Old 3rd November 2009, 19:26   #1
M5 Roggan
M5 Roggan's Avatar
Garage: Silver Shadow 6 (M6 silver grey)
"Check" & "BC" buttons rattle??
Looking for a solution on a very small but somewhat annoying problem I have (guess i should be lucky to only have this kind of issues )
The two small buttons on the indicator lever behind the wheel for the "Check" messages and "BC" for browsing through the board computer (time/temp, range, oil level etc) are rattling at certain speeds in my car... It started after fitting 20" wheels. The sound occurs on rougher tarmac and at certain speeds... I don't run very high pressure in my tires, the vibrations are only very subtly noticable when I hold my finger to the indicator lever itself. Currently I just hold my fingers on the buttons to make it quiet hehe.
Before I isolated the problem to these buttons I though it came from somewhere inside the fan/vent on the driver side or there around.
- Has anyone had the same problem and found a good workable solution?
Im thinking about putting a very small piece of cotton or something like that behind the buttons to see if that helps, but it might jam the button if I do too much and then it would be hard to get it out... Hence the question to get an answer from someone who has done some trail and error already Like I said its a small issue, but with such a otherwise solid quality product as the M6 a sound like that can ruin some of the quality and solid feeling!
_
M5 Roggan is offline
Old 3rd November 2009, 19:31   #2
AGS
AGS's Avatar
Garage: 2009 Carbon Black M5
_
Had the same problem on my '06 M5, and had my dealer repalce the stalk at no change (but I was still under warranty). Have not found any self-implemented fix given how small the buttons are.
AGS
Current:
Previous:
2006 M5
2003 M5
2000 540i6
1998 Grand Cherokee 5.9 Limited
1990 Eagle Talon TSi AWD
1978 RX-7
AGS is offline
Old 3rd November 2009, 19:48   #3
M5 Roggan
M5 Roggan's Avatar
Thanks for the feedback, I guess this is a common issue, at least on 05 and 06 models. I dont think i want to find out what BMW would charge to replace the complete stalk incl labour as I no longer have the new car warranty...
Just had a look in the car and the buttons are hollow from the rear, so it should be possible to put something there to either make them heavier or fill the gap so they don't start to vibrate.
Old 3rd November 2009, 20:14   #4
M5Express
M5Express's Avatar
Garage: 2006 M5 Silverstone II, Full Merino, HUD, Active Seats, Rear & Side Shades
This is a very common problem. Some people have put a black rubberband around the stalk to eliminate the noise, but now you have a black rubber band. Choose your poison. Hope this helps!
M5Express
2006 E60 M5 Silverstone II
CF Delete
K&N Drop Ins
White LED Angel Eyes
LCI LED Tailights
LCI LED License Plate Lights
Custom Alcantara Steering Wheel
M Sprint Booster
Black Kidney Grill
M5 - ML500 - HUMMER H2 - TIARA 3600 OPEN - 1977 MONGOOSE MOTOMAG BMX
M5Express is offline
Old 4th November 2009, 15:41   #5
LJ Martin
Garage: 06 M5 black/black 94 740il black, 69 Corvette red, 03 G35 Black
I have an 06 with the same problem. I think I'll try some slicion spray if that don't work I'll turn the rev's or stereo up.
LJ Martin is offline
Old 4th November 2009, 17:22   #6
chastee1
Garage: E60 BMW M5 Indianapolis Red Metallic, '69 543ci stroker Dodge Dart, '86 Mustang SVO
Even though it is out of warranty it is likely recently out of warranty, right? In the US dealers have a "good faith" account and can sometimes cover "warranty" work on cars that are just over the miles or timeline. It is worth asking the dealer if they would cover this as a warranty claim - assuming this kind of thing can be done at the companies' discretion in Sweden as well.
chastee1 is offline
Old 4th November 2009, 17:34   #7
Copper
Garage: 2009 BMW M5 - Gray
I confirmed that this is the source of my little rattle today on my drive to the gym. I'll have the dealer replace the unit when I bring it in to have the OEM iPod interface installed.
Thank you for helping me isolate this! I was thinking it was one of the buttons on the steering wheel. My M5 is a 2006 model.
Copper is offline
Old 4th November 2009, 18:57   #8
M5 Roggan
M5 Roggan's Avatar
Since my car is an import from Germany I very much doubt that BMW Sweden (who have been robbed of their margins) will give me goodwill for something like this.
However this is just a small and issue, I can think of at least 3-4 ways to solve it. Since the buttons are hollow and one of the reasons why they vibrate is based on their low inertia i was thinking of sticking something small and heavy to the back of them... Ill post on my solution when its done unless someone posts a solution that has worked for them before I do
Old 6th November 2009, 00:03   #9
Stormster
Garage: M5
Have the same problem! REALLY annoys me! Stupid I know....
Would love to know an easy fix. Have the £100 excess for my warranty so will get stalk replaced next time I have another claim.
Stormster is offline
Old 6th November 2009, 00:35   #10
hp99hp
Garage: E46 m3
I had the dealer replace mine under warranty.
hp99hp is offline
Introduction and E34 "steering" & "wheel" question BESPOKE M5 E34 M5 Discussion 3 9th July 2009 01:08
"Engine Malfunction: reduced power!" & "Increased Emissions" OTDoc E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 16 2nd November 2008 00:15
"Engine Malfunction; Reduced power!" & "Increased Emissions" OTDoc E60 M5 and E61 M5 Touring Discussion 16 9th August 2008 04:25
Difference between "M" and "POWER" buttons? Blue Angel E60 M5 and E61 M5 Touring Discussion 15 23rd April 2008 03:54
Steering wheel buttons used to "X" and now they "Y" Redshift E39 M5 and E52 Z8 Discussion 1 18th April 2004 21:31
Page generated in 0.11208 seconds with 11 queries
