Old 12th July 2009, 17:53   #291
Streetking
Streetking's Avatar
Garage: '08 M5 white
Originally Posted by xraym5 View Post
I believe you are correct. At the same time, there is something psychologically appealing about Dinan using an "almost new" block for the "new" engine.
It's better to use a "seasoned" block than a new one, especially when you are stroking, changing pistons ect. In my 1700+ hp Supra, I always use season blocks when we freshen up the motor.
SW
Streetking is offline
The Following User Says Thank You to Streetking For This Useful Post:
M6SCSMD (12th July 2009)
Old 12th July 2009, 17:55   #292
juber
juber's Avatar
Garage: E60 M5 - Silverstone II
SW
HOLY DOG! 1700 Hp!!!!!
Sorry abit off topic but any pics?
juber is offline
Old 12th July 2009, 18:24   #293
ur20v
Garage: e60 M5 (June 05 Build) Black on Black
SW
Yep fully agree! I know BMW and others used to leave the block castings out side to 'age'/relax before machining for special applications.
Better a good old engine core than a brand new one.
Jay
ur20v is offline
Old 12th July 2009, 20:44   #294
Gustav
Administrator
Gustav's Avatar
Thanks for your information.
Originally Posted by Sauvage View Post
Yeaeven though the interior is new, everything else is reused, i've switching over everything I can from our original engines to the stroked just to be safe. Water pump, vanos pressure pipe, lateral oil pumps, oil level sensor.
Gustav is offline
Old 12th July 2009, 20:45   #295
Gustav
Administrator
Gustav's Avatar
Let us know when you start the project CONGRATS!
Originally Posted by slowing View Post
im keen to be third in china, PM sent~~
PENN
Gustav is offline
Old 12th July 2009, 22:01   #296
Myke951
Myke951's Avatar
Garage: 944 Turbo White
Send a message via AIM to Myke951
search for his other threads or go to the boost logic website.. his is the car that has the texas mile record...
2004 Mini Cooper S: Alta supercharger 15% pulley upgrade, Dinan cold-air intake, Skunk2 header back exhaust, RMW CUSTOM TUNE, Alta oil catch can, OMP Strut brace, Eibach pro-kit springs, H-Sport camber links, 19mm Rear sway bar w/ adj. end links, 18 in. Breyton mini magics, 6lbs lighter crank pulley, polyeurathane tranny and engine bushings, wheel Studs, Wilwood BBK... More to come soon!
RIP=White 944 turbo: KKK K-27/6 turbo, upgraded intercooler, Lindsey Racing hardpipes, Autothority MAF, B&B exhaust with 4.5" oval tip, Siemens #55 fuel injectors, Lindsey Racing MaxHP custom Chip set, 3 bar fuel pressure regulator, Re-worked head and slightly overbored pistons, Spec Lightened 6 puck stage 3 clutch, Quaif torque biase differential, Apexi AVC Type-R Electronic boost controller, HKS type-1 turbo timer, Shimmed wastegate, Champion Motorsports adj. bypass valve, Weltmeister front and rear sway bars, Weltmeister strut tower brace, Koni adj. "yellows", unknown springs, Turbo Twist rims, Kumho Ecsta Supra tires... And a couple of more unknown mods...
Myke951 is offline
Old 4th August 2009, 00:11   #297
Gustav
Administrator
Gustav's Avatar
Guys, we need some updates from you guys
Best regards Gustav
Gustav is offline
Old 4th August 2009, 00:53   #298
M6SCSMD
M6SCSMD's Avatar
Garage: 2008 M6 Alpine White Black Interior with Carbon Fiber
I should be done with the break in period in a week or two. Then it goes to the dealer for service and to be put on the dyno. After that the real fun begins. I have been out of town, so the break in has been slightly longer for me.
Scott
Modifications: (Installed 06/09)
-Dinan High Flow Air Mass Assemblies
-Dinan Throttle Bodies
-Dinan Free Flow Exhaust
-Dinan 13% Underdrive Crankshaft Pulley Kit
-Dinan 5.7L Stroker Engine
-Passport 9500ci
M6SCSMD is offline
The Following User Says Thank You to M6SCSMD For This Useful Post:
Gustav (4th August 2009)
Old 4th August 2009, 05:24   #299
M5Ranger
Garage: 2006 M5 Alpine White
I know that I'm the undesireable and disliked but it has been very quiet.
Come on guys beat that badboy like a rented mule.
Cheers gents
Ranger
2006 M5 Alpine White/Silverstone
Upgrades:
Engine: SS headers, Evosport power pulley, ASR ECU remap,
ASR custom air intakes, Dinan throttle bodies, ASR Engineering NOS kit
Exhaust: ASR Engineering Gen. II exhaust.
Suspension: H & R sport spings,Dinan front/rear CF strut braces.
Wheels: HRE P40 w/ 275/30/20 and 305/25/20.
Exterior: Vorsteiner CF vented hood, Vorsteiner CF front spoiler,
ACS rear deck lid spoiler, front kidney grill & side gills in CF.
Brakes: Brembo GT kit, (F) 6 piston monobloc calipers w/ 16"
rotors & (R) 4 piston monbloc calipers w/ 15" rotors.
Interior: ACS titanium CF trim.
Dyno results straight motor 460 rwhp, on nitrous 581 rwhp/461 lb/ft rw torque.
ASR TT S85 FULL ENGINE BUILD COMING
2007 GT3RS ORANGE / BLACK
2006 M5 BLACK / BLACK
2010 GT3RS DEPOSIT IN FOR AN ALLOCATION
M5Ranger is offline
Old 4th August 2009, 15:54   #300
georgefu
Garage: 2006 M5 black
core charge
Has everybody here got their core charges back for the engine and throttle bodies?
georgefu is offline
45 minutes discussion with Dinan on the V10 stroker engine + news that there will be a stroker Dinan M3 V8! Gustav E60 M5 and E61 M5 Touring Discussion 24 30th December 2008 14:12
Two new official Dinan Engineering Video: BMW M3 | M5 | M6 Tecknology on the V8 | V10 stroker and Dinan History and Dinan HQ Walkaround Gustav E60 M5 and E61 M5 Touring Discussion 7 28th November 2008 11:58
Two new official Dinan Engineering Video: BMW M3 | M5 | M6 Tecknology on the V8 | V10 stroker and Dinan History and Dinan HQ Walkaround Gustav E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 2 23rd October 2008 13:08
Two new official Dinan Engineering Video: BMW M3 | M5 | M6 Tecknology on the V8 | V10 stroker and Dinan History and Dinan HQ Walkaround Gustav E39 M5 and E52 Z8 Discussion 5 23rd October 2008 05:27
Two new official Dinan Engineering Video: BMW M3 | M5 | M6 Tecknology on the V8 | V10 stroker and Dinan History and Dinan HQ Walkaround Gustav E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 1 23rd October 2008 05:26
Page generated in 0.13079 seconds with 12 queries
