Old 4th November 2009, 17:47   #1
spinny
Garage: 2007 M5
Those with a 3.91 diff please read
At 80MPH in 7th what do your RPMs sit at?
Thank you.
spinny is offline
Old 4th November 2009, 20:44   #2
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
Thank you.
If you give me the tire rolling diameter in inches (or tire size, I can compute the rolling diameter) and 7th gear ratio, I can run a program and give you the answer. From memory, stock is 3.62, so you can multiply your rpms at that speed by 1.08 (3.91-3.62/3.62) +1) and you should be very close.
gsfent is offline
Old 4th November 2009, 20:46   #3
spinny
Garage: 2007 M5
Stock tire size
spinny is offline
Old 4th November 2009, 22:12   #4
BMWPower06
BMWPower06's Avatar
Garage: Indy Red ///M5
Send a message via AIM to BMWPower06
i think 7th gear is .83
Indianapolis Red BMW ///M5
The Law of Automotive Physics:
A^M=G would be nothing without the power of ///M
BMWPower06 is offline
Old 4th November 2009, 22:59   #5
gsfent
gsfent's Avatar
Stock tire size
Well, since I have an E39, I can't go outside and look. But I will look it up and post here for you.
Edit:
According to TR, standard rear is 285/35-19, so rolling diamter is 26.9 inches. Assuming full lock up in SMG as it has no torque converter for slippage, 3000 rpm is 80 mph (79.9) with the 3.91. Since the BMW speedo is usually a little optimistic, you may see a slightly higher speed reading at the rpm.
gsfent is offline
Old 5th November 2009, 00:25   #6
spinny
Garage: 2007 M5
Wow, my car has a 3.91 rear!
Edit:
Fail haha I have a 3.62 according to these calculations:
http://www.csgnetwork.com/multirpmcalc.html
spinny is offline
Old 5th November 2009, 03:57   #7
gsfent
gsfent's Avatar
Edit:
Engine RPM Calculator
My bad, I put the wrong diff ratio down. That is in fact 3.62. The 3.91 would be 74 mph at 3000 rpm. 80 mph would be about 3250 rpm.
gsfent is offline
Old 5th November 2009, 15:59   #8
Vodyk
Vodyk's Avatar
Garage: E60 M5
Send a message via AIM to Vodyk
I checked mine. Its around 3100 but clearly OVER 3k.
08 ///M5 Black Sapphire/Black
Performance: Dinan 3.91 Diff / Exhaust / ECU | Evosport Pulleys | RPI Scoops / Block-Off Plates | BMC Filters | CF Remove
Suspension: KWv3 Coilovers | Dinan CF Strut Brace / FRC System / Rear Anti-Roll Bar
Wheels: HRE P40 19' Black/White | Mich PS2 F:255/40 R:285/35
Exterior: H.I.D. AngelEye Kit | Matte Black Grills | CF Badges | 20% Lumar Tint
Interior: Hardwired V1
Coming Soon: Laser Interceptor Laser Jammers
Vodyk is offline
Diff Bushing & Guibo - Get Dinan Diff Reinforcement & Flywheel - Thoughts? VetteRacer E39 M5 and E52 Z8 Discussion 0 4th June 2009 12:38
Barter Trade: Wanted Dinan 3.91 Diff / Stock Diff + Cash SBM6 For Sale or Wanted 4 14th January 2009 02:09
MK4 Nav won't read DVDs but will read CDs Robstar E39 M5 and E52 Z8 Discussion 11 23rd February 2007 11:20
One More Diff Question...M-Diff on M5?? Yupkwondo E39 M5 and E52 Z8 Discussion 4 10th April 2002 01:30
OEM BMW M3 Diff vs. M5 diff Le Mans E39 M5 and E52 Z8 Discussion 6 18th August 2001 02:32
Page generated in 0.10475 seconds with 11 queries
