Oil Leak - BMW M5 Forum and M6 Forums
post #1 of 30 Old 10th January 2011, 03:45 AM Thread Starter
cifly2002
Angry Oil Leak
I looked under my car today to find an oil leak under the front right part of the car. After everything I'm reading I think it might be the Vanos oil line, but now I'm wondering since my car is not under warranty anymore what will this cost me. I just bought this about 3 months ago from Fremont BMW. About a month ago my car was in for the check everything service and they didn't notice it. They also charged me for a new battery because I was getting the high battery drain warning and guess what? I have the same warning coming up again. Getting pretty frustrated with everything. Any help would be appreciated. Thanks everyone in advance.
cifly2002 is offline
post #2 of 30 Old 10th January 2011, 02:00 PM
Hasan Shaikh
Hasan Shaikh's Avatar
I think it would be the Oil Cooler. This is a common problem with these cars.
If it is only the connector or the lines, you should not have to spend much.
If you need to replace the Oil Cooler, I would suggest the RPI Oil Cooler.
Good Luck!
Hasan Shaikh is offline
post #3 of 30 Old 10th January 2011, 05:58 PM
andrewsherman
andrewsherman's Avatar
+1 on both the potential problem and the solution.
2014 M5 Competition|Space Grey|Black Merino Full Leather|Anthracite Trim|Executive package|LED Lighting Package|Drivers's Assit Package|B&O Sound System|Bel STiR Plus 9500ci|IND Side Markers and Side Vents|Exhaustmeister|Pirelli Sottozero Serie II
Past Rides:'07 M5 Silver grey/Black(Nicely Modded)|'04 745Li Titanium Grey/Black|'01 740iL Titanim Silver/Black|'91 K1100RS|'88 K75S
andrewsherman is offline
post #4 of 30 Old 10th January 2011, 08:21 PM
Clyde
Clyde's Avatar
Originally Posted by cifly2002 View Post
I just bought this about 3 months ago... They also charged me for a new battery because I was getting the high battery drain warning and guess what? I have the same warning coming up again.
Check for any aftermarket accessories that a previous owner may have installed.
Clyde is offline
post #5 of 30 Old 10th January 2011, 11:00 PM Thread Starter
cifly2002
I hope you are right on this one. I'll find out today when they call me back. Also, should I just have them install it since my car is already there? How much am I expecting to spend there?
post #6 of 30 Old 10th January 2011, 11:49 PM
w8m5
w8m5's Avatar
w8m5 is offline
post #7 of 30 Old 11th January 2011, 12:03 AM
dannboss
dannboss's Avatar
As is noted, this is a common problem. If you look inside the lower grille at the top left of the oil cooler (facing the bumper of course), you will see this is where the two lines come into the oil cooler. If this is not where yours is leaking from, you may have a completely different problem.
Mine is leaking at this location, and there are several options. Replace the oil cooler, replace the lines, replace both the oil cooler and lines, or start small and work to big. Meaning, there are two o-rings which fit inside this connection. They are $4 each at a BMW dealership (part 8 on the link above). Crimp the lines and replace the o-ring. If the leak stops, problem solved. If not, continue to problem solve.
I purchased the two o-rings, and it should take me a few hours to replace and test. $8 and a few hours is worth it to me to try and address the issue prior to dropping it off at the stealership.
dannboss is offline
post #8 of 30 Old 11th January 2011, 12:30 AM Thread Starter
cifly2002
Stearlership has it
Unfortunately I didn't know what to do with it so I drove it into the stearlership this morning. They have it and are still looking for the problem. They just called me and said they need to have it over night and take a look at it again tomorrow. Pretty crazy considering I took it in this morning at 7:45 a.m. Is it really that hard to figure out where the leak is coming from?
post #9 of 30 Old 11th January 2011, 04:49 AM
Vodyk
Vodyk's Avatar
+1 to oil cooler leak. Mine leaked all it needed was two new gasket rings and tightening. Goodluck. Problem is to do this you have to take the front bumper off which takes a little bit of effort.
Vodyk is offline
post #10 of 30 Old 11th January 2011, 10:29 PM
ssigarto
ssigarto's Avatar
ssigarto is offline
Significant oil leak, oil fill cap orientation? Bryan@Jlevi SW E39 M5 and E52 Z8 Discussion 13 12th January 2016 05:01 PM
Oil Leak - Replace upper/lower oil pan & solenoids?? duc748_2003 E39 M5 and E52 Z8 Discussion 14 7th August 2014 06:38 PM
Pictures of oil leak at oil cooler hoses Rodster E60 M5 and E61 M5 Touring Discussion 34 8th June 2014 09:09 PM
Engine Oil Leak Suspected - Non-Linear Oil Usage 507bhp E60 M5 and E61 M5 Touring Discussion 12 10th December 2005 09:05 PM
Persistent Oil Leak Fixed w/New Oil Pan JonB E39 M5 and E52 Z8 Discussion 2 14th June 2002 12:04 AM
