The $6000 Question - Page 3 - BMW M5 Forum and M6 Forums
Old 13th April 2010, 08:20   #21
kweezy31
Garage: M5 E28 Black/Natur
"Moton Club Sport Damper System". That'll take a huge chunk of your budget, but a good handling car is just as, if not more important than a powerful car. But I don't think you'll really have to worry about the power thing
kweezy31 is offline   Reply With Quote
Old 13th April 2010, 08:36   #22
Myke951
Myke951's Avatar
Garage: 944 Turbo White
I know that, but the cost of wheels to lbs shaved off of unsprung weight is not very efficient money wise IMHO if he is merely going for quickest 0-100... I know shaving weight is not equivalent, i was using it as an analogy as hp/weight ratio is changed in the same manner, so obviously there is some similarity. He asked for an opinion on what he wants so i gave him my opinion to what he asked or else i would recommend the suspension mods myself... He may never see the track and just wants an advantage on the street...
Originally Posted by Danish-M View Post
Wheels can improve handling and acceleration! Ever thought of that???
Also, adding power is by no means equivalent to to reducing weight!!! You got that all wrong............ Shaving weight is shaving weight, and will improve your car in every way. Adding power will not!
This car is plenty fast! I would spend my money on improving the cars short comings. The handling, and in most cases the driver..............
$6K IMO would be well spend on:
Springs (H&R)
Camber plates
Sway bar kit (Dinan)
Brake pads (Pagid RS19)
Tires (Anything good and cheap)
HPDE's
More tires
More HPDE's
Spending money on actually driving the car is money well spent IMO. You bought a sick car, why not drive the pants of it around a track??? Who cares about drag racing a Z06 on the hwy??? A Z06 owner can spend 25 cents and ad 100hp anyway.The true joy comes from skillfully spanking an 800hp Z06 on the track....................
2004 Mini Cooper S: Alta supercharger 15% pulley upgrade, Dinan cold-air intake, Skunk2 header back exhaust, RMW CUSTOM TUNE, Alta oil catch can, OMP Strut brace, Eibach pro-kit springs, H-Sport camber links, 19mm Rear sway bar w/ adj. end links, 18 in. Breyton mini magics, 6lbs lighter crank pulley, polyeurathane tranny and engine bushings, wheel Studs, Wilwood BBK... More to come soon!
RIP=White 944 turbo: KKK K-27/6 turbo, upgraded intercooler, Lindsey Racing hardpipes, Autothority MAF, B&B exhaust with 4.5" oval tip, Siemens #55 fuel injectors, Lindsey Racing MaxHP custom Chip set, 3 bar fuel pressure regulator, Re-worked head and slightly overbored pistons, Spec Lightened 6 puck stage 3 clutch, Quaif torque biase differential, Apexi AVC Type-R Electronic boost controller, HKS type-1 turbo timer, Shimmed wastegate, Champion Motorsports adj. bypass valve, Weltmeister front and rear sway bars, Weltmeister strut tower brace, Koni adj. "yellows", unknown springs, Turbo Twist rims, Kumho Ecsta Supra tires... And a couple of more unknown mods...
Myke951 is offline   Reply With Quote
Old 13th April 2010, 08:56   #23
Revo
Revo's Avatar
Garage: 2006 E60 M5 Black on Black
While I don't agree at all with that "this power mod is equal to 130lbs less" mumbo jumbo, I would like to point out something about wheel weights.
Stock M5 tire diameter is 26.9 inches in rear. So the circumference is roughly 85.5 inches. At 200mph, your wheels are rotating at mere 2470RPM. 100mph is (obviously) half that at 1235RPM. 50mph is obviously again half at 617.5RPM.
Stock M5 wheels are light as they are (not 8000 set of Neez QD7 light, but light enough for an OEM wheel). Say (optimistically) you save 10lbs of rotating mass by switching, but like most, you get 20 inch rims, negating some of the benefits of having a lighter wheel (since larger rim means the weight of the wheel is further from the axis of rotating, effectively increasing rotating mass).
So what do you think provides an improvement? A light (underdriving pulley) that is revved to over 8000RPM 7 times on the path to 200mph? (in the OP's case, 3 times to 100mph) or wheels spinning at 2470RPM at 200mph (1235RPM for the OP's 100mph) and are slowly increased to that speed as the car accelerates from a stop.
I'm not saying wheels don't make a difference, cause they make a huge difference - and also help with braking and cornering.
I'm simply pointing out that the OP asked to provide a list of mods to help his car do 0-100.
Considering a full exhaust provides a significant increase in torque, and a pulley reducing rotating mass making a solid difference in the critical gears 1, 2, and 3 where the engine typically winds out quite quickly.
Why don't you buy a set of $6000 wheels and tires and race against the $6000 in power mods and see who hits 100mph first (to keep things even, you must run similar tires, such as PS2's - it would be stupid to compare some drag radials to stock Continentals)?
The M5 is my dad's - but I drive it more than he does!
Revo is online now   Reply With Quote
Old 13th April 2010, 09:01   #24
BMWPower06
BMWPower06's Avatar
Garage: Indy Red ///M5 & ///M3
Actually saving unsprung weight is probably even better than getting a full RPi stage 2. A lightweight 18" set up could save ~20lbs/corner, multiply that by 4 corners = 80 lbs of unsprung mass saved. Convert that to sprung mass using the standard 10:1 ratio and you have the equivalent of roughly 800lbs of sprung mass shaved off the car by just picking up lighter wheels. I'd love to see a full RPi stage 2 take that on
This article explains the above in much more detail:
Unsprung Weight, Part 2
So as I said several posts ago, don't waste your money on these so called performance mods and just get some nice wheels. Hell even a nice set of forged 19s will still save you about ~10lbs/corner
Indianapolis Red BMW ///M5
The Most Important Law of Physics:
A^M=G would be nothing without the power of ///M
BMWPower06 is offline   Reply With Quote
Old 13th April 2010, 09:08   #25
BMWPower06
BMWPower06's Avatar
My 20" forged 3 Piece DPE REAR wheels and tires were a pound lighter than my OEM 19" FRONT wheels and tires. Also, the overall diameter (tire and rim) barely changed from my 19s to 20s. With 20" wheels comes thinner tires.
What does the RPM that the rim or pulley spin at have do with acceleration?? by your logic, I see the following:
.1lb saving for pulley at 8000rpm (8000rpm*.1lb)= 800
10lb saving PER wheel at 2470rpm (2470rpm*10lbs)= 24,700
According to your numbers the rims make a MUCH bigger difference than a pulley. Also, you have 4 wheels and only 1 pulley, so should we multiply 24,700 by 4?
Also, my experience with full exhaust's (on NA cars) has always been a gain of hp at the expense of loss of tq in the low rpms. You always want to have some back pressure to help with low end tq.
Old 13th April 2010, 09:37   #26
Revo
Revo's Avatar
You also need to consider the rate at which the pulley is accelerated.
In first gear the pulley goes from 1500RPM (clutch engagement point a casual start) to 8250RPM. The wheels go from 0RPM (still) to 580 RPM at 47mph. Now lets see, shift to second gear and the engine speed goes from 5000RPM back up to 8250RPM while the wheel speed goes from 580 RPM to 863 RPM. A small increase of 283RPM vs the again, 3250RPM span of the engine.
Also, the weight savings by a pulley is far more than .1lbs, not to mention the reduced load of aftermarket pulleys under-driving.
Secondly, prove to me you can save 80lbs by getting new wheels and tires. First off, when you go from 19 to 20" using the correct size tires (same outer diameter/width) - yes, the barrel of the rim only goes .5 inch further way from the axis of rotation, but it still goes out further. What you lose in this increased torque from this rotating mass totally outweighs the small gain you have by having slightly less sidewall rubber (your contact patch rubber barrel is still the same on both a 19" and 20" tire - the only difference is sidewall.
Going wider than stock further impedes by adding more rotating mass since you are adding weight at the worst point (outer diameter of a wheel - where it has the most effect on rotating inertia).
This is not to mention that a pulley costs about $500 and high end, light weight wheels you seem to referring to cost about 8-10 grand per set.
But again, all that aside, I want PROOF you can save 20lbs per corner. Cause otherwise, I call BS on that one.
Old 13th April 2010, 09:54   #27
Revo
Revo's Avatar
FYI, super lightweight BBS wheels saved a mere 4.5lbs per corner vs OEM wheels.
18lbs total.
Please show me a setup that saved over 4 times that.
Thanks.
Old 13th April 2010, 16:23   #28
Myke951
Myke951's Avatar
Exactly... 18lbs a corner? what are you smoking? unless it is a wheel made of carbon fiber (yes i am aware of them)... Again revo I acknowledge that its not the same as shaving weight, BUT it does share similarities in acceleration through hp/weight ratio... (like a lotus versus an e46 m3 lotus= 2000lbs with 200hp, m3=3300lbs with 333hp)... I think you guys are taking what I said the wrong way... BMWPOWER06 I would LOVE to see your car with your wheels go against an rpi stage 2 car with stock wheels on... lol, itll almost be as good as you saying AFE actually made power...
Old 13th April 2010, 17:39   #29
triplesiks
triplesiks's Avatar
Garage: 2006 E60 M5 Black Sapphire
From everything I have read, it is my opinion that the M5 is pretty close to maxed out unless you go for supercharger. I could see the exhaust. But I doubt I would ever change anything. I like the stock car and if you think 20 horsepower is gonna make the difference in beating someone in a street race, if its that close, you would have to race several times to see who was really faster. A split second on reaction time is worth 20 horsepower. Don't get me wrong I love reading about all the mods and love watching the you tube videos too. I would be tempted to go the Dinan route because your dealer will install and I do not think it voids anything. Good Luck and post a video when you are done.
triplesiks is offline   Reply With Quote
Old 13th April 2010, 17:58   #30
Ahmed
Ahmed's Avatar
Garage: Black C63 AMG P31
Sales Feedback: (4)
You know... for 6k, if you shop from the classified section of members here, you can probably go the whole nine yards! FULL BOLT ON's and wheels too!
2006 E60 M5 Sepang Bronze/Natural Brown/Olive Ash (RIP)
2013 C63 AMG P31 Magnetite Black/Classic Red & Black/Carbon Fibre
Ahmed is offline   Reply With Quote
6000 Miles, 6 quarts of oil, and I cant get used to the SMG PilotMike E60 M5 and E61 M5 Touring Discussion 54 19th April 2008 23:03
Ouch! U$$6000 for a new clutch! 7 speed SMG E60 M5 and E61 M5 Touring Discussion 16 8th March 2007 03:47
E39touring ALPINA B10 MY 2000 6000 mil M5touring reg ALPINABoard.com | BMW Alpina Discussion 5 8th September 2006 18:33
For-Sale: E39 M5 suspension. Used for less than 6000 miles. FAST 5 Parts / Other For Sale or Wanted 1 24th February 2005 02:19
$6000 M5 on eBay dwasifar E39 M5 and E52 Z8 Discussion 2 12th November 2001 20:52
