Old 11th March 2010, 11:44   #1
5seriessport
Garage: 2006 M5 - Alpine White
What size Brembos? Pistons or Surface Area?
What size brembos will fit a stock wheel? I have heard that the 380mm require 20" and the 405mm require 22" wheels.. which I certainly will not be getting.
I can't afford the wheels and brakes at the moment, but am considering the brakes since I ruined my rotors and pads at the track already anyway.
SO, does anyone have any experience with brembos under stock wheels?
Also, am I going to get more power and/or less fade with more pistons or more surface area?
5seriessport is online now
Old 11th March 2010, 15:21   #2
M5Ranger
Garage: 2006 M5 Alpine White
I haven't put Brembos on stock wheels but allow me to disspell mis-information.
You can run 380 mm rotors with 19" aftermarket wheels (well top names, ie. HRE ect...) and you can run 405 mm rotors with 20" wheels. I know because I have them on my white M5. You do not need 21' or 22" (bling) wheels.
With the stockers the problem may come up with the rears. The rear Brembo caliper is much more substancial than the pewmee stock rear caliper and may not clear.
Later I will post a pic of my front 405's with the 20" HRE 590R.
Cheers
Ranger
2006 M5 Alpine White/Silverstone Still alive, I think.(I miss it)
2007 GT3RS ORANGE / BLACK
2006 M5 BLACK / BLACK
FORGED IN A FIRE LIT LONG AGO, STAND NEXT TO ME, YOU'LL NEVER STAND ALONE. FIRST IN, LAST OUT.
YOU DON'T ALWAYS KNOW WHERE YOU STAND, TILL YOU KNOW THAT YOU WON'T RUN AWAY.
YOU HAVE ENEMIES? GOOD. THAT MEANS YOU'VE STOOD UP FOR SOMETHING, SOMETIME IN YOUR LIFE.
W. CHURCHILL
SOCIALISM IS A PHILOSOPHY OF FAILURE, THE CREED OF IGNORANCE, AND THE GOSPEL OF ENVY, ITS INHERENT VIRTUE IS THE EQUAL SHARING OF MISERY. W.CHURCHILL
M5Ranger is offline
Old 11th March 2010, 16:07   #3
Ahmed
Ahmed's Avatar
Garage: Sepang Bronze E60 M5
Sales Feedback: (3)
You can put 380mm 6 piston fronts and 4 picton rears on your stock M5 wheels. All you need are 10mm spacers.
2006 Sepang Bronze/Naturelle Brown E60 M5
Eisenmann Sport Mufflers
Miesterchaft Sections 1 & 2
Evosport Headers
Evosport Pulley
RPi RAM Scoops + Block Off Plates + BMC Filters
CA Auto/AL-Tuning Custom Stage 2 DME Upgrade
Eibach ProKit Springs
20" Breyton Race CS with Yokos
White Angel Eyes, 6000K HID's & LED Plate Lamps
Matte Black Kidney and Fender Grills
StopTech BBK 380mm 6 Piston Front & 4 Piston Rear
ACS RP Roof Spoiler
Vorsteiner RP Splitters
Ahmed is offline
The Following User Says Thank You to Ahmed For This Useful Post:
Revo (11th March 2010)
Old 11th March 2010, 19:15   #4
Jlevi SW
Jlevi SW's Avatar
Garage: 400hp Vorsteiner E92
Send a message via AIM to Jlevi SW
As a good rule, if you have 18" wheels you can fit a 14" system, 19" wheels can usually squeeze a 15" system. That's a rough estimate though because the offset and concavity of the wheel will be the limiting factor. I highly recommend contacting your dealer and requesting fitment templates, which you can then print out, cut up, and hold up to your stock wheels to see!!!
Let us know if you require further assistance
JL
JleviSW.com
1.888.JLEVISW
Jlevi SW is offline
Old 12th March 2010, 03:01   #5
Dbld
Garage: 2006 Interlagos Blue M5
Be careful adjusting total piston area and the front/rear relationship. For track use, you can safely get away with increasing your front piston area a little bit compared to the rear. You don't want to go the other way though (track use sees more weight transfer than you'd see on the road...more weight transfer to the front = less rear brake). If you put too much rear brake on the car you could end up doing hand-brake turns everywhere. ;-) Of course ABS masks this, but it's still not ideal.
Dbld is offline
Old 12th March 2010, 03:14   #6
Dbld
Number and size of pistons have more to do with pad taper problems on the track that's not normally much of an issue on the street. Cooling for track use can be critical though. If overheated, not only does brake efficiency get worse, but pad life can be more than halved.
Also, don't mix drilled and slotted disks by accident. Drilled disks can have quicker initial bite over slotted, and slotted over solid. Solid can give more fade problems for several reasons. Again, ABS can obscure a lot of this for folks not on the track often. A drilled disk on the back with a slotted disk on the front can lead to ABS (on rear especially) on initial brake application due to the better initial bite on the rear. The other way around (drilled front/slotted rear) is a safer bet to avoid ABS intervention.
Sorry - I cannot help with disk/caliper clearance problems, but you could shim a caliper out to a larger diameter disk down the road. The larger disk gives effectively more brake compared to an otherwise equal smaller disk. With that in mind, just the piston sizes in the caliper do not tell the whole story for your brake balance/bias.
I have seen many set-ups with stupidly large rear brakes for track use. This often leads to problems that are challenging to diagnose for those not familiar with how braking systems work.
Hope this helps...
Dbld is offline
Old 12th March 2010, 17:39   #7
Precision Sport
Company Representative for Precision Sport
Precision Sport's Avatar
Garage: BMWs. . .Boosted preferably!
Send a message via AIM to Precision Sport
Sorry to post this here but "5seriessport", can you please e-mail me? My PM feature does not work yet and I can't reply to your PM.
frank(at)precision-sport.com
Thank you and sorry to post this here.
Frank
Precision Sport Industries
www.precision-sport.com
828 Cherry Street
Winter Park, FL 32789
Find us on Facebook!
Follow us on Twitter!
G-Power build thread - http://www.m5board.com/vbulletin/e60...r-updates.html
Second G-Power build thread - http://www.m5board.com/vbulletin/e60...hite-time.html
Precision Sport is offline
Old 12th March 2010, 23:23   #8
Brecus.com
Company Representative for Brecus Motorsport
Brecus.com's Avatar
Garage: Imola E39 M5
The rule of thumb on BBK measurement for wheel clearance is to add 4" to the rotor size to determine wheel clearance. Therefore a 380mm kit would likely need 19" wheels and 405mm would likely needs 20" wheels for the barrel clearance. But, race wheels often have better clearance and stock wheels typically have worse.
Below are the clearance charts for the E60 Brembo BBKs.
The Brembo system uses a directionally vented disc out of the Brembo Racing program. It's larger in diameter and thicker in order to dissapate heat more efficiently. Piston count, by itself will have little bearing on fade. But a longer pad will help with heat management and fade. Below you can see the difference in the pad shapes and size. The Brembo six piston caliper uses a longer, larger pad than the four piston. Because the Brembo disc is a two piece design, the center aluminum hat keeps the heat out of the wheel bearings and helps the system stay cooler overall.
PLEASE EMAIL US FOR PRODUCT INQUIRES
Brecus.com is offline
S14 Pistons / S38-B36 pistons jibbajabba E34 M5 Discussion 7 5th June 2009 16:11
what size are stoptech ST40 pistons? razahyde E39 M5 and E52 Z8 Discussion 1 13th October 2008 23:28
Meguiar’s Surface Care Clinic for Bay Area E28 & E34 M5 owners KLittle E28 M5 Discussion 1 24th November 2004 19:30
Meguiar’s Surface Care Clinic for Bay Area E28 & E34 M5 owners KLittle E34 M5 Discussion 1 14th October 2004 12:57
Meguiar’s Surface Care Clinic for Bay Area E28 & E34 M5 owners KLittle Regional Forums and Events and group meetings for M5, M6 and Alpina owners 1 14th October 2004 12:57
