Reference tool.... - BMW M5 Forum and M6 Forums
Old 28th November 2009, 01:19   #1
07M5IntlgsBlue
Garage: 07 M5
Reference tool....
Can anyone tell me where I might find a cross reference tool that will tell me which vehicle model/year wheels are interchangeable with each other? ie.. Can I take 18" wheels off an 02 39 and put them on a 07 e60 etc..
Thank you for your consideration.
07M5IntlgsBlue is offline   Reply With Quote
Old 28th November 2009, 09:10   #2
Vodyk
Vodyk's Avatar
Garage: E60 M5
Yikes. Don't know of a tool/website that will tell you that.
This is how i work it:
Bolt Pattern has to be 5x120
Hub size can be 72.5 (e60 default) or 74 (e39 uses 74 and you would need hubcentric rings, which is just little plastic piece to fill in the little bit from 72.5 to 74)
Will the wheel clear the rotors/calipers: common problem however new cars seem to give a lot more clearance with the different wheel designs so on the e60 this wont be a real problem. E39 bbs RGR's will not clear BBK for instance. Really just looking on the forums and asking around will answer this. Like i said I really don't know much that wont clear on the e60
offset: stock is 8.5 et 12 9.5 et 28. Lot of aftermarket wheels for our cars w/o using spacers run 9 et 6-9 10.5 et 27-29 So i like to play in these ranges, and figure out what size spacer would take to get to or close, without going past the more aggressive sizing. If i need a larger spacer then 15mm i give up on the rim.
I think thats it.
To answer your question:
E39 will require hubcentric rings. 74-> 72.5
Offset is 8 et 20 9.5 et 22
Which if you were to compare vs our stock rims:
Front: -2mm innter clearance +14mm outer clearance. Which would fit but would probably want spacers! To make them look good/aggressive you would need a hefty size spacer like 25mm
Rear: +6mm inner clearance -6mm outer clearance. Spacing should be fine. depending on how you spacer the front you may want to make the rear even. If you went 25mm front spacer i would follow the rear with a 5mm.
Most 18' rims should clear our rotors/calipers and with spacers i can't imagine a problem. I wouldn't recommend this setup though as the front would have a large spacer.
Vodyk is offline   Reply With Quote
Old 28th November 2009, 17:48   #3
07M5IntlgsBlue
Garage: 07 M5
Thank you Sir, a very helpful reply!
WTB: BMW Scanning Tool (PEAKE TOOL? BAVAUTO SCAN? AUTOXRAY?) weichihlin Cars For Sale or Wanted 0 2nd June 2007 10:56
Fuse Reference Chart Digi E60 M5 and E61 M5 Touring Discussion 8 2nd May 2006 16:58
Dension IceLink Install reference t10001 E39 M5 and E52 Z8 Discussion 2 24th January 2006 13:14
Reference No. for ///M floormats? Jad E60 M5 and E61 M5 Touring Discussion 0 31st August 2005 09:59
Shop reference for Orange County/LA Vincent00 E34 M5 Discussion 3 28th November 2002 06:30
