Originally Posted by Hasan Shaikh
Auto mode is a big negative. S6 does wear the clutch faster than the S4.
Are you sure about this?
The biggest factor in clutch wear/life is the slipping, rubbing, and abrasion that occurs during engagement of the clutch. That's why the driver is supposed to get the clutch engaged as quickly (and comfortably!) as possible. The warning about not riding a manual clutch or inching through a line of traffic is based upon this.
Auto mode would be a negative for the same reason - all components slip longer and more gradually.
Everything I know and everyone I've talked to indicates that the faster the engagement the better for clutch life. Obviously there's a point where simply dropping the clutch is not good - but the problems stemming from that are different than simple wear and erosion of the clutch material itself.
S6 doesn't get near that point. So I'd say - along with shop personnel I've spoken with at BMW, Lamborghini, independents - that the higher/faster clutch settings are better overall.
Just drive the 5. At worst you'll lose a couple thousand miles, but you'll be a lot happier!!
