Old 19th June 2009, 11:14   #121
ur20v
Garage: e60 M5 (June 05 Build) Black on Black
I'd say it wasn't opened up early enough and was treated with 'kid gloves' and has glazed the bores, oh well just add the oil, its not worth 'opening' the motor to recify.
One caviate to do with the running in period, its not just the engine thats 'running' in, in the 1st 100 miles the most important thing from a safety point of view is go steady on the brakes and tyres, brakes have a galvanised layer on them that needs to be gentally removed and then the pads need to bed in and coat the discs, 1st 50 miles go really gental then do 10 or so medium to hard braking (not stops!!) from different speeds letting the brakes cool for a couple of miles between... just avoid coming to a complete stop as it will heat soak the pads and discs in one spot and warp the brakes. The tyres/tires need to be treated with great respect in the first 100 miles specially accellerating out of junctions or around corners as you could spin out due to release agents on the tyres specially in the rain!! plus they need to be heat cycled to to perform to their best .The dif, clutch/flywheel and gearbox need to be beded in, avoid high speed runs!!
Manufactures and insurers like long run in periods so you get used to your new performance gentally and learn the car and hopefully some of the showing off will have melted away by the time you can floor it!!??
Its a balancing act, just use your head!
Jay
ur20v is online now
The Following User Says Thank You to ur20v For This Useful Post:
Gustav (19th June 2009)
Old 19th June 2009, 15:20   #122
m3jasper
Garage: E36 M3 - Artic Silver
SW,
Curious as to why you removed the headers. Did Dinan tell you needed to? I would think that a set of good flowing headers would very well with the stroker...
m3jasper is offline
Old 19th June 2009, 15:24   #123
6pack
6pack's Avatar
Garage: 07 M6 Black Sapphire Metallic
Perhaps the tune would not account for it. I know they can do a custom tune on their software to account for the cel. It was offered to me. I think Dinan does not want to turn off the cel and risk improper
AF.
2007 M6 Black Sapphire Metallic/Carbon Fibre Trim
Eisenmann Race Oval Tips
3M Clear Bra
RPI Scoops (Black)
K40 Calibre Radar w Bluetooth Remote & Defuser EX
Sprint Booster
Vorsteiner Carbon Fibre Front Spoiler
Dinan H Flow Air Mass Meter/Intake D763-0044
Dinan Cold Air Intakes D760-0021
Dinan 13% Pulley D560-0001
Dinan Stage 3 Software D903-51M3
Dinan H Flow Throttle Bodies D760-3800A
Dinan 3.91 LSD D773-0601A
Dinan CF Strut Brace D180-0007A
Dinan Stage 2 Suspension D190-6318
2007 Escalade ESV/Black Raven
All Options Available
2009 CTS-4/Black Raven
6pack is offline
Old 19th June 2009, 17:46   #124
Sauvage
Garage: WTB [Ducati 1198S]
I removed his uneven length long tube headers and installed a set from Dinan that are modified stock even length headers with primary catalyst removed. SW knows more about the numbers but it was said by Dinan to be a beneficial change
Sauvage is offline
Old 20th June 2009, 01:28   #125
M6SCSMD
M6SCSMD's Avatar
Garage: 2008 M6 Alpine White Black Interior with Carbon Fiber
Just heard from my SA, Tim, that the engine is in and running. It just has to be remapped and the exhaust put on, and I should be able to pick her up tomorrow! I can't wait. One other pic of the two engines:
http://www.m5board.com/vbulletin/att...1&d=1245450470
Modifications: (Installed 06/09)
-Dinan High Flow Air Mass Assemblies
-Dinan Throttle Bodies
-Dinan Free Flow Exhaust
-Dinan 13% Underdrive Crankshaft Pulley Kit
-Dinan 5.7L Stroker Engine
-Passport 9500ci
M6SCSMD is offline
Old 20th June 2009, 01:30   #126
ThisFlyGuy
ThisFlyGuy's Avatar
Garage: 2006 BMW Interlagos Blue M5
how is gas mileage affected with the swap? same, better or worse?
2006 BMW M5
ThisFlyGuy is offline
Old 20th June 2009, 04:42   #127
DarrinB
DarrinB's Avatar
Garage: 2006 M5 Silver Gray/Black/Aluminum
Where in Ohio are you? Try to make it to one of the tracks over here one day?
2006 BMW M5 Silver Gray/Black/Aluminum
-Hardwired V1
-35% tint
-Clear Bra
-cf delete
-12.346@117.78 mph 1.86 60'(before cf delete) 65 deg
-12.303@116.00 mph 1.87 60'(after cf delete) 47 deg
2003 Acura CL Type S
Black/Black(traded in for ///M5)
-Aem intake, comptech exhaust/headers, comptech sways, eibach springs, UR crank pulley
-fastest 1/4 time: 14.21@98.68
DarrinB is offline
Old 20th June 2009, 05:54   #128
G ///McGregor K
G ///McGregor K's Avatar
Garage: '08 M5 Space Gray
Thats a sweet picture! Congrats!
2008 Space Gray/Black Full Merino Leather/Alum. trim
Loaded - every option (minus heated steering wheel)
Interior:Hardwired Valentine One with Concealed Display, Blinder Xtreme M25 (J16) Laser Jammer, Bimmian Interior Xenon Lighting Kit and ///M Racing Pedals
Exterior: Hartge Front Spoiler Lip, Hartge Rear Diffuser, Vorsteiner Vented and Domed Hood (Double-Sided CF), Hamann Roof Spoiler, H&R Springs and 15% Tint
"Performance": ASR Cold Air Intake, RPI GT Section 3 Muffler, Custom Fabbed Straight-Pipe Section I, Evosport Power Pulley and Hybrid Rear Badge
G ///McGregor K is offline
The Following User Says Thank You to G ///McGregor K For This Useful Post:
M6SCSMD (20th June 2009)
Old 20th June 2009, 06:10   #129
PianoProdigy
Garage: Interlagos Blue 2006 M5
Really?
PianoProdigy is offline
Old 20th June 2009, 06:14   #130
cshorter
cshorter's Avatar
Garage: 2007 Silverstone M5
Well at 5.0 liters I'm sure he was getting around 13MPG, so (5.7/5.0)*13=14.8 I think he's got a shot at breaking 15 MPG...
2007 M5 Silverstone
6-Speed, with some options and what-not...
1977 Black/Black Corvette
cshorter is offline
45 minutes discussion with Dinan on the V10 stroker engine + news that there will be a stroker Dinan M3 V8! Gustav E60 M5 and E61 M5 Touring Discussion 24 30th December 2008 14:12
Two new official Dinan Engineering Video: BMW M3 | M5 | M6 Tecknology on the V8 | V10 stroker and Dinan History and Dinan HQ Walkaround Gustav E60 M5 and E61 M5 Touring Discussion 7 28th November 2008 11:58
Two new official Dinan Engineering Video: BMW M3 | M5 | M6 Tecknology on the V8 | V10 stroker and Dinan History and Dinan HQ Walkaround Gustav E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 2 23rd October 2008 13:08
Two new official Dinan Engineering Video: BMW M3 | M5 | M6 Tecknology on the V8 | V10 stroker and Dinan History and Dinan HQ Walkaround Gustav E39 M5 and E52 Z8 Discussion 5 23rd October 2008 05:27
Two new official Dinan Engineering Video: BMW M3 | M5 | M6 Tecknology on the V8 | V10 stroker and Dinan History and Dinan HQ Walkaround Gustav E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 1 23rd October 2008 05:26
Page generated in 0.12035 seconds with 12 queries
