Our future: swap SMG for 6-speed manual? - Page 12 - BMW M5 Forum and M6 Forums
 42Likes
post #111 of 114 Old 5th February 2017, 07:58 AM
Hasan Shaikh
Hasan Shaikh's Avatar
Hasan Shaikh is offline
post #112 of 114 Old 5th February 2017, 08:05 PM
CHARIOT
Originally Posted by Hasan Shaikh View Post
Mods.
This thread needs to be cleaned up and made a sticky.
We need the complete parts list also.
I will update the parts list to reflect what was actually needed/not needed and the corresponding details, but the original list posted before I did all the work is pretty darn close.
CHARIOT is offline
The Following 2 Users Say Thank You to CHARIOT For This Useful Post:
Hasan Shaikh (6th February 2017)
post #113 of 114 Old 7th February 2017, 12:11 AM
CHARIOT
So we have a slight problem....
The oil measurement does not work...even with the engine warm on a flat surface with handbrake pulled up.
Is there anything special in the manual cars that needs to be done, or any preconditions that are different from the SMG?
EDIT - Never mind It mysteriously randomly started working after I recalibrated the level/yaw sensor.
Crisis Averted
On a side note: For what it's worth to anyone, i'm starting to regret the delrin shifter bushings. They're very solid, so they have their pros and cons. While they do stiffen up the shifter carrier, the level vibration they allow to transmit into the shifter is absolutely abysmal; you can feel every edge, and every single metallic noise from the transmission. They also make the transmission feel extremely notchy....i'll be placing an order tonight for the factory hardened rubber ones, along with new transmission mounts from BMW.
CHARIOT is offline
post #114 of 114 Old 15th February 2017, 01:58 AM
CHARIOT
A word of warning to anyone planning to do this retrofit on their 2007 - the MDM switch panel is very hard to find since it is technically only a 1 year production part. That, accompanied by the fact that it only came in manuals makes it even more elusive. A new one can always be purchased at the dealer, but it will set you back ~$315
However, I think I may have found a coding workaround in the DSC which will allow you to disable the DSC again but use the SMG DSC button instead. Working on it now, will report back.
So, there is no way to code the DSC to look for the other old style DSC switch. The coding flag can either be set to SMG or HANDSCHALTUNG, but switching to SMG also enables the DSC to start looking for the SMG messages on the PT_CAN including the yaw rate sensor. LOTS of error codes and check control messages and no start off assistance anymore. The DSC button DOES work, but I don't want to have all the errors just to be able to disable DSC.
On to plan B:
In the midst of brainstorming all of this I had a hunch....why not just re-wire the DSC for the old switch? Well, remember earlier in the thread where I explained my lucky malfunction of the MDM automatically coming on when starting the car? The DSC for MANUAL cars looks for the DSC switch signal on the same pin as the brake switch signal on SMG DSC cars....
This is DSC with SMG cars.....brake switch signal is going to pin 4. DSC switch signal is going to pin 41.
That's DSC for manual cars.
DSC module is listening for the DSC switch signal on pin 4. Because I haven't changed any wiring yet, my brake switch signal is still going to pin 4. DSC is seeing my brake switch signal and thinking its the DSC/MDM switch signal, therefore turing on my MDM when I press the brake pedal. They must both be a 12V on/off result based on status. Only weird thing is the MDM light dos not turn on/off as I press/release the brake pedal, so it must be doing some redundancy check or something.
If you're a 2007 converting from SMG to manual, you need to move pin 4 on your DSC to pin 30 to move the brake switch signal to the proper place, and open pin 4 for for your DSC switch if you want to use the old button in the event you can't find an MDM switch panel. Then simply swap pin 41 to pin 4 for the DSC to recognize your old DSC switch
CHARIOT is offline
6 speed manual on e60 m5 smg euro tra1ner E60 M5 and E61 M5 Touring Discussion 2 23rd June 2009 06:03 PM
6 speed manual needs much LESS oil than SMG! BogoKi E60 M5 and E61 M5 Touring Discussion 16 15th August 2007 05:00 AM
Is 6 Speed manual really slower than SMG? benfmd E60 M5 and E61 M5 Touring Discussion 35 30th July 2007 07:21 PM
2006 SMG or 2007 6 Speed Manual? jazz4tune E60 M5 and E61 M5 Touring Discussion 39 28th July 2006 05:12 AM
smg, auto or 7 (yes, 7!) speed manual Gus E60 M5 and E61 M5 Touring Discussion 20 20th March 2003 04:09 AM
