Old 18th June 2009, 22:01   #31
hbpetrides
hbpetrides's Avatar
Garage: BMW M6, silver grey
Send a message via AIM to hbpetrides Send a message via Skype™ to hbpetrides
And all this time I used to cover the car with a blanket
musclecar
hbpetrides is offline
Old 18th June 2009, 23:45   #32
/\/\5Power
/\/\5Power's Avatar
Garage: M5 Silverstone/Silverstone
Send a message via MSN to /\/\5Power
Originally Posted by Foothills_M5fan View Post
If it is the first cold start of the day, I might let the engine run for about 1 minute while the RPM drops below 1000 and the idle smooths out, then I go. I usually use the time to make sure I have everything I need before I leave home or to lock up the house.
I do the same on the first start of the day. Let the engine run till the RPMs fall below 1000 and then drive. Then the whole day its just drive and go. Is this okay?
/\/\5Power is offline
Old 24th June 2009, 16:13   #33
Ahmed
Ahmed's Avatar
Garage: Ex- E39 M5
Also remember, idling alot can mess up your exhaust system!
2006 Sepang Bronze/Naturelle Brown E60 M5
Eisenmann Sport Mufflers
Miesterchaft Sections 1 & 2
Evosport Headers
Evosport Pulley
RPi RAM Scoops + Block Off Plates + BMC Filters
CA Auto Software
Eibach ProKit Springs
20" Breyton Race CS with Yokos
White Angel Eyes, 6000K HID's & LED Plate Lamps
ACS Roof Spoiler
Ahmed is online now
Old 24th June 2009, 19:54   #34
wilsodh
wilsodh's Avatar
Originally Posted by RussRamz View Post
Yes, get in and go.
The issue with warming the car at idle is that NONE of the other components are warmed. If you allow the engine to warm to normal temperature and then blast off down the autobahn, the gearbox and differential are still COLD! So, follow the instructions in the manual and you'll be fine.
I understand the differential warm up concept, but why is it deleterious to the gearbox/differential? In either case (driving immediately with cold engine or driving after warm up idle), the gearbox/differential are cold, and the warm up kinetics of these components would be essentially the same.
I guess common sense would be that you don't blast off until all components are at operating temperature. But that doesn't get at why idling per se is frowned upon...
Any insights?
Dave
'00 Royal Red/black/walnut M5
'El Diablo'
’00 Black/black DA s/c M5
Carrillo rods, Arias pistons,
Schrick cams, Vortech T-trim,
Supersprint headers/exhaust,
wilsodh is offline
Old 24th June 2009, 21:54   #35
keang24
keang24's Avatar
Garage: E60 M5 SG
Please elaborate how idling can affect the exhaust.
Warming up the car idle won't help tranny and other components other than bringing the oil temp to the level, but it shouldn't hurt.
The Good Die Young
R.I.P. BALL...11/15/88-06/22/06
keang24 is offline
Old 24th June 2009, 23:52   #36
Myke951
Myke951's Avatar
Garage: 944 Turbo White
Send a message via AIM to Myke951
90% of engine wear is caused during intial startup due to insufficient lubrication... This is why i make sure i do not drive my car for at least 2 min after i crank the engine, so i limit that amount of wear and ensure a longer lifespan... Also, never buy a car from a woman as i always see them take off as soon as they start the car up, it angers me whenever i see it...lol
2004 Mini Cooper S: Alta supercharger 15% pulley upgrade, Dinan cold-air intake, Skunk2 header back exhaust, RMW CUSTOM TUNE, Alta oil catch can, OMP Strut brace, Eibach pro-kit springs, H-Sport camber links, 19mm Rear sway bar w/ adj. end links, 18 in. Breyton mini magics, 6lbs lighter crank pulley, polyeurathane tranny and engine bushings, wheel Studs, Wilwood BBK... More to come soon!
RIP=White 944 turbo: KKK K-27/6 turbo, upgraded intercooler, Lindsey Racing hardpipes, Autothority MAF, B&B exhaust with 4.5" oval tip, Siemens #55 fuel injectors, Lindsey Racing MaxHP custom Chip set, 3 bar fuel pressure regulator, Re-worked head and slightly overbored pistons, Spec Lightened 6 puck stage 3 clutch, Quaif torque biase differential, Apexi AVC Type-R Electronic boost controller, HKS type-1 turbo timer, Shimmed wastegate, Champion Motorsports adj. bypass valve, Weltmeister front and rear sway bars, Weltmeister strut tower brace, Koni adj. "yellows", unknown springs, Turbo Twist rims, Kumho Ecsta Supra tires... And a couple of more unknown mods...
Myke951 is offline
Old 24th June 2009, 23:57   #37
Myke951
Myke951's Avatar
i wonder why you arent suppose to let it idle?
Myke951 is offline
Old 25th June 2009, 00:39   #38
Dick Fidd
Dick Fidd's Avatar
Garage: 06 M5 Silverstone/Silverstone
I use a little ky around the exhaust - she's ready to go after that.
Dick Fidd is offline
Old 25th June 2009, 18:17   #39
DoctorWill
DoctorWill's Avatar
Garage: '08 M5 Alpine White
Send a message via MSN to DoctorWill
My engine chokes a little when cold, does that happen to others as well?
August 25, 2008 E60 ///M5 Alpine White, Eisenmann Race Exhaust
January 2006 Lexus GX 470 Silver
12/2005-12/2008 Toyota 4 Runner White
6/01-10/6/07 Porsche Boxster Glacier White
7/26-7/27/08 Porsche 550 Spyder Silver - RIP
7/1, 2007 - 5/12/08 Mercedes SL550 Black - RIP
DoctorWill is offline
Old 25th June 2009, 20:22   #40
Streetking
Streetking's Avatar
Garage: '08 M5 white
j/k...
Streetking is offline
Where's the warm air? jajo E39 M5 and E52 Z8 Discussion 16 5th December 2008 06:50
Warm weather oil vics E39 M5 and E52 Z8 Discussion 11 14th February 2008 06:34
No warm up! Why? djtroy E39 M5 and E52 Z8 Discussion 25 14th May 2006 11:57
Warm up times Black M5 Off Topic Forum 0 17th March 2002 06:17
Warm Hearted Thanks M PHATIC E39 M5 and E52 Z8 Discussion 5 31st March 2001 21:10
Page generated in 0.13250 seconds with 11 queries
