Old 9th June 2009, 05:09   #11
6pack
6pack's Avatar
Garage: 07 M6 Black Sapphire Metallic
Congrates.
When I spoke to the Dinan rep at my dealership, he suggested I ship my car to Dinan if I wanted a stroker.
He said they would more equipped to test and tune.
I am correct that the stock headers are used with the stroker
and they add the Dinan midpipe to allow it to breathe?
You are lucky to have such qualified techs at the dealership. Also, lucky to have the stroker.
2007 M6 Black Sapphire Metallic/Carbon Fibre Trim
Eisenmann Race Oval Tips
3M Clear Bra
RPI Scoops (Black)
K40 Calibre Radar w Bluetooth Remote & Defuser EX
Sprint Booster
Vorsteiner Carbon Fibre Front Spoiler
Dinan H Flow Air Mass Meter/Intake D763-0044
Dinan Cold Air Intakes D760-0021
Dinan 13% Pulley D560-0001
Dinan Stage 3 Software D903-51M3
Dinan H Flow Throttle Bodies D760-3800A
Dinan 3.91 LSD D773-0601A
Dinan CF Strut Brace D180-0007A
Dinan Stage 2 Suspension D190-6318
2007 Escalade ESV/Black Raven
All Options Available
2009 CTS-4/Black Raven
6pack is offline
Old 9th June 2009, 05:51   #12
JaxTseng78
Garage: 08 M5 Interlagous Blue
How much do you want for your evosport headers?
JaxTseng78 is offline
Old 9th June 2009, 06:07   #13
Cosmos
Cosmos's Avatar
Garage: has lots of porn
Sales Feedback: (3)
This does not really come as a surprise to me...
"Motion does not equal progress"...Cos
Malo periculosam libertatem quam quietum servitium...
Cosmos is offline
Old 9th June 2009, 19:21   #14
Gustav
Administrator
Gustav's Avatar
A Dinan Stroker in Hong Kong? Congratulations!
Do you ship the engine to Dinan or do they send a mechanic to you?
for overseas stroker conversion!
Originally Posted by georgefu View Post
Got my '06 done too. Should be done by this weekend!
Stock header and cats with DINAN pulley, throttle bodies, intake, midsection and mufflers.
Gustav is offline
Old 9th June 2009, 19:28   #15
MMac
Garage: Unfortunately not a M...Will have one Someday:)
Congrats on the Dinan stroker. I am looking forward to seeing the finished result.
MMac is offline
Old 9th June 2009, 19:52   #16
Streetking
Streetking's Avatar
Garage: '08 M5 white
it's out!
Just took these a few mins ago. Didn't realize how big the transmission is.
SW
Streetking is offline
The Following 3 Users Say Thank You to Streetking For This Useful Post:
Daytona Bones (11th June 2009), S2000 (29th September 2009), shchow (10th June 2009)
Old 9th June 2009, 20:46   #17
mackyfr
mackyfr's Avatar
Garage: BMW M5 Sepangbronze metallic
Send a message via MSN to mackyfr
Wow... just wow! I couldn't be more jealous!!
mackyfr is offline
Old 9th June 2009, 21:24   #18
ThisFlyGuy
ThisFlyGuy's Avatar
Garage: 2006 BMW Interlagos Blue M5
wow didn't know your front suspension/brakes had to be taken out too...
2006 BMW M5
ThisFlyGuy is offline
Old 9th June 2009, 21:30   #19
invincible569
Garage: M5
How do you put that back together? I would be nervous.
Happy Stroking!
invincible569 is offline
Old 9th June 2009, 21:36   #20
Sebring NL
Sebring NL's Avatar
@ Streetking. You're the MAN. Very wise choice. BMW can't do this anymore over CAFE regulations, but this should be the new M5 engine
@ Flyguy. I am a big pro of taking out subframes on many cars for jobs like this. In fact, even the E28 and E34 M5 benefit from this. The V8 is virtually impossible to work on for some jobs too, and even on E30's I pull the subframe off for certain jobs. In the factory, the engine and trans are fitted in exactly the same way as depicted above, which is also the reason why std E39 and E60 M5 manifolds are so much viable for improvement ( the factory can't fit the headers after fitting the engine out of time /cost aspect, so the manifolds are OEM not in their ideal design for the sake of production) . Also, the other way of removing the engine is through the engine bay / hood area, which is much more difficult because:
1) danger of damaging the engine bay/bulkhead etc
2) Engine and box must be tilted almost 45 degrees, which is something you want to avoid with the complicated engines.
3) hood must be removed, and with the E60, its hard to put back correctly. Many a time, I have seen the hood/headlight area not coming along nicely anymore after the hood has been removed and retrofitted. Its not easy at all to adjust this properly, and it takes much more time all in all then removing the subframe and its surroundings
4) when putting the engine BACK, its much easier to move against gravity ( sounds strange!) rather than having a hoist that 'drops' the engine and box back into the car. If something would go wrong, a 20K engine falls through the bay of a 80k car. If something goes wrong when hoisting upwards , it simply slides back into the place it was when you started
it should also be noted, on engine swap scenarios, its always preferable to keep the engine and box as a unit, rather than separating them and putting it back together with the engine insitu
wout
///M5HD91-229-
|Eibach|Koni|Porsche Brembo
for looking through the windscreen
///M535iDC71-181-
|H&R|Bilstein|Sparco
for looking through the Lexan side windows
B6 3.5 1531-668-
|Dogleg|Glanzschwarz
for fun
C1 2.5 1531-184-
|D-1 cage|full race spec
for looking at chequered flags
740d GE81-317-
twinscroll v8 diesel daily
Sebring NL is offline
The Following 7 Users Say Thank You to Sebring NL For This Useful Post:
chowdah (10th June 2009), Clyde (10th June 2009), EGBOZ (9th June 2009), floridaBMW (20th June 2009), Gustav (9th June 2009), Kelster (10th June 2009), shchow (10th June 2009)
45 minutes discussion with Dinan on the V10 stroker engine + news that there will be a stroker Dinan M3 V8! Gustav E60 M5 and E61 M5 Touring Discussion 24 30th December 2008 14:12
Two new official Dinan Engineering Video: BMW M3 | M5 | M6 Tecknology on the V8 | V10 stroker and Dinan History and Dinan HQ Walkaround Gustav E60 M5 and E61 M5 Touring Discussion 7 28th November 2008 11:58
Two new official Dinan Engineering Video: BMW M3 | M5 | M6 Tecknology on the V8 | V10 stroker and Dinan History and Dinan HQ Walkaround Gustav E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 2 23rd October 2008 13:08
Two new official Dinan Engineering Video: BMW M3 | M5 | M6 Tecknology on the V8 | V10 stroker and Dinan History and Dinan HQ Walkaround Gustav E39 M5 and E52 Z8 Discussion 5 23rd October 2008 05:27
Two new official Dinan Engineering Video: BMW M3 | M5 | M6 Tecknology on the V8 | V10 stroker and Dinan History and Dinan HQ Walkaround Gustav E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 1 23rd October 2008 05:26
Page generated in 0.13007 seconds with 12 queries
