2006 Continued clutch chatter/transmission problems and I am fed up!! Need advice
Okay, here I go,
Just wondering what people would do in my situation. I have an 2006 (Dec.05 build) which has been having clutch problems lately (I am the original owner). Long story short, my clutch has been chattering lately from a stop to first. Here is the order of the problem:
1) 4-3-06.....Transmission failure light comes on. Car got new software.
2) 12-28-09..Clutch chatter when going from stop into first, along with transmission failure light that appeared. Dealer states both "concerns could not be duplicated"
3) 1-8-10.....Transmission failure light comes on. Car not changing gears right. Dealer replaces clutch, flywheel and accessories.
4) 2-9-10.....Clutch still chattering when going from stop into first. Dealer programs software and says everything is fine now.
5) 3-8-10.....Clutch still chattering when going from stop into first. Take car to different dealer, they verify problem and programs new software.
6) Present....Clutch still chattering, albeit a little less on level take off. More noticeable on hill starts.
I am to the point where I am tired of wasting my time (which is valuable), money and energy to have the same problem keep reappearing, after making countless trips to dealerships for this same problem. Totally fed up!!!
What would everyone else do in my situation? I noticed on the service sheet (from the most recent trip to a dealer), it mentioned if the problem persists, I would need to go for a test drive with a BMW regional rep. More of my time wasted on same problem. It even states the shop foreman feels the problem is STILL more pronounced on hills, even after the new work done. I had a friend mention an attorney and the lemon law (as I live in California), or even post on the internet the continued and all previous problems with my car, so everyone can see who is wanting to buy a BMW.
Dont know about california. But where i am the car would have to still be under warranty to qualify for the lemon law.
Did any of the dealers replace and lubricate the clutch release bearing? If your clutch and flywheel came in a kit, then the clutch release bearing that it included in the kit is not lubricated. They have to physically grease down the bearings.
Technically, the warranty on the car ran out last month, but the latest round of work was and still is under warranty because the problem started while under warranty and continues today.
If you could, I would try to see if your car can be taken back as a lemon, as this problem seems ridiculous, and something you should definitely not have to deal with. An early 06 car often has transmission issues, but these seem way more repetitive than normal. If you do keep the car, I would most certainly get an extended warranty.
Having had not dissimilar faults, my Actuators were replaced and the engine management software updated - essentially having driven the car for 23k miles with clutch judder it hasn now gone, car is next to perfect now. My take is that a lot of the SMG faults lie elsewhere and not with the unit (clutch bearing, flywheel, clutch plate etc.) or associated gearbox software?
It's an 05/05 build - I bought it with 30k miles and it is now on 53k miles on original clutch
Originally Posted by EricM
Okay, here I go,
Need advice please? I am frustrated. Thanks.
Eric
2005 E60 M5 Interlagos blue
So you only updated the software and replaced the actuators? then the problem went away?
Did you ever replace clutch or flywheel? My car had the software updated then the shudder started...
A clutch is really a very simple thing, it needs to release and it needs to engage. When its engaged, if its worn it will slip, you can see that slip by accelerating in a high gear, the engine will rev away faster than the vehicle speed increases.
SMG is just a standard clutch and then instead of a clutch pedal actuators, so its really a question of what is part of the entire system that controls the clutch i.e oil, pump, actuators, clutch etc and eliminate
The problem that you have at a dealership service center is, your $100+/hr can either pay for someone who really understands mechanics and knows how to diagnose or someone at the other end of the spectrum is the tech who just follows the directions my the tech sheet verbatim.
I had a brand new truck that had a wobbling pulley, I took it back twice, first time they replaced the a pulley guide wheel. Next time they called and said they would need it for a few days.... I got it back the next week they had replaced the engine (I had 1500 miles), I read the report and it showed the questions and the answer for the tech replace engine.... crazy!
Scottsdale, Az
Current Rides
2006 M5 - Silverstone II
2006 Range Rover HSE
1968 SS Chevelle (540 hp / 500 ft/lb)
2009 Polaris RZR
Chattering means there is a problem with the way your clutch is releasing, or the fact that maybe some tranny fluid has leaked form your pump onto the clutch.
__________________ 2006 Sepang Bronze/Naturelle Brown E60 M5
Eisenmann Sport Mufflers
Miesterchaft Sections 1 & 2
Evosport Headers
Evosport Pulley
RPi RAM Scoops + Block Off Plates + BMC Filters
CA Auto/AL-Tuning Custom Stage 2 DME Upgrade
Eibach ProKit Springs
20" Breyton Race CS with Yokos
White Angel Eyes, 6000K HID's & LED Plate Lamps
Matte Black Kidney and Fender Grills
StopTech BBK 380mm 6 Piston Front & 4 Piston Rear
ACS RP Roof Spoiler
Vorsteiner RP Splitters
I am familiar with the problems with a clutch. My concern is whether I should raise hell now that this would be my fifth time to take it back for the same problem?
