Mobil 1 Extended Life 10w60
API SN/SM/SL & CF
ACEA A3/B3, A3/B4
Kinematic viscosity @ 40°C_________________________152.7 cSt________(ASTM D445)
Kinematic viscosity @ 100°C________________________22.7 cSt_________(ASTM D445)
Viscosity Index___________________________________178
Sulfated Ash wt%_________________________________1.4___________ __(ASTM D874)
Phosphorous, wt%________________________________0.13___________ _(ASTM D4951)
Flash Point_________________________________234ÂşC___________(ASTM D92)
Density @15.6ÂşC g/ml_____________________________0.86____________(AS TM D4052)
Total Base Number TBN___________________________11.8_____________(AS TM D2896)
MRV @ -30ÂşC____________________________________25,762cP__ _______(ASTM D4684)
HTHS Viscosity, mPa•s @ 150ºC____________________5.7______________(ASTM D4683)
Shell Helix Ultra Racing 10W-60 10W-60
API SM/CF
ACEA A3/B3/B4
Kinematic viscosity @ 40°C_________________151 cSt_______________(IP 71)
Kinematic viscosity @ 100°C____________________22.8 cSt______________(IP 71)
Density @ 15°C_______________________________0.85 kg/l______________(IP 365)
Flash Point___________________________________215°C_____ ___________(IP 34)
Pour Point____________________________________-39°C________________(IP 15)
HTHS Viscosity @ 150°C PaS____________________5.42
Valvoline VR1 Racing 10w60
SAE 10W-60
API SL
Kinematic viscosity @ 40°C____________________165 mm2/s____________ASTM D-445
Kinematic viscosity @ 100ÂşC___________________23.0 mm2/s___________ASTM D-445
Viscosity Index______________________________168____________ ______ASTM D-2270
Viscosity, mPa.s –25°C. ______________________<7000 _______________ASTM D-5293
TBN, mg KOH/g_____________________________12.0__________________ASTM D-2896
Pour Point__________________________________-39ÂşC_________________ASTM D-5950
Specific Gravity @ 15.6°C.____________________0.864_________________A STM D-4052
Flash Point, COC_____________________________220ÂşC_____________ ___ASTM D-92
Gulf Competition 10W60
(no formal specifications can be claimed, but these oils contain performance
additives designed to achieve ACEA A3/B4 and API SL/CF)
Kinematic viscosity @ 40°C___________________________168.5cSt
Kinematic viscosity @ 100°C__________________________24.1cSt
Viscosity Index_____________________________________175
Cold Crank cP______________________________________6450@ -25ÂşC
Flash Point_________________________________________>200ÂşC
Pour Point_________________________________________-30ÂşC
TBN mg KOH/g_____________________________________9.2
Density @ 15ÂşC Kg/l_________________________________0.866
Castrol Edge 10W60 & Castrol Edge Professional TWS 10W60
*pdf dated JULY/27/2011
*pdf dated JUNE/07/2011
ACEA A3/B4, A3/B3
API SM/CF or earlier specification 10W-60 lubricant.
BMW Exclusive approval for BMW M-Models
Kinematic viscosity @ 40°C___________________________________________160 mm²/s _____________ASTM D445
Kinematic viscosity @ 100°C__________________________________________22. 7 mm²/s_____________ASTM D445
Density @ 15°C Relative g/ml_________________________________________0.853__ ________________ASTM D4052
Viscosity CCS -25°C (10W) mPa.s (cP)_________________________________4879_________ __________ASTM D5293
Viscosity Index None______________________________________________ __173____________________ASTM D2270
Pour Point_____________________________________________ ____________-39°C___________________ASTM D97
Flash Point, PMCC______________________________________________ _____203°C__________________ASTM D93
Ash Sulphated % wt________________________________________________ _1.29___________________ASTM D874
Castrol EDGE SPORT 10W60
*pdf dated MAY/20/2011
API SM/CF,
ACEA A3/B3, A3/B4 or earlier specification 10W-60 lubricant.
Viscosity, Kinematic 40º C__________________________________157 mm²/s_____________ASTM D445
Viscosity, Kinematic 100ºC__________________________________22.9 mm²/s____________ASTM D445
Density @ 15C Relative g/ml________________________________0.853___________ _______ASTM D4052
Viscosity CCS -25C mPa.s (cP)_______________________________4700___________ _______ASTM D5293
Viscosity Index None_______________________________________174____ _______________ASTM D2270
Ash, Sulphated % wt_______________________________________1.24_____ _____________ASTM D874
Pour Point_____________________________________________ ___-36°C_________________ASTM D97
Flash Point, PMCC__________________________________________208° C________________ASTM D93
Liqui Moly Synthoil GT1 10W60
API SL/CF
ASTM colour : _____________________3.5
Density at 15 °C : __________________0.86 g/cm³
Viscosity at 40 °C : _________________163 mm²/s
Viscosity at 100 °C : ________________24 mm²/s
Viscosity index : ___________________179
Flash point : _______________________238 °C
Pour point : _______________________-35 °C
Evaporation loss : __________________6.9 %
