Blackberry 9630 problems with bluetooth - BMW M5 Forum and M6 Forums
post #1 of 3 Old 11th July 2010, 11:26 PM Thread Starter
hfarouk55
Hello everyone:
Just had a weird problem that started last week in my 2008 M5. I have a Blackberry 9630 from Verizon for the past 6 months. I paired it with the car bluetooth and it worked flawlessly for all that time. Last week suddenly when I started the car one day, the phone ones it pairs with the car, there appears to be an active call when in deed there isn't. When this happened, the radio did not work, voice command was not working either. I could not disconnect that active call using all the different buttons in the car. When I shut down the car, the computer remains on and cannot completely shut it down. The only way to get things back to normal is to shut down the phone, or disconnect it from the bluetooth connection which returns everything in the car to normal. I thought it was a problem with the blue tooth, so I tried to pair my Iphone to the car that worked fine with no issues. So, it is only the blackberry. Now, I deleted it from the bluetooth list of the car and reinstalled it which did not solve the problem. I rebooted the computer system by pushing the eject buttons of the CD and DVD as well as the volume button, which also did not correct the problem. When this happened last week, there was nothing new. I did not change anything with the car or the phone, so it happened spontaneously.
So, every time I pair the blackberry to the car, the car recognize it as having an active call and I cannot disconnect it which mutes all the voice functions of the car.
Did anyone face that problem or has a solution?
Have a very good day everyone.
Hosam
hfarouk55 is offline
post #2 of 3 Old 12th July 2010, 11:17 PM
KGP,Esq
I have the exact same phone from Sprint and have not encountered pairing problems but will be on the lookout and let you know if anything arises.
KGP,Esq is offline
post #3 of 3 Old 13th July 2010, 06:30 PM Thread Starter
hfarouk55
Found out the solution
Finally found out the solution of the problem. I did reboot my blackberry and everything was fine afterwards. It was the phone that had the problem.
Thank you guys for all the help.
Hosam
Blackberry 9630 paralyze the radio and voice command hfarouk55 F10 M5 Discussion 2 12th July 2010 04:43 AM
Anybody have bluetooth problems? [Bluetooth problems with Blackberry 8300] ThisFlyGuy E60 M5 and E61 M5 Touring Discussion 15 4th March 2008 01:28 AM
Bluetooth/Blackberry 7100 Winnipeg M5 E39 M5 and E52 Z8 Discussion 10 12th December 2006 03:27 PM
bluetooth and blackberry korea_7 E39 M5 and E52 Z8 Discussion 4 24th June 2005 01:43 AM
Blackberry 7290 Bluetooth Spooky 1 E39 M5 and E52 Z8 Discussion 1 28th November 2004 06:16 AM
