic pan under the engine.
The second one is in the bottom of the plastic oil filter housing, in the passenger side of the front bumper accessed from underneath after removing a panel. You use it to drain the oil filter housing of oil before you remove the filter. Also, since it holds 0.4Liters, it can be used to remove 0.4L of oil if you accidentally overfill the oil. Obviously be carefull not to overtighten this one since it's in plastic.
Make sure you let the engine idle for at least 3 minutes before you drain the oil so all the oil gets pumped into the main sump where the drain plug is.
DaveCM5 is offline
The Following 2 Users Say Thank You to DaveCM5 For This Useful Post:
H0LLYW00D (10th March 2011), Speedy_Rocks (10th March 2011)
post #5 of 13 Old 10th March 2011, 08:02 PM
Speedy_Rocks
Speedy_Rocks's Avatar
Great tip on a way to remove 0.4l of oil. Thanks.
2008 M5
2004 M3 gone
1997 M3 gone
1972 2002 Tii long gone
Speedy_Rocks is offline
post #6 of 13 Old 11th March 2011, 10:52 PM Thread Starter
LeeDan00
LeeDan00's Avatar
thanks for the info. i guess i only have 1 drain plug but good info on draining 0.4L of oil just in case.
LeeDan00 is offline
post #7 of 13 Old 12th March 2011, 12:32 AM
BK02
BK02's Avatar
My 2006 M5 has the drain plug in the oil pan and a drain plug in the oil filter housing. The dealer had stripped the oil filter housing plug, so I replaced it with a new one after having to drill it out on the bench. You don't actually need to remove the filter housing drain plug because you can just screw off the filter housing with a large socket. It's a little messy, but not too bad.
Brian
'06 M5 Silver Gray Metallic - Silverstone Leather
- Factory Options: CPO, Perforated leather, comfort access, Multifunction seats, Rear Shade, Cooled seats, Fold down rear seats, Heads up Display, Satellite Radio
- Mods: H&R Springs, Painted Calipers - G2 Blue, EBC Pads, Stainless brake lines, front splitter
'74 BMW 2002
'13 Mercedes C250
'69 Camaro Pro Touring - build in process
'06 Toyota Tundra Double Cab
'11 Hyundai Elantra
BK02 is offline
post #8 of 13 Old 12th March 2011, 01:05 AM
carolina
carolina's Avatar
Mine stripped out in the filter canister also. Less mess when it works, but not a big deal to dump the filter full. Just a little more mess on my hands. Dealer said the filter housing canister drain stripping out was fairly common from use and over-tightening.
carolina is offline
post #9 of 13 Old 12th March 2011, 01:20 AM
Clyde
Clyde's Avatar
The filter canister drain seals with an o-ring, so over-tightening is just a lame mechanic
The torque spec is 10Nm (7lb-ft).
All our cars have both the main sump drain and the filter canister drain.
The second drain plug (if it exists) would drain a second sump
Clyde is offline
post #10 of 13 Old 14th February 2017, 05:27 PM
texsn95
texsn95 is offline
DIY oil change update - 2nd drain plug ssigarto E60 M5 and E61 M5 Touring Discussion 16 18th February 2013 07:25 PM
torque oil drain plug frank///M5 E39 M5 and E52 Z8 Discussion 13 5th February 2011 05:15 PM
oil drain plug door sbacchus E39 M5 and E52 Z8 Discussion 2 2nd June 2009 04:37 PM
Oil Drain Plug Torque on M5 - 25NM? Leaky PS oil? CWY_M5 E39 M5 and E52 Z8 Discussion 0 4th November 2006 08:45 PM
What about that oil drain plug?? Prutser E34 M5 Discussion 2 14th June 2003 12:58 PM
