Old 30th October 2009, 19:43   #1
bmhusted
Garage: '06 M5 Sapphire Black on black
Launch Control Not Working
I've had my M5 for about one year, got it as a CPO. Since I've owned it, I've used launch control 3 or 4 times. I was at a light a couple of days ago and just decided to take of the DSC, put it in S6, hold the SMG forward and hit the gas (not actually intending on launching). I noticed the car crept forward, meaning the clutch was engaging instead of reving to 1,500, the US spec limit. I've tried this a couple of times now and it's doing the same thing. Any idea why?
I needed to have some work done on it probably 2 - 3 months ago, it was showing 5 or 6 faults at once. Took the dealer a while to figure it out and this is the first time I've tried Launch Control since then. Could this be a software issue??
I know the computer keeps track of the number of times launch control was used but I haven't used it much, of course I can't speak for the previous owner.
I'm about to call the dealer and have them look at it...seems like they should since BMW did build this funtionality into the car.
bmhusted is offline
Old 31st October 2009, 03:31   #2
avlnch
avlnch's Avatar
Garage: 2008 E60 BMW M5
Make sure of the following, and perform them in these steps:
Do not hit the M button (for the sake of this test).
Press POWER
Press DSC
Press + on SMG Drivelogic Setting to #6
- Make sure the car is STOPPED, not rolling. Once it is stopped, let your foot off the brake (if you won't roll back)
- Hold the shift lever forward ( - )
- Apply throttle slowly - make sure the revs are increasing and the car isnt moving - then put the pedal to the floor
- With the pedal to the floor, a hand on the wheel, let go of the shifter
- You should have launched
I know you tried it, and have done it before, but do it in those steps. If that does not work, bring it in to the dealer.
2010 BMW ///M5 INDIVIDUAL {Frozen Grey/Platinum/Platinum Alcantara/Piano Black Trim} - IN PRODUCTION!!!
~Mods: HRE 20" P41 [Black&MachinedFace], Eibach Pro-Kit Springs
2008 BMW ///M5 N. AMERICA {Black Sapphire/SilverStone II/Black Alcantara/Aluminum Trim} - LEASE UP 01/2010
~Mods: Black Grills, Black Gills, Black Roundels, White AngelEyes, Charcoal Filters Deleted, RPI Scoops, BMC Filters, DINAN Software, DINAN Exhaust, DINAN 13% Pulley
Other Vehicles: 09 MERC S65 AMG [BLACK], 09 MERC S65 AMG [WHITE], 09 MERC SL63 AMG, 07 BMW ALPINA B7
Previous Vehicles: 08 MERC S63 AMG, 06 RANGEROVER S/C
avlnch is offline
Old 31st October 2009, 03:33   #3
avlnch
avlnch's Avatar
Also, just to clear up any rumors:
- The dealer may be able to track how many times you use Launch Control
However
- There is no restriction on how many times one can use the feature
- Your warranty does not "expire" if you use it more than 3 or however many times
- The dealer will not refuse to replace your clutch just because you use LC, however if there is excessive wear (you use it all the time) then there is a possibility that they will refuse. This applies to the same senerio as one track driving their car, fading the pads, and asking BMW to replace them.
avlnch is offline
Old 31st October 2009, 10:03   #4
hbpetrides
hbpetrides's Avatar
Garage: BMW M6, silver grey
Send a message via AIM to hbpetrides Send a message via Skype™ to hbpetrides
Just a quick reminder, not sure if you have discored it, the car will neither engage M mode or activate launch control when the temperature is not hot enough.
Just making sure you dont try this when the car is still rather cold.
musclecar
hbpetrides is offline
Old 31st October 2009, 20:28   #5
Revo
Revo's Avatar
Garage: 2006 E60 M5 Black on Black
The car engages M mode fine...M mode is just a series of pre-defined settings. It will not, however, release full S6 shifts until completely warm.
Revo is offline
Old 31st October 2009, 21:21   #6
bmhusted
Thanks everyone for the input. I'm going to head out this afternoon and give it another shot and see what happens! I'll report back.
bmhusted is offline
Old 31st October 2009, 22:33   #7
BMWPower06
BMWPower06's Avatar
Garage: Indy Red ///M5
Send a message via AIM to BMWPower06
Make sure the engine is up to full operating temperature. Otherwise LC will not work
Indianapolis Red BMW ///M5
The Law of Automotive Physics:
A^M=G would be nothing without the power of ///M
BMWPower06 is offline
Old 1st November 2009, 00:29   #8
moonbeamer
Garage: 2007 E60 M5 WHITE
launch mode? you mean burnout mode, , I have used it maybe twice in 2 years with disappointment.... you should be able to use with DSC MDM enabled, along with actual control of the clutch and throttle to get a quick and controlled launch and not a smoke show.
moonbeamer is offline
Old 1st November 2009, 04:43   #9
M Junkie
Garage: 04 m3 smg
if the car is creeping when attempting to use lc i suspect its because you werent on level ground and or stopped fully. if the car isnt stopped/even after releasing brake it wont go fully into lc.
chuck
M Junkie is offline
Old 1st November 2009, 04:48   #10
Revo
Revo's Avatar
I don't understand what it is with the car moving. The system will hold the brakes for you (similar to hill start assist) until you release the clutch. If LC is properly engaged it shouldn't roll at all.
I notice a few of you have the sequence for launch control mixed up.
Once in P500 (S or regular), DSC off, S6 in first gear, with your foot STILL on the brake, push the gear lever forward and hold it. After you are holding the lever forward move your foot over and push the gas down until it kicks. If you press slow, it is "optimal launch mode" and pushing fast is "burnout mode." (For those with US launch controls, I don't think it matters - 90% of the times both result in the car bogging anyway!)
Revo is offline
Tags
control, launch, malfunction, working
Launch control not working properly?? Canadian car Interlagos///M5 E60 M5 and E61 M5 Touring Discussion 4 17th July 2009 23:50
Launch Control not Working.. mods? Rambino E60 M5 and E61 M5 Touring Discussion 6 25th March 2009 15:52
Launch control not working ttm6 E60 M5 and E61 M5 Touring Discussion 36 24th September 2007 16:14
Launch control not working ttm6 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 7 20th September 2007 03:22
Why isn't my launch control working? marwan E60 M5 and E61 M5 Touring Discussion 14 12th January 2006 10:57
Page generated in 0.12055 seconds with 11 queries
