2010 CIC install in 2006 M5 Pictorial - Page 4 - BMW M5 Forum and M6 Forums
Like Tree6Likes
Old 17th July 2010, 16:12   #31
stunt
Garage: 2006 M5 Black Sapphire
Ok, I got the center console removed.
The first step is to pull the shifter knob. It pull straight up and will take some force. Be carefull to stop pulling as soon as it breaks free to prevent damaging the wires for the light. The leather boot pops out and comes with it.
You also want to remove the iDrive knob at this point. Pull straight up at the 3 and 6 o'clock positions and it will come off.
With the boot gone, you can now pull off the trim piece. This will reveal 2 torx screws that hold down the main trim piece (wood or aluminum). At this point you also want to pop out the ashtray inset. Just push down on it and it will release.
The main trim piece can now be removed. Pull it loose at the front, then use a wedge to carefully pry it straight up at the rear.
Here's a shot of the center console after the trim has been removed. You can see the 2 white retainers behind the iDrive controller. This is where you want to insert a flat wedge. You can also make out 6 torx screws in this shot. The 4 in the front hold down the ashtray bracket. They don't have to be removed, but it makes it easier to get the console out later.
Next we need to reveal the 4 nuts that hold the console in place. Start by sliding back the 2 side trim pieces where the floor carpet meets the console along either side. You want to remove the rear nut on each side. Here's the passenger side one:
Now its time to climb in the back seat and remove the power outlets and A/C vents. The lower panel will pop right out. If you have a snap-in adaptor, you will want to disconnect it at this time. Things should now look like this:
Next you need to remove the 2 clips that hold the vents in place. Here they are shown partially removed:
Pull down and out, and the vents will come out. Disconnect all wires and shove them into the AC tunnel to get them out of the way. You should have a clear view of the remaining 2 bolts that need to be removed.
Now comes the fun part! Pull the parking brake handle forward to loosen it from the metal lever. Now pull it as hard as you can to set the brake. You can now begin to lift the center console as shown here:
You will now want to reach in and undo the connector for the iDrive controller. Continue lifting up and the consoler will clear the parking brake lever and can be removed. Here's a shot with it removed showing the iDrive connectors on the passenger seat:
Backseat shot showing the entire consoler area:
You should now have the following collection of pieces removed from the car:
Here's the backside of the console with the iDrive controller still attached:
Here it is again with the controller removed:
Closeup of old iDrive:
Back side:
Reconnected in car:
Nelson, does the new iDrive controller have 2 connectors on it that looks like it will accept the wires you see in the shot above?
So that's pretty much it for removing the console. Once the new controller gets here next week, I can begin trimming the for the new iDrive.
Finally, here are a couple of shots of the patient under the knife:
2006 M5 Saphhire Black / Sepang Leather / All Options
  • 2010 CIC
  • Red Calipers
  • Black Grill & Gills
  • Charcoal Filter Delete
  • MTec v2.1 AEs wired as DRLs
  • Eibach Springs | H&R Spacers
  • Smoked White LED Side Markers
stunt is offline   Reply With Quote
The Following User Says Thank You to stunt For This Useful Post:
Ahmed (29th July 2010)
Old 17th July 2010, 19:42   #32
v8venom
v8venom's Avatar
Garage: 2013 GTR - black edition
Stunt,
Your documentation is fantastic, but this idrive controller upgrade is a major turnoff! Are you going try to look for some software solutions via programming session with Patryk using the old controller first?
Viet
v8venom is offline   Reply With Quote
Old 17th July 2010, 20:20   #33
stunt
Yes. I figure we will start by seeing what program version is actually in my vehicle, and assuming it is v37.x like the dealer stated, we will try to get the old idrive going.
If I have older software, I'm going to raise hell with the dealer.
I'm not sure if we will try the new controller before I get the program updated first, but hopefully it won't come to that.
So assuming we get everything working w/ the old controller, then and only then, will I swap out to the new controller and verify all is still well.
Old 17th July 2010, 22:21   #34
CHIH
CHIH's Avatar
Garage: E60 M5 Gray
awesome write up!!! very interesting this for my next mod !!
CHIH is offline   Reply With Quote
Old 21st July 2010, 01:56   #35
stunt
Got my interface cable today and had about a 1 hour session with Patryk.
In about 20 minutes, he had my original iDrive controller working!
Apparently the dealer did upgrade the firmware/software on it, but for some reason, not well enough!
After another 20 minutes, he had my CIC reading CDs and DVDs, and after I checked that everything was working correctly, he programmed my mirrors to fold up when locking the car, and fold down when unlocking. Very cool!
I also have the new iDrive controller, and while the bracket for it does bolt up nicely to my existing console, the controller itself will not work with trim used for the original iDrive controller. I'll post pics in a bit showing the issue.
In short, the CCC to CIC conversion works great in pre-2010 M5s with no need to replace the original iDrive controller!
HUD, M5 button settings, everything works as it should, only much faster and nicer looking than before.
I give a big thumbs up to Patryk in being able to get my controller going where the dealer program update couldn't!
I'll post additional details later tonight. I'm very excited to finally getting the old iDrive controller working. I'm a bit dissapointed that my current trim won't work with the new controller, but I don't really have any issues navigating the CIC with the existing controller at all.
Currently in the process of loading the 2010 North America Nav DVDs.
The Following 3 Users Say Thank You to stunt For This Useful Post:
Ahmed (29th July 2010), cshorter (21st July 2010), nelson29 (21st July 2010)
Old 21st July 2010, 02:31   #36
stunt
Here's the new iDrive bracket fitting perfectly into my console:
The new iDrive fitting not so perfectly below my trim:
Screen after putting in Nav DVD 1:
Entering the code:
Loading process started:
It better hurry up loading, my next mod is already here!
The Following 2 Users Say Thank You to stunt For This Useful Post:
Ahmed (29th July 2010), nelson29 (21st July 2010)
Old 21st July 2010, 02:38   #37
v8venom
v8venom's Avatar
awesome to hear that you and patryk got the old idrive controller to work...
any word on voice command?
Old 21st July 2010, 03:40   #38
stunt
No official word on the voice command right now, but there is no technical reason why it won't work.
Old 21st July 2010, 07:31   #39
brabusw209amg
Garage: BMW
wow. nice!!! This is sick! I really want the voice command tho.
brabusw209amg is offline   Reply With Quote
Old 21st July 2010, 09:40   #40
JT///M5
JT///M5's Avatar
Garage: 2008 M5 Sepang Bronze
awesome writeup! keep us posted on your progress! plus your pics look great!
2008 Sepang Bronze / Portland Full Leather
- Olive ash wood trim, Comfort Access, Soft Close doors, Multi Function Sport seats, Alcantara Headliner, Heated Wheel, DIRAC Individual Sound, HUD, Auto High Beams, Hardwired V1, 3M tint, EURO SMG and EURO MDM Programming, 2010 HDD CIC iDrive Retrofit w/HD Radio, Knock off Scoops, Style 167s w/M5 Offsets on SuperSports, Corsa Cat Back Exhaust, Lowtec front springs, Stock rear springs, X5 Lightning CREE 20W LED Angel Eyes.
JT///M5 is offline   Reply With Quote
2010 CIC Retrofit Installation LOG nelson29 E60 M5 and E61 M5 Touring Discussion 217 16th May 2013 10:33
DIY IPod MOST Adapter Install in 2006 M5 mcw331 E60 M5 and E61 M5 Touring Discussion 194 12th December 2012 04:02
I need the new Idrive.. (CIC) joenjolera.com E60 M5 and E61 M5 Touring Discussion 31 30th August 2011 04:24
Supersprint header/race cat install pictorial(lots of pics) ECB E39 M5 and E52 Z8 Discussion 22 27th March 2008 10:42
