European Member M-bitious (Frank) BMW M5 E60 individual carbon black metallic with aftermarket options from Hartge, Manhart Racing, StopTech, Evosport, RPI, Mos-Tec, Bavarian Soundwerks, Audison, Senergy and Cargraphic + more - BMW M5 Forum and M6 Forums
Like Tree1Likes
Old 31st May 2010, 02:59   #1
Gustav
Administrator
Gustav's Avatar
Garage: BMW M3 DCT Sedan / Limousine
This is the story behind my Euro carbon black BMW M5 E60 (2007 facelift) and the changes I have made to the car over the past year. I went from an M3 E46, to the M6, the latest M3 E92 and back to the raw power of the M5 V10. Yes I like my M’s. I don’t believe anyone has introduced his modified car in this way, and I hope you will enjoy it. Let me start with some general pictures with the end result then detailed pictures of each modification showing you what the parts are. The tuner names are all hyperlinked for your convenience. My goal was not to change the general appearance of the car too much, as if it could have left the factory as a special edition. On the other hand I wanted a more aggressive look, a more powerful NA engine and a better sound system. I hope you will enjoy this trip.
Frank.
Note: I had to use some pictures from suppliers and should anyone object then such a picture will be removed.
I would like to thank Adam and Bart for taking most of these brilliant pictures.
Hi res here.
Hi res here.
Hi res here.
Hi-res here.
Hi-res here.
Hi res here.
Cargraphic – Rims.
3 piece 9.5 and 10.5 x 21 inch Cargraphic rims with Conti Sport Contact 3 in 255/30/21 and 295/25/21. I realize that these wheels are heavier than stock, but it is a small sacrifice for good looks. The wheels weigh about 13.5 kg. I actually haven’t noticed/measured any difference in performance, but then again my Stoptech brakes are lighter than stock.
Hi res here.
HARTGE – Spoilers, springs, steering wheel, pedals.
The Hartge front splitter actually produces some extra down force at high speeds. All German tuning parts have to pass the TÜV, so it is more than simple cosmetics.
Hi res here.
The Hartge rear diffuser supposedly does the same and fills the gap between the two mufflers nicely.
Hi res here.
Hartge lowering springs. Comfort is almost oem and the 25 mm drop still allows me to take all these ridiculous speed bumps. Body roll is obviously less now. I could have gone for a coil over, but I didn’t want to lose the EDC settings.
Hi res here.
Hartge leather steering wheel for a much more comfortable grip. I never liked the oem one.
Hi res here.
Hartge aluminum pedals. These are a 100% perfect product and fit. Unfortunately Hartge don’t do a dead pedal.
Hi res here.
STOPTECH – BBK ST60.
Stoptech 6 pot Big Brake Kit 380x35 mm at the front with slotted discs. I decided to go for slotted discs as they are more heat resistant than drilled ones. Braking has improved dramatically with no fading whatsoever. If you look at the last video clip, you will understand why braking is important to me.
Hi res here.
Carbon-factory – Real carbon fiber overlay.
Carbon Factory is one of my favorite companies. The grilles and all other parts are better than oem quality. I just can’t believe how nice all their work is, and relatively cheap as well. You simply send them your oem part and they do their magic. They will also purchase a new oem part for you and overlay that, so you can keep the original part.
Hi res here.
Carbon Factory side gills are a massive job to overlay, but they came out brilliant. A lot of companies only do the two horizontal strips.
Hi res here.
Carbon factory upper mirror covers with oem gloss black lower cover. Be warned that these upper covers are a lot of work to install. The whole mirror needs to be disassembled.
Hi res here.
Carbon factory engine bay parts. Nice little photo shop job. There are 9 parts overlaid with real carbon and it looks so classy. This is how BMW should have done it. A board member already classified this engine bay to be “the sexiest on the m5board”.
Hi res here.
CA-Automotive – Roundels, door pins and engine tuning.
Hi res here.
CA-Automotive black/silver carbon trunk roundel. I had Bimmian stickers before this, but they came off during heavy rain. These babies are the real thing.
Hi res here.
Carbon door pins. I just happened to come across these on my first visit to their website and thought they looked really smart. A first step to greater things by Roy and his people.
Hi res here.
CA-Automotive remap including speed delimit, 8,400 rpm raised rev limit and smg software, which makes the transmission shift faster and smoother when not at WOT. Engine management defaults to P500 and they activated video on the move. In winter I use the spare key which defaults to P400. Mike can do almost anything you wish with very reasonable pricing. The tuning list below resulted in the following dyno sheet with 450 RWD bhp and 510 Nm of torque. I don’t have a before dyno. There is a bit of a strange torque dip at 4,500 rpm, but we’ll look into that. Next on the list are the Stage 2 Schrick cams with custom live remap by Mike. I will have the car dynoed afterwards.
RPI – Ram air kit en block off plates.
Race Precision ram air induction kit with BMC air filters. Cheap power making mod. Nuff said. This is a mod that even I could do myself. It takes half an hour to do the whole thing. I have been driving in heavy rain storms and no water gets into the air boxes at all.
Hi res here.
Race Precision block off plates. Get these cheap plates while ordering your kit. They help pressurize the air boxes.
Evosport – Pulley kit.
The Evosport under drive pulley kit was also installed by CA Automotive. Under drives the accessories by 12%, allowing more power to go to the wheels. Unlike other reports my M5 does not run any hotter than before, but revs quicker and easier.
Manhart Racing - Differential, headers.
Manhart Racing 3.91 differential making the engine run 250 rpm higher per each 62 mph. I noticed a much quicker 62 – 125 mph time. More than 1.5 seconds (hand clocked), which is quite impressive. The top speed is still in excess of 335 km/h or 208 mph on the speedo at 8,000 rpm.
Mos-tec - Headers.
Hi res here.
Bavarian Soundwerks - Speaker upgrade.
The BSW stage 1 speaker upgrade gives a better kick bass than the Harmann Kardon Prologic 7 set and the treble is much clearer. The subwoofers under the seats I left untouched.
Herz – Subwoofer.
This Herz Mille ML 2500 subwoofer I had installed in a ported enclosure. It is a sound quality subwoofer, rather than SPL, that even with only 10 inch size can withstand 600 Watt RMS. It is therefore very heavy. (But I have enough power to compensate for it).
Hi res here.
Clean install behind a 10 inch hole in the arm rest and covered with cloth.
Hi res here.
Audison – Amplifier and digital processor.
I have always liked the quality of the (LRx 5.1MT) Audison ABD class amplifier. It is a 5 channel amp producing 2x60, 2x170 and 1x750Watt at 4 Ohm. There is no distortion at any sound level.
The Audison bit-one digital sound processor de-equalizes the oem system and can then be fine tuned through a laptop to suit your needs. You actually have to measure the distance between each speaker and your head for the best performance.
I decided to have everything neatly hidden behind this wall. Even with the enclosure and the huge amp behind it, it can still take enough bags for 4 people.
Hi res here.
The Audison Bit one in car remote allows further adjustment of the sound and allows personal presets. Often CD’s sound much better than the radio, so I simply select a different setting for that.
Hi res here.
Alpine – Monitors and covers.
7 inch Alpine TME M780 headrest monitors as rear entertainment source. In the picture they are zoomed in, so part of the subtitles is lost.
Hi res here.
Leather covers make the monitors less easily spotted by criminals. Hmmm, well I just gave away my secret didn’t I?
Hi res here.
Senergy – Tv and dvd player.
The Senergy 6 DVD changer for movies or live music recordings to be selected with a remote control. Obviously the car has various switch boxes installed for the monitors, AV capability and the AUX port was dealer activated.
Hi res here.
Hi res here.
The Senergy digital tv and radio allow me to receive all common stations and then some, although in my country they are all encrypted, so you need a Digitenne subscription. The picture shows that on screen car messages pop up through the movie image at the bottom and i-drive allows me to change source or channel. Once set I usually change the screen back to GPS and leave the movie to the people in the back.
Hi res here.
Nice little TV antenna with proper reception. There is a second one behind the front wind screen, because cars usually move around a lot ;-)
Hi res here.
BMW USA - Floor and trunk mats.
BMW M5 embroidered floor and trunk mats. We can’t get these in Europe and I can’t order them from Europe. But hey, a board member helped me out here. Gotta love the m5board!
Hi res here.
Some more pictures of the car. Let the pics do the talking.
Hi res here.
Hi res here.
Hi res here.
Hi res here.
Hi res here.
To make the car come alive I uploaded some clips to youtube.
I hope this was both interesting and useful. If you need detailed information (like pricing) from me, the best way is to PM me. General questions I will answer in this thread.
Google+ LinkedIn Facebook Flickr
My email gustav@gtboard.com m5board Member visiting Stockholm, Sweden? PM me to and I'll show you Stockholm! gtboard.com
Gustav is offline   Reply With Quote
The Following 13 Users Say Thank You to Gustav For This Useful Post:
///m\\\ (2nd June 2010), Ashok Arora (31st May 2010), Chrispy (1st August 2010), DarrinB (1st June 2010), FTB (5th November 2010), Infamous Q (4th June 2010), KILLZBUGZ (31st May 2010), mackyfr (31st May 2010), Omarshareef (6th August 2010), S2000 (12th November 2010), usmcrebel (1st July 2010), waleed_wales (31st May 2010), wilhelm (1st June 2010)
Old 31st May 2010, 04:51   #2
KILLZBUGZ
KILLZBUGZ's Avatar
Garage: M5 SSII
Very nicely modded, one of my favourites
KILLZBUGZ is offline   Reply With Quote
Old 31st May 2010, 04:57   #3
KGroschi
Garage: 2008 M5 white
Fantastic car! So beautiful! I got a white E60 M5 and would love to have so much carbon fiber on my car but it's kinda expensive. Thank you for sharing!
KGroschi is offline   Reply With Quote
The Following User Says Thank You to KGroschi For This Useful Post:
Gustav (31st May 2010)
Old 31st May 2010, 05:37   #4
ninjaboym5
Garage: 09 M5 Alpine white
very nice. did you keep the stock exhaust?
ninjaboym5 is offline   Reply With Quote
Old 31st May 2010, 05:40   #5
Msizzle
Msizzle's Avatar
Garage: m6 blue
well done, that is an impressive build
Msizzle is offline   Reply With Quote
Old 31st May 2010, 06:05   #6
sjbdeebo2
sjbdeebo2's Avatar
Garage: 540i
Loving the tasteful mods. Keep the pictures coming!
sjbdeebo2 is offline   Reply With Quote
Old 31st May 2010, 06:46   #7
KGroschi
Question: How is the evosport pulley working? Do you feel the gain? I want to get it put I am not 100% sure yet. Does it have an effect on the warranty?
Old 31st May 2010, 06:59   #8
M5aud
M5aud's Avatar
Garage: E60 M5 Sapphire black
In all honesty this is the best timeline build I have seen in a while. Very good images and documentation.
Car looks very balanced both mechanically and visually.
Thumbs Up!
M5aud is offline   Reply With Quote
The Following User Says Thank You to M5aud For This Useful Post:
Old 31st May 2010, 07:01   #9
Taipan
Taipan's Avatar
Garage: various
Very tasteful! Loving the carbon and also the nicely done hi-fi!
Taipan is offline   Reply With Quote
Old 31st May 2010, 11:12   #10
Shine
Garage: VW Golf IV
Nice write-up! Also very tasteful mods... the most interesting ones can be seen in detail.
Shine is offline   Reply With Quote
Pictures: Individual BMW M5 Messing Metallic with bicolour black Ecru interiour with AC Schnitzer options (prerpare for a different M5...) Gustav E60 M5 and E61 M5 Touring Discussion 20 3rd November 2012 15:19
Member M-bitious Carbon Black BMW M5 in the Netherlands Gustav E60 M5 and E61 M5 Touring Discussion 15 24th April 2010 04:56
Member M-bitious Carbon Black BMW M5 in the Netherlands Gustav Owners Gallery 1 13th April 2010 07:36
Pictures: Individual BMW M5 Messing Metallic with bicolour black Ecru interiour with AC Schnitzer options (prerpare for a different M5...) Gustav Owners Gallery 0 21st February 2009 03:46
