Slight Vibration around 2250 RPM - what could it be? - BMW M5 Forum and M6 Forums
post #1 of 45 Old 24th February 2010, 05:03 PM Thread Starter
M5Express
M5Express's Avatar
I've had a weird vibration when the car is around 2250 RPM especially in 3rd or 4th gear, but it also does it in 2nd and 5th. Most prevalent when accelarting softly on my morning commute. It goes away after 2500 RPM. It's something new, never done it before. I feel it mostly on the steering wheel since that is my main connection to the car, but it's not exclusively on the steering wheel. Feels like I'm running over very little rumble strips on the road.
My first thought was motor mounts, but I really have no idea. Have any of you been through this?
I had the clutch and flywheel replaced 2000 miles ago.
M5Express
2008 Porsche Cayenne S
Air Suspension
Porsche Dynamic Chassis Control
22" Porsche Sport Technos
2006 E60 M5 Silverstone II - SOLD TO REDGUTZ
K&N Drop Ins
White LED Angel Eyes
LCI LED Tailights
LED License Plate Lights
Custom Alcantara Steering Wheel
Black Kidney Grilles
Rearview Camera and Video Playback
iPhone dock by Spec.dock
Passport 9500ix Hardwired
M5Express is offline
post #2 of 45 Old 24th February 2010, 05:14 PM
M5poeser
M5poeser's Avatar
maybe dirty injectors? or spark plugs!.. try running some injector cleaner, i had this problem in my 545i, but the vibrations were there all the time, not at a certain rpm. GL
///M5
E60 Sapphire Black
Mods:
Rpi Pulleys
AIB 3.0
Rdash LED License Plate lamps
M5poeser is offline
The Following User Says Thank You to M5poeser For This Useful Post:
M5Express (24th February 2010)
post #3 of 45 Old 24th February 2010, 05:36 PM
xraym5
xraym5's Avatar
I had a similar problem, and it turned out that the heat shield was rubbing against the exhaust.
2006 M5--Sapphire black/sepang
Dinan: free flow exhaust, Stage 3 engine software, high flow throttle bodies, high flow air mass meter/intake Assemblies, stage 2 suspension, 13% underdrive crankshaft pulley, 5.8 liter stroker engine, Dinan middle exhaust section, custom headers (I think I am finally done)
2011 Space Gray ZCP E92 M3; two-toned black and red interior; Dinan 4.6 liter stroker engine, intake, exhaust, midsection, pulley, and throttle bodies.
xraym5 is offline
The Following User Says Thank You to xraym5 For This Useful Post:
post #4 of 45 Old 24th February 2010, 05:37 PM
ChaoticZen
ChaoticZen's Avatar
Maybe one or more tire need to be rebalanced? Have you hit any potholes recently maybe your rim was bent VERY slightly.
The search of that perfect E39 M5 has ended...
ChaoticZen is offline
post #5 of 45 Old 24th February 2010, 05:38 PM Thread Starter
M5Express
M5Express's Avatar
Interesting.
M5Express
Air Suspension
K&N Drop Ins
LCI LED Tailights
post #6 of 45 Old 24th February 2010, 05:42 PM Thread Starter
M5Express
M5Express's Avatar
No, I doubt it. I'm a tire pressure fanatic. I have a big, vertical Ingersol Rand compressor at home and I always have them perfectly inflated and inspect them for the smallest of nicks. Plus, I'm the only one that drives the car and haven't hit anything lately. Plus it's always at the same RPM, not the same speed, which tells me it's an engine or drivetrain issue.
M5Express
Air Suspension
K&N Drop Ins
LCI LED Tailights
post #7 of 45 Old 24th February 2010, 06:33 PM
fenderltd
fenderltd's Avatar
I had this exact same problem about 1.5 years ago with a Audi A8L. Drove me crazy. Turned out to be a bent exhaust heat shield. Can you pin point the area roughly that its coming from?
fenderltd is offline
post #8 of 45 Old 24th February 2010, 06:46 PM
ChaoticZen
ChaoticZen's Avatar
Got ya, only reason I brought it up is that I have a very similar issue but only on the same speed, not rpm and I cannot visually tell my rim was bent until I went in for a balance and the tech there told me. Sorry couldn't be more helpful!
post #9 of 45 Old 1st March 2010, 02:41 PM Thread Starter
M5Express
M5Express's Avatar
Dropped the car off at the dealer on Saturday. I went the extra step of writing the speed in each gear where it vibrates. Hopefully it eliminates the SA calling to tell me the couldn't duplicate the problem. Will post results of the issue.
M5Express
Air Suspension
K&N Drop Ins
LCI LED Tailights
post #10 of 45 Old 2nd March 2010, 03:59 PM Thread Starter
M5Express
M5Express's Avatar
Arrrgh! Got a call from the dealer. They cannot duplicate the problem. I'm going over there to take a spin with the tech and personally show him the problem. This sucks.
I'll ask them to lift the car and check the heat shields. I wasn't going to tell them to try that (let 'em figure it out on their own), but at this point I just want the car fixed. Updates coming later today.
M5Express
Air Suspension
K&N Drop Ins
LCI LED Tailights
Slight Vibration from a Stop. RCOD Coming Soon? M5Express E60 M5 and E61 M5 Touring Discussion 4 3rd September 2009 08:29 PM
slight lag at 4000 rpm eljockvis E39 M5 and E52 Z8 Discussion 12 3rd June 2006 12:23 PM
slight binding sound and vibration thru steering wheel? EdP E39 M5 and E52 Z8 Discussion 13 9th May 2006 05:27 PM
Question: Slight vibration hum inside steering column? ATLANTA M5 E39 M5 and E52 Z8 Discussion 0 28th October 2005 11:55 PM
slight vibration when braking at speed steve adams E39 M5 and E52 Z8 Discussion 12 5th January 2002 03:02 AM
